rich.dev Posted 1 hour ago Posted 1 hour ago (edited) 9 minutes ago, jd1923 said: I'm not doing the windows but will run a full length strip up at the streetside roof line. I did same John, but I used the 3/4” and on both the driver and passenger side. https://a.co/d/08DrU7cW Edited 1 hour ago by rich.dev **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
jd1923 Posted 59 minutes ago Posted 59 minutes ago 9 minutes ago, rich.dev said: I did same John, but I used the 3/4” and on both the driver and passenger side. Yeah Rich, so it must have kept the drip lines off the fiberglass on both sides! I believe with 25" I should have about 6 ft leftover to place a drip edge on the rear just below the OLIVER sign. You had cautioned us as to how this product would not straighten out, creating wrinkles, which can be seen in your picture. This thread started with a $16 product, with the title "DO NOT use this product!" The one you tried is $40 and the Trim-Lok with 3M tape is $63. It's expensive, but now that I have it in hand, you can stretch this product at a radius opposite to how it's coiled up for packaging and it stretches nicely without wrinkling. Your warning and finally @ScottyGS's suggestion got me to the right product, thank you! 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
