Townesw Posted June 7 Share Posted June 7 Summary: make sure your accumulator is not rubbing against the bottom of the curb side bunk. Check the cutouts above the rear jacks. Check the duct under the curb side bunk. I noticed black dust on the board that the water pump and accumulator are mounted to. Turns out that the pump, piping, accumulator, valve, etc. assembly doesn’t really fit together well but it is screwed to the board anyway. The misalignment between the pump and accumulator caused the rubber bushing in the mount on one side of the accumulator to become dislocated and the accumulator rubbed against the bottom surface of the curb side bunk. I caught it before it wore through. I also noticed that both cutouts to access the studs to manually operate the rear jacks don't line up with the studs and would have made it hard to manually operate the jacks. I’ll enlarge these later. Also the 2 bolts on the rear curb side jack could rub through the heater duct. 5 4 1 2 Bill and Martha 2018 LEII Hull 313 2019 Chevrolet 2500HD Duramax Link to comment Share on other sites More sharing options...
Geronimo John Posted June 7 Share Posted June 7 WOW. I'll be adding this for my 2018 model OE2. Thank you for posting. GJ 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR). Link to comment Share on other sites More sharing options...
Patriot Posted June 7 Share Posted June 7 Yes, thanks for posting. I will be inspecting these areas for sure. 1 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor North Carolina 🇺🇸 Link to comment Share on other sites More sharing options...
jd1923 Posted June 7 Share Posted June 7 @Townesw it's strange how from hull #113 to #313 there is such a difference! The crank on my rear stabilizer jacks (both sides) are 2-3" from the edge. 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins! Link to comment Share on other sites More sharing options...
Townesw Posted June 8 Author Share Posted June 8 @jd1923 What is the stuff attached to the Simpson Strong Tie? Have you replaced the quarter turn valves with solenoids? Bill and Martha 2018 LEII Hull 313 2019 Chevrolet 2500HD Duramax Link to comment Share on other sites More sharing options...
jd1923 Posted June 8 Share Posted June 8 4 hours ago, Townesw said: @jd1923 What is the stuff attached to the Simpson Strong Tie? Have you replaced the quarter turn valves with solenoids? Yes Bill, they are actually motorized ball valves. Here is the upgrade thread: 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins! Link to comment Share on other sites More sharing options...
MAX Burner Posted June 23 Share Posted June 23 On 6/7/2024 at 5:25 PM, jd1923 said: The crank on my rear stabilizer jacks (both sides) are 2-3" from the edge. Our 2017 LE2 was configured the same way - just re-mount/re-plumb that stuff around to make the accumulator fit like this, buddy: We'll do it this summer when you come over for a visit! We'll even make room for a small MT. Bike Pump for when the accumulator drops pressure! HA! Cheers! Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX Link to comment Share on other sites More sharing options...
jd1923 Posted June 23 Share Posted June 23 @MAX Burner my comment was re the stabilizer Jack being further from the edge (see pics above). We don’t need no schtinken ‘cumulator, REMCO pump Made in USA, variable speed pump, they suggest no accumulator necessary. 🤣 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins! Link to comment Share on other sites More sharing options...
MAX Burner Posted June 24 Share Posted June 24 On 6/22/2024 at 8:52 PM, jd1923 said: We don’t need no schtinken ‘cumulator, REMCO pump Made in USA, variable speed pump, they suggest no accumulator necessary. 🤣 Ah! Of course. Frankly, after installing the accumulator last year, I still can't tell the difference at any of the points of usage. Been playing with pressures between 15 and 30psi. Whatever.... Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX Link to comment Share on other sites More sharing options...
