srthomsen Posted February 23, 2025 Posted February 23, 2025 On 10/27/2024 at 7:17 PM, Jason Foster said: If it is worth it, then it is worth it. Age is one thing that no one can run from. 1 2023 Elite #1403--2019 Ford F150--2.7 Ecoboost V6--10 speed auto--without Max Tow
Moderators topgun2 Posted February 24, 2025 Moderators Posted February 24, 2025 17 hours ago, srthomsen said: Age is one thing that no one can run from. But - I'm running as fast as I can! And, now you tell me that all this running is for nothing? 1 4 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
MAX Burner Posted February 24, 2025 Posted February 24, 2025 3 hours ago, topgun2 said: But - I'm running as fast as I can! And, now you tell me that all this running is for nothing? Hey, Bill -- slow down, brother. If you don't, you'll eventually just die tired! HA! 3 1 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Jason Foster Posted March 4, 2025 Posted March 4, 2025 On 2/23/2025 at 3:24 PM, srthomsen said: Age is one thing that no one can run from. You can't run from it but you can run with it. Stay mobile, stay strong. 3 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
MobileJoy Posted March 4, 2025 Posted March 4, 2025 The age thing is definitely overrated... We had ours done 18 months ago. We used to wax, but after a long trip cleaning the Mojo took considerable elbow grease. We returned from a long trip in 10/24 and the Mojo hadn't been washed in over 2 months. It cleaned up easily. Black drip stains wiped away with almost no effort. Even bugs were easier to remove. It looks better than new. So I'd say it is definitely worth the money given the cleaning and waxing time saved, and the appearance of the cleaned fiberglass. Ours is garaged and we use RockTamers. On 12/5/2024 at 6:45 PM, Rolind said: The guys were fantastic, did great work and were fun to talk to on drop off and pickup. We would strongly recommend them for their excellent work. Ditto! 2 2021 Elite II Twin #850 "Mojo", 2020 F250 Lariat 7.3L FX4 3.55
Galileo Posted March 4, 2025 Posted March 4, 2025 On 10/27/2024 at 7:55 PM, Mountainman198 said: and the chance to get intimate with my trailer. I think this is a huge factor. Of course, a really attentive person or crew doing the work for you could tell you everything they found, but seeing, touching, feeling everything for one’s self is huge for a DIYer. Last trip on top of the Oliver was to do a detail wash after being up there to rescue the bolts that had vibrated out of the fan motor on the Dometic A/C. (That unit is SO loud and obnoxious that it needs a nickname - like the “Vultee Vibrator” or the “Piper Traumahawk”) That little exercise got me familiar with the crud buildup by the awning brackets, weatherproofing around the various gadgets attached to the roof, and an as yet unexplained stain on the roof caused by something leaking of that dang A/C. Even from inside, I can see the MaxxFan needs to come OFF the roof to detail clean the inside of the translucent dome. I thought I was being anal when I removed the fan blade for a proper wash rather than just a quick wipe-down. We use the fan A LOT (probably because the damn A/C is so freaking loud - have I mentioned that before? 😋 ) so dirt, dust, cat hair, etc build up on the fan parts and can’t be cleaned thoroughly from inside. We don’t even cook much inside, but something being drawn out of that fan is acting as an adhesive to hold that dirt. Anyway, here’s to getting intimate with our trailers…. Oh, and I can’t find the bottle at the moment, but I’m using some expensive, highly-recommended milky-looking spray on the front of the trailer and TV to help the gozillion “love bugs” - that completely coat the front of vehicles driving through Louisiana - slide off as opposed to needing sandpaper to remove them. 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
Ronbrink Posted March 4, 2025 Posted March 4, 2025 2 hours ago, Galileo said: We use the fan A LOT (probably because the damn A/C is so freaking loud - have I mentioned that before? 😋 You are not alone; some owners bothered more than others, but your assessment is spot on! 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
