DunnYet Posted July 21, 2024 Posted July 21, 2024 Well - it finally happened to us. We broke the hinge on the Norcold Fridge in Reset (Hull # 1030 LE I). Easy fix right? It is if you can source the parts. For reference, the parts are Left Hand Hinge - Norcold 619042 Right Hand Hinge - Norcold 619041 Unfortunately, I have only found a source for the Right Hand Hinge. The Left Hand Hinge seems to be very elusive. Have a service ticket in with Oliver to see if they have a source, as well as a request in directly to Norcold. Does anyone have a favorite source for Norcold parts that you could share? Or a spare hinge that I could purchase from you? 🙂 1 Current: 2023 Oliver Elite II - Hull #1364 "Reset 2.0" (Second Owner) Tow Vehicle: 2023 Ford F-150 XLT 3.5L EcoBoost /w 3.55 axle and Max Tow Package "SIlver" Original: 2022 Oliver Elite I - Hull #1030 "Reset" (For Sale) Original Tow Vehicle: 2022 Subaru Ascent "Blue Moose" Home Base: Duncanville, TX
Moderators SeaDawg Posted July 21, 2024 Moderators Posted July 21, 2024 (edited) https://rvfridgeguys.com/norcold-evaporator-door-spring-holder-w-spring-619042-fits-left-hand-side/ Most people show it out of stock. I've purchased from rvipgrades before. Not rvfridheguys. But both show it still in stock. Good luck. Edited July 21, 2024 by SeaDawg 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Snackchaser Posted November 17, 2024 Posted November 17, 2024 Oh boy, another one bites the dust! Those little notched pins for the freezer door hinge broke off on ours too, and now the door won’t stay closed or seal. I searched the net for new parts and nobody had the left spring holder assembly. But while searching, this post popped up and I found out Im not alone! Apparently Norcold is out of business and these parts are no longer available. So short of replacing the whole fridge, I figured out a way to repair them. I cut out pieces from 1” x 1/16” brass bar to “sister” onto the broken spring holder assemblies. Holes were drilled for a 3/16” brass pin and 1/16” rivets. I filed notch’s on the brass rod to match the original pins and soldered them into place with plumbers flux and solder. I trimmed the excess, and filed it flat. The new brass piece was riveted onto the hinge with 1/16” diameter x 1/4” flat head brass rivets. Fortunately I had all the brass and rivets in my stash, but most hardware stores carry this stuff. It was a little tricky to install the hinges with enough spring preload, probably because the repaired hinges were stiffer and wider than the originals. Here’s what worked for me: Put the repaired right spring holder assembly in it’s final position on the fridge wall. Remove the right door mount clip from the door. Install the left spring holder assembly onto the door mount clip so it has spring pre-load. Mount left side door with spring holder/clip assembly onto fridge while maintaining spring pre-load. While holding door in place, use left door clip to wind some pre-load and screw it on the door. Hope this saves someone a new fridge! Cheers, Geoff 7
Ronbrink Posted November 17, 2024 Posted November 17, 2024 My temporary fix is working well enough and may tweak a bit for a more permanent solution, since parts are not readily available. 3 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, Hughes Autoformer, dual Lagun tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, Dreiha Atmos 4.4 A/C upgrade. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone Refrigerator and Freezer; pending transfer of Mechman 320A high output alternator from former TV.
Moderators topgun2 Posted November 17, 2024 Moderators Posted November 17, 2024 Might something like THIS work for keeping that door closed? Bill p.s. "invention is the mother of necessity" and I really like your work. 1 5 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Snackchaser Posted December 4, 2024 Posted December 4, 2024 Hurray! Dometic freezer hinges work in the Norcold! Although I repaired my old broken Norcold hinges, I had also ordered a replacement right-hand hinge while they were still available. It was then I noticed that Dometic freezer hinges looked very similar. The major dimensions were the same, only the spring barrel was shorter, so I ordered a left one from a family owned Oregon company called iFiXiFi, and it works perfectly. It's so nice to have that door snap firmly closed again! There are actually several aftermarket Dometic hinges on Amazon, but the iFiXiFi brand seemed better and they also have Youtube videos that cover the design and quality of their parts and installation methods. It was about $35 for the Left hinge including the shorter spring and hinge pin. You may notice from the photos that the Dometic style hinge does not have the "90 degree open stop" as does the Norcold. This is to prevent the main door from bending the freezer door past 90 degrees to the point where it could break. The Dometic refrigerators have stops moulded into the frame for this purpose. You can retain this feature by using a Norcold right hinge, which are still available, with the Dometic left hinge. Otherwise just be mindful of it. Amazon https://a.co/d/fftOAMe IFiXiFi installation videos: https://youtu.be/fXQCQgKwjGo?si=ES5rrbr0vK1UJB2N I also recommend this video, it was the method I used. https://youtu.be/8Ae0ncOSu9U?si=wBuMTqLK6erE5Jqi I should mention that AliExpress also carries a Dometic hinge kit that comes with the left and right hinges including springs and pins for $29, but I can’t vouch for the quality. Cheers! Geoff 3 4 1
Ronbrink Posted January 16 Posted January 16 On 11/17/2024 at 7:04 AM, topgun2 said: Might something like THIS work for keeping that door closed? Bill p.s. "invention is the mother of necessity" and I really like your work. Yes, thanks for the inspiration! I purchased some magnetic catches (set of four) for $7, and asked my Son to design and 3D print a couple of mounting blocks. I decided to use the magnetic halves from two paired sets for a stronger, single catch. Here is what I did: Mounting blocks with recess for flush fitment of magnetic catch components, shown here as a pair. View of optional mounting holes and longer screws for vertical attachment. Catch components screw-mounted into block recess, shown as a pair. Center interior door attachment, horizontal mount using screws. Center interior freezer attachment, vertical mount using Alien Tape rather than screws as a preliminary precaution. Completed install. I’m very pleased with the holding power of the dual magnet approach, now for some field testing! 4 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, Hughes Autoformer, dual Lagun tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, Dreiha Atmos 4.4 A/C upgrade. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone Refrigerator and Freezer; pending transfer of Mechman 320A high output alternator from former TV.
Kathy Tewart Posted January 17 Posted January 17 Thanks for sharing everyone, my experience with the freezer door is the latch breaks easily. We had to replace one early on with our 1st fridge. It’s a shame Norcold does not make this model anymore (or they are out of business?) Our 1st fridge died after 2 years and that is when we found out it could not be replaced or parts ordered. We ended up buying the same unit off ebay, new, because it was sort of the easiest option for us. 1
