DunnYet Posted May 19, 2024 Posted May 19, 2024 (edited) Acknowledging the risk of starting a contentious discussion.... For the composting toilet boosters - We are studying the possibility of staying with the composting toilet and are reading other threads around that. However, I'm a planner so I want to understand / gather parts lists for a "de-conversion" project. Does anyone know the exact model of the toilet that is in the LE II in the 2023 model year range? If I'm going to make the change the spouse would like a lower one than our LE I currently has if possible. I think it's a Dometic 3xx but trying to determine which one exactly. The LE I is a Dometic 311. I believe that it's the same between the LE I and the LE II - again not sure of this though. From other posts I know that the black tank is still in there, as well as the water valve to hook up to the flush toilet. Any advice on what is required to make the connection between the black tank and the toilet would be appreciated. Thanks very much - once I start this project, I will be putting a reverse how-to up on the forum. Kevin Edited May 19, 2024 by DunnYet Left our what I already knew - that the LE I is a 311 Current: 2023 Oliver Elite II - Hull #1364 "Reset 2.0" (Second Owner) Tow Vehicle: 2023 Ford F-150 XLT 3.5L EcoBoost /w 3.55 axle and Max Tow Package "SIlver" Original: 2022 Oliver Elite I - Hull #1030 "Reset" (For Sale) Original Tow Vehicle: 2022 Subaru Ascent "Blue Moose" Home Base: Duncanville, TX
jd1923 Posted May 20, 2024 Posted May 20, 2024 I'm with you, thank you. You can't get me to do anything but hookup the hose at the dump station! 🤣 Separate liquids from solids and more cr@p, NOT! (pun intended) Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Moderators SeaDawg Posted May 21, 2024 Moderators Posted May 21, 2024 I'll look forward to your posts. You can compare heights on any low profile toilet. Our 2008 Aqua magic has been great. All the composting toilets are tall. If you like that concept, buy/get a footstool. If not, retrofit, and join the rest of us with the stinky slinky. 2 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
JBurton Posted May 21, 2024 Posted May 21, 2024 On 5/19/2024 at 4:09 PM, DunnYet said: Acknowledging the risk of starting a contentious discussion.... For the composting toilet boosters - We are studying the possibility of staying with the composting toilet and are reading other threads around that. However, I'm a planner so I want to understand / gather parts lists for a "de-conversion" project. Does anyone know the exact model of the toilet that is in the LE II in the 2023 model year range? If I'm going to make the change the spouse would like a lower one than our LE I currently has if possible. I think it's a Dometic 3xx but trying to determine which one exactly. The LE I is a Dometic 311. I believe that it's the same between the LE I and the LE II - again not sure of this though. From other posts I know that the black tank is still in there, as well as the water valve to hook up to the flush toilet. Any advice on what is required to make the connection between the black tank and the toilet would be appreciated. Thanks very much - once I start this project, I will be putting a reverse how-to up on the forum. Kevin Good morning Kevin. I would be happy to help you. I ordered my LE ll with the composting toilet and after six months decided I would rather have a flusher and converted to the factory toilet myself. If you’ll give me a call. I can offer some guidance. John Burton 480-390-6996 2 4
Galway Girl Posted May 21, 2024 Posted May 21, 2024 We replaced our 2019 EII standard toilet with a Dometic 311 (due to broken foot pedal. 4 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com
JBurton Posted May 21, 2024 Posted May 21, 2024 On 5/19/2024 at 4:09 PM, DunnYet said: Acknowledging the risk of starting a contentious discussion.... For the composting toilet boosters - We are studying the possibility of staying with the composting toilet and are reading other threads around that. However, I'm a planner so I want to understand / gather parts lists for a "de-conversion" project. Does anyone know the exact model of the toilet that is in the LE II in the 2023 model year range? If I'm going to make the change the spouse would like a lower one than our LE I currently has if possible. I think it's a Dometic 3xx but trying to determine which one exactly. The LE I is a Dometic 311. I believe that it's the same between the LE I and the LE II - again not sure of this though. From other posts I know that the black tank is still in there, as well as the water valve to hook up to the flush toilet. Any advice on what is required to make the connection between the black tank and the toilet would be appreciated. Thanks very much - once I start this project, I will be putting a reverse how-to up on the forum. The factory uses the Dometic model 311. It’s low profile at 13 3/4”. I purchased mine from Camping World on sale and I think they’re still on sale with free shipping. 1
Galway Girl Posted May 21, 2024 Posted May 21, 2024 (edited) If you get a dometic 311- suggest the one with the upgraded slow close seat/lid. It's a residential lid made of heavy material. The default from dometic is a plastic lid/seat with no slow close and it is rather flimsy. Edited May 21, 2024 by Galway Girl 2 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com
Geronimo John Posted May 21, 2024 Posted May 21, 2024 (edited) MS AI says the dimensions by model are as follows: (Suggest independent verification) GJ When I had to replace my OTT OEM toilet due to a 25 cent part breaking and no available parts, my research yielded the below info. I chose to go with the low profile elongated seat 321 Full Timer. Hope this is useful. GJ MODEL 311 Part Timer 320 Full Timer (Wrong P/N - My Error) 320 Full Timer 321 Full Timer E-Trailer # DOM67FR DOM87FR DOM87FR DOM99FR DESCRIPTION Low Profile Round Stand. Height Elongated Stand. Height Elongated Low Profile Elongated SOURCE: OEM PROVIDED May 2018 E-Trailer OR# 113709215 Shipped to Idaho, 83255 Dometic Warranty Replacement Need this model COLOR White White Same White STATUS Plastic Flush Rod Failed. Discarded in Idaho upon receipt of E-trailer replacement. Replacement toilet purchased. Flush ball seal not centered. Leaked water & sewer gas Still in original unopened box. DEPTH 19" 22" Same 22" HEIGHT 14.25" 19.25" TILT! Same 13.5 The 5" step between the toilet mounting surface and where you feet go is why just about all of us under seven feet tall need the low profile model. For more efficient printing, I have transformed the above into my DIY format. DIY - Dometic Toilet Replacement Specifications.docx Edited May 21, 2024 by Geronimo John Added printable DIY file. 3 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
DunnYet Posted May 24, 2024 Author Posted May 24, 2024 On 5/21/2024 at 8:32 AM, JBurton said: Good morning Kevin. I would be happy to help you. I ordered my LE ll with the composting toilet and after six months decided I would rather have a flusher and converted to the factory toilet myself. If you’ll give me a call. I can offer some guidance. John Burton 480-390-6996 Thanks very much John will take you up on that! 1 Current: 2023 Oliver Elite II - Hull #1364 "Reset 2.0" (Second Owner) Tow Vehicle: 2023 Ford F-150 XLT 3.5L EcoBoost /w 3.55 axle and Max Tow Package "SIlver" Original: 2022 Oliver Elite I - Hull #1030 "Reset" (For Sale) Original Tow Vehicle: 2022 Subaru Ascent "Blue Moose" Home Base: Duncanville, TX
