Relatively new LE I owners here. We did about 20+ days on the road after picking it up this summer. We are loving everything about our LE I - except, a day on the road nearly always results in one or more window shades falling off at some point during the day. We pick them up and re-mount them and continue on. A quick search of the forum shows that it is not uncommon, however, we recently had one break as a result of falling. Oliver has been great in getting us a replacement but I want to find a remedy before we break another. (Actually the shade material gets buggered up a bit when the fall as well.) Has anyone found a sure fire method of preventing the shades from falling off? Would you consider a drop of super glue on a couple of the clips?
We mount them top first and then a firm hand to the bottom to lock them in. They always appear firmly mounted before we take off. Thinking out loud here, I wonder if the LE I single axle is more prone to shades coming loose since it may be a bit more prone to bounce when hitting a bump in the road. We are getting ready for an extended trip in a couple weeks and I would like to find a solution.
I know there's a window shade subject matter expert out there. I just need to find him/her. 🙂
  • Sad 1
2024 Legacy Elite Platinum, Hull #1465
2024 Nissan Pathfinder, Rock Creek Edition
Lithium Batteries (260AH),
240 Watt Solar with Charge Controller, and a 2000 Watt Pro Inverter.
Victron Orion XS 50A DC-DC Battery Charger
Just my 2 cents...we have an LE2 and had the same problem with one of our shades.  I also thought they were securely fastened until I realized how the metal clips actually held the window casing on.  The backs of the window casings have a recessed channel that accept the metal clips and some were loose or did not protrude far enough into the channels.  Some clips have fiberglass strips beneath them and some don't.  I guess that was a mod Oliver did to get all clips to hold.  The trick for us, after ensuring the screws holding the clips were tight, was to add a strip of fiberglass to a clip, if necessary, to make sure the clip would protrude into the channel far enough to lock in.  So if one doesn't seem to grab then it probably need a spacer.  And if it already has one it's possible it needs a thicker spacer (I've not seen this however).  We don't have the problem anymore but we still occasionally check if the screws are tight.  And it doesn't take much to strip those screw holes, so don't overtighten.  We found that if we lined up all clips on either the top or bottom channel and popped it in then the other side is very easy to pop in.  Hope this helps :)
Could be....also wiggle the corners slightly.  If it's not secure you'll know.  Best of luck :)
10 minutes ago, johnwen said:
Just my 2 cents...we have an LE2 and had the same problem with one of our shades.  I also thought they were securely fastened until I realized how the metal clips actually held the window casing on.  The backs of the window casings have a recessed channel that accept the metal clips and some were loose or did not protrude far enough into the channels.  Some clips have fiberglass strips beneath them and some don't.  I guess that was a mod Oliver did to get all clips to hold.  The trick for us, after ensuring the screws holding the clips were tight, was to add a strip of fiberglass to a clip, if necessary, to make sure the clip would protrude into the channel far enough to lock in.  So if one doesn't seem to grab then it probably need a spacer.  And if it already has one it's possible it needs a thicker spacer (I've not seen this however).  We don't have the problem anymore but we still occasionally check if the screws are tight.  And it doesn't take much to strip those screw holes, so don't overtighten.  We found that if we lined up all clips on either the top or bottom channel and popped it in then the other side is very easy to pop in.  Hope this helps 🙂
John, That definitely helps. How did you discover the fiberglass spacer, since it was presumably hidden on the back of the clip? I will definitely check this out.
Bob
I also stumbled across a post by @Coddiwomple that provides another nice solution.
In addition to @johnwen's comments regarding the spacing of the bracket from the window frame -
My first inclination was to tighten the brackets to the frame - loose screws and bolts tend to make me believe that things should be tight - but in the case of these blinds this thinking was wrong.  The "spacers" allowed for the bracket screws to be tight but (as @johnwen says) it also allowed for the bracket to be positioned correctly in order to engage the frame of the blinds properly.
Another thought is that since you have already "used" the frame clips multiple times and since these clips were apparently not fully seated in the first place, it is possible that they have lost a bit of "spring" and/or have become slightly collapsed such that they no longer hold as they once did.  The solution for this is either new clips (my favorite) or to try to bend the original clips back into something near the original position (do not try to do this while the clips are on the window frame).  If you are going to be at the 2025 Owner's Rally let me know and I'll bring you a few new clips.  Or, contact Oliver Service and they will send you a couple.
Great points, Bill. Oliver is sending a replacement shade as well as new clips, so hopefully between that and the spacer information we can get the shades mounted firmly. Although, I am really tempted to take @coddiwomple 's appoach. Looks like a very secure way to mount them.
I appreciate your input.
Had similar issues with my Legacy1 trailer. Washboarded roads really puts these connections to the test.
I had Oliver send me some extra clips which I added in addition to the OEM clips. One or two per shade as I recall. I then used thin nylon washers to shim the clips out so they were all in plane and fully engaged the groove on the back of the frame (use a straightedge). Since then, I have also started towing with all shades in the up position (both sheer and blackout pulled up). This puts the drawbars (?) at the top of the shade frame, placing a little more weight at the top of the frame and not stressing out the clips as much. So far so good.
Dave
2015 Oliver Elite 1, Hull 107
  • 7 months later...
We’ve always had one shade that was never seated properly - the one at the aft seat at the dinette. I’d know because I’d lead on it and it would pop on, then pop right off when I un-leaned on it. We found one broken clip and got a “free” replacement when we passed through Hohenwald.
The problem has gotten worse as time went by. We’re to the point that that shade now falls off every time we hit the road. (So I’m taking it off -before- we leave today!)
Upon closer inspection, we found that one channel where the clip snaps into is spread - from pressure and heat I’d guess. Another area of the channel is actually cracked at the “root” of the channel. I tried moving the clips to locations where the channel was still good, but that didn’t really help.
The shade over the curb side bed is now starting to show the same malady.
So - seems some have resorted to “gluing” the shades on with RTV or similar. I was hoping for something a little less permanent and/pr requiring keying the thing off when desired.
My current thinking is some 3M adhesive wire tie mounts - little 3/4” square pads with foam tape on the back. One on the wall by the window, and in on the shade frame. In two or more places around the window. Add a wire tie and it -should- stay in place. Downside: visible and could look jury-rigged.
Looking at the relationship between the window frame and the window shade, a square “U” clip could do the job - if I could find one the perfect size and shape. Guess I’ll look.
Aside from replacing the shade and all the clips - which will likely fail in time just as the original ones have - has anybody found a permanent and esthetically pleasing fix?
  • Wow 2
King Bed Floorplan
electronics package
Truma Aqua-Go
LOUD Dometic Penguin A/C
LevelMate Pro+
RealTruck hard tonneau cover
Rove R2-4K DashCams
We have run into this issue a few times but only on very rough back country roads, ie BLM or USFS roads. Typically before traveling down these types of roads I will take all 3 off their mounts and lay on the king bed in the back. To my way of thinking the clips seem like a poor connection method for this type of application anyway. Seems to me a better method might be a long run of velcro across the bottom, either that or some extremely strong neodymium magnets. I have seen this type of magnet so strong it's virtually impossible to pull apart. Just a thought or two
Legacy Elite II #70
Has anybody been able to source the shade clips besides from Oliver?  And if so, source and part number please?
A couple of years ago I secured a small bag of these clips - probably 20 or so.
Be happy to send you a couple if that is what you need.
PM me with details
PM me with details
Much appreciated.  I also reached out to Oliver and it sounds like they will send me some.  If they don't, I will get back with you directly.
  • 1 month later...
Time for my morning complaint session.
Reached out to Oliver and heard back about the price of the clips plus shipping.  Responded to their email with a request for 10 clips.  Never heard back - that was exactly one month ago.
In the grand scheme of all they probably deal with on a daily basis - not a huge thing. But if they can't deal with the small issues, makes you wonder about the big ones...
As you might remember -
We received a notification here on the Forum about a month ago (maybe two) concerning a change in the way parts, service and the production unit all interact.  While this is still no excuse for "dropping the ball" (particularly on such a small thing) the internal sorting out of new and different responsibilities just might help explain where and/or how the ball was dropped.
Understood.  I know many on this forum have used and had good support from Oliver.  It is situations like this that convince me to try to deal with most things on my own (the Truma AquaGo recall for example).  I'd rather fix it myself if at all possible and within my skill level, plus it's a learning experience.
"Looking at the relationship between the window frame and the window shade, a square “U” clip could do the job - if I could find one the perfect size and shape. Guess I’ll look."
We had issues with the dinette window shade frame falling off too.  We ordered six new clips from Oliver that are more rectangular and fit in the channel much better.  The original ones had a bit of outer flare and didn't seem as well designed for the channel.  The steel is very stout and I couldn't spread the gap enough to get the screw and screwdriver to fit so I took a Dremel and used the tapered stone grinding wheel to just create a big enough opening for both screw and screwdriver.  The attachment now is very snug.  The original clips looked like they would push the window off.
Public "thank you" to @topgun2 for sending me window shade clips that I tried (unsuccessfully) to buy from Oliver.  Very much appreciate the thoughtfulness.  Hope I can return the favor to them (and others) in the future.
