Gonz Posted October 26, 2024 Posted October 26, 2024 Rheostat Install on AC.pdfHello, I am sharing instructions I developed for installing a rheostat on the Dometic A/C so the A/C blower motor's speed and can controlled and reduced, thereby reducing the excessive air turbulence noise. FYI, the file size is large, I apologize for this. I tried compressing the file prior to uploading, but most of the content disappeared each time I compressed the file. I also tried compressing the photos within the file, but this too did not work. Thanks, GG 4 3
Moderators topgun2 Posted October 26, 2024 Moderators Posted October 26, 2024 Gonz - I assume that you have an Elite II. Can you tell us what year you have? Thanks. Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Tideline77 Posted October 27, 2024 Posted October 27, 2024 This looks like a great modification! thanks for the detailed instructions 👌🏻👌🏻👌🏻 Robert E 2022 LE II , LIthium Pro, 2018 F150 XLT 4WD 2.7 EcoBoost , 355 gears, tow package,36 gallon fuel, factory brake controller, transmission cooler
katanapilot Posted October 27, 2024 Posted October 27, 2024 Does the Dometic noisemaker A/C have an evaporator temperature sensor? I'm not an HVAC expert, but I would be concerned about operating the fan at too low of a speed and freezing up the evaporator. Sorry, I didn't take the time to read the attached file. 2 2020 Elite II Hull #628, Houghton Heat Pump, Victron MP2, SmartSolar, Orion, Cerbo, Lynx install in progress... TV - 2011 Toyota Tundra Crew Max Platinum 4WD, Magnuson Supercharger, OME suspension, Wilwood front and rear brakes
jd1923 Posted October 27, 2024 Posted October 27, 2024 20 hours ago, Gonz said: I am sharing instructions I developed for installing a rheostat on the Dometic A/C so the A/C blower motor's speed and can controlled and reduced, thereby reducing the excessive air turbulence noise. This is a great idea and when we get back to high speed internet I’m looking forward to reading the PDF and trying it! Thank you. At Inks Lake in a sea of Olivers I noted a few things. First off, if you have $1650 to spend, get the Atmos A/C! @Ronbrink’s system is amazing. In 15 minutes at the noon hour in Texas 80+ heat and humidity it cooled the interior at a whisper! Humidity dropped 11% on the gauge and I felt cool and dry before we looked at the numbers. We run our Dometic only when necessary and set it in Auto so the fan is on only when the compressor is on. The majority of noise is inside from the loud fan at high speed. Outside it’s not near as noisy. We had a neighbor who runs theirs fan ON always. Their outside noise was double ours, likely from running it 24x7! Theirs was not only louder but I could hear bearing noise, on top of noise! 2 hours ago, katanapilot said: would be concerned about operating the fan at too low of a speed and freezing up the evaporator. Maybe, but likely with the fan at 50-60% it would be fine. Most A/C systems allow for multiple fan speeds, but set on AUTO ours only runs fan on HIGH. Worth a try! What are you chancing, a poor Dometic model where w/o modification needs replacing anyway? 4 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Geronimo John Posted October 27, 2024 Posted October 27, 2024 GG Thanks for the post and procedure. I share the thoughts of Kantanga and JD on not taking the fan speed down too low. One safety thought from your procedure which states: "Regarding electrical safety, none of this work should be performed without 1) first flipping the A/C breaker located in the panel under the dining table, 2) assuring the Oliver is disconnected from shore power and 3) assuring the solar system’s inverter is turned o (if your Oliver is equipped with a solar system)." Most OTT's have inverters. Yes you have well killed relavant breaker and power sources to the A/C unit. But if the inverter is left on and the wrong breaker is turned off, (As it is easy to do looking at it upside down in the dark on most of our trailers), then you could be in for an "enlightening experience". For safety sake I suggest you also list turning OFF the Inverter. Again, great post! Safety John (AKA GJ) 3 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Ronbrink Posted October 27, 2024 Posted October 27, 2024 3 hours ago, jd1923 said: In 15 minutes at the noon hour in Texas 80+ heat and humidity it cooled the interior at a whisper! Humidity dropped 11% on the gauge and I felt cool and dry before we looked at the numbers. Great testament on the Atmos. Felt bad you guys had to step into the Oliver with the a/c off, but then perfect demonstration of the efficiency of the unit to quickly cool the interior while dropping the humidity! Love me some Atmos! 4 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, Hughes Autoformer, dual Lagun tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, Dreiha Atmos 4.4 A/C upgrade. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone Refrigerator and Freezer; pending transfer of Mechman 320A high output alternator from former TV.
mountainoliver Posted October 27, 2024 Posted October 27, 2024 Ronbrink, thanks for showing/demonstrating your great installation of the Atmos air conditioner! I have a question though, not so much for you as it is for the Houghton second generation folks. The major issue with the second generation Houghton is that the evaporator fan (inside fan) runs continuously and supposedly raises the inside humidity level. Yet the Atmos unit (at least in Texas) operates the same and significantly reduced the humidity in the camper with a fairly significant amount of condensate running off of the camper roof. What am I missing? What’s different? 1 2017 Elite II, Hull #208 2019 Chevy HD 2500 Duramax
Gonz Posted October 27, 2024 Author Posted October 27, 2024 All, the instructions state my Oliver is a 2021 Elite II. The instructions also state the importance of being safe and assuring no work is performed without first 1) flipping the A/C breaker in the main panel under the dining table, 2) disconnecting from shore power and 3) turning off your inverter. A couple questions were asked about freezing the cooling coil, this is addressed in the instructions. Regarding the risk of freezing the coil, I meant to add instructions on how to visually check the coil for signs of freezing; I periodically checked the coil for freezing during the testing that I conducted and never saw signs of freezing. I will update the instructions on how to check for freezing (while the A/C is operating) in case you choose to do this modification. The check is easy to do and very safe. 1
Gonz Posted October 27, 2024 Author Posted October 27, 2024 All, I have updated the instructions to Rev 1. The last two pages in Rev 1 outline the process for inspecting the cooling coil for signs of freezing. Rheostat Install on AC rev 1.pdf 2
Ronbrink Posted October 28, 2024 Posted October 28, 2024 (edited) 15 hours ago, mountainoliver said: The major issue with the second generation Houghton is that the evaporator fan (inside fan) runs continuously and supposedly raises the inside humidity level. Yet the Atmos unit (at least in Texas) operates the same and significantly reduced the humidity in the camper with a fairly significant amount of condensate running off of the camper roof. What am I missing? What’s different? I have read that outside air being drawn in as the issue with the Houghton, but some have argued it is not and I respect that. I do know that the Atmos has significantly more airflow than my former DPll and maybe more than the Houghton, as well. That said, this increased airflow could be drying the wet coils out faster and/or more efficiently, thereby decreasing humidity levels. I too would like to better understand and hopefully someone can provide a definitive answer to your questions. Edited October 28, 2024 by Ronbrink 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, Hughes Autoformer, dual Lagun tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, Dreiha Atmos 4.4 A/C upgrade. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone Refrigerator and Freezer; pending transfer of Mechman 320A high output alternator from former TV.
Gonz Posted October 28, 2024 Author Posted October 28, 2024 On 10/26/2024 at 4:36 PM, topgun2 said: Gonz - I assume that you have an Elite II. Can you tell us what year you have? Thanks. Bill 2021
Geronimo John Posted October 29, 2024 Posted October 29, 2024 On 10/27/2024 at 11:14 AM, mountainoliver said: The major issue with the second generation Houghton is that the evaporator fan (inside fan) runs continuously and supposedly raises the inside humidity level. There is no "Supposedly". It does as reported, tested, documented and videoed on several sites. For non-believers here is a simple demonstration procedure of the amount of moisture that their Set 2 units generate: Run the stock not modified Houghton on auto cool with the T-stat set to lowest setting. The unit will run and as it approaches set temp, the fan speed will work its way down to low. Run for a few minutes longer. The evaporator coil will be "Loaded" with condensate and you should be seeing signs of excess condensate running over the side of your trailer. Now cycle off the unit. THen turn it on to heat pump and set the temp to max temp to cause the heat pump to start. You will now feel and sense the huge amount of moisture being evaporated off the supply air coil and being dumped into the cabin as the warm heat pump air dries out the supply air coil. BTW, you can do this with any heat pump air conditioner. I estimated the amount of moisture retained in the fins of our unit to be ab0ut 25 ounces. If the fan is not cycled with the compressor, as the vast majority of ac units are designed, you can expect to see this problem. It can be amelerated somewhat by design by changing the coil face temperature and by special coatings on the coil fins and piping. But the results still will be unsatisfactory for most US mainland conditions. Hence this is one of the two problems with stock Set 2 Houghtons. My hope is that Houghton later units will be redesigned to cycle the supply air fan with the compressor, and also come with a remote thermostat. Those two changes would make the Houghton a class leader in quality and performance. GJ 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
mountainoliver Posted October 29, 2024 Posted October 29, 2024 John, I never said that I was a non believer! I just asked the question hoping that the issue could be explained clearly. I’m not on either side of the issue. 2 2017 Elite II, Hull #208 2019 Chevy HD 2500 Duramax
mountainoliver Posted October 29, 2024 Posted October 29, 2024 Just curious, why would I want to run the air conditioning wide open then immediately run the heat wide open? If I did that with my home heat pump/air conditioner I think that the same thing would happen. I don’t think that I remember that the air conditioner was run then the heat pump. I can understand now why a huge amount of humidity is cycled into the trailer. Maybe that explains why the Atmos unit cooled down the trailer and reduced the humidity even though the fan was running continuously, it was allowed to run a normal air conditioning cycle. Thanks for the explanation, much appreciated. 4 2017 Elite II, Hull #208 2019 Chevy HD 2500 Duramax
Geronimo John Posted November 1, 2024 Posted November 1, 2024 Said differently: The goal of the AC is to cool and dehumidify. For dehumidification you want to be getting humidity out of the system as fast as possible. For the Gen 2 Houghton it is by dumping it over the side. If the supply air fan is turned off with the compressor, most of the around 23 ounces of liquid on the coil remains on the coil. Upon start up you very quickly are kicking condensate over the side . If the supply air fan contineues to run, most of the condensate will be moved back into the cabin. Sort of like two steps forward and one step back thing. Hope this helps GJ 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
