dewdev Posted February 9, 2025 Posted February 9, 2025 (edited) I am in the market to buy a scale to measure my RV tongue weight. What has others bought and are you happy with it? Thanks Edited February 10, 2025 by dewdev 2018 Oliver Elite II, Twin Bed, Hull #354 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
jd1923 Posted February 9, 2025 Posted February 9, 2025 39 minutes ago, dewdev said: What has others bought and are you happy with it? I just purchased this tool. Don't know how to test for accuracy, but it seems to work well. It's well made, small and easy to carry and use. Problem I see is you really need to know tongue weight divided by trailer weight to see if you are in the 10-15% range. 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
dhaig Posted February 11, 2025 Posted February 11, 2025 I also purchased the Shoreline Tongue Weight Scale. It works well and appears to be reasonable accurate. I also weighed our TV and LEII on a CAT scale and computed the tongue weight. The tongue weight reported by the Shoreline scale and the computed weight from the CAT scale were reasonably close, ~500 lbs. I have only measured our tongue weight once with the scale. Unless you make a significant modification or change how you load the trailer, I would not expect the tongue weight to vary much. Given the low frequency of use, I would try to borrow one from a friend, or perhaps rent a tongue weight scale, if one can be found. 2 North Texas | 2022 LEII, Hull #990, delivered 2/17/22 | 2014 BMW X5 35d
dhaig Posted February 11, 2025 Posted February 11, 2025 Correction: The tongue weight scale is Sherline, NOT Shoreline. despite what auto-correct thinks. 1 1 North Texas | 2022 LEII, Hull #990, delivered 2/17/22 | 2014 BMW X5 35d
rideadeuce Posted February 11, 2025 Posted February 11, 2025 (edited) I have this and it works great. Lots of options, comparable to Anderson products. If interested, they have a great weight distribution system that works in tandem with the tongue weight scale as well. It takes the guess work out of weight distribution by utilizing an app and tongue weight scale to help adjust to proper tongue weight. https://www.weigh-safe.com/product/weigh-safe-drop-hitch/ https://www.weigh-safe.com/product/true-tow-weight-distribution-middleweight/ Edited February 11, 2025 by rideadeuce 2 - Mike Brentwood, TN - 2018 Elite II - Spirit of Adventure Hull #308 - 2016 Toyota Tundra Limited 5.7L Class IV hitch with 12k lb coupler, Weigh safe adjustable trailer hitch, Dobinsons HD 2in Leaf springs, Timbren bump stops, Dobinsons 3in coilovers and UCAs, Mechman 370 amp HO alternator. Oliver upgrades: Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp DC/DC charger with Anderson connections, Toshiba 6-in-1 Microwave oven - air fryer combo, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar on top, Custom aluminum bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires, Seabiscuit Metal Designs front storage box and moose rack.
MAX Burner Posted February 14, 2025 Posted February 14, 2025 On 2/11/2025 at 4:20 AM, rideadeuce said: I have this and it works great. Lots of options, comparable to Anderson products. Nice looking piece of kit, for sure. Definitely not a cheap date! 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Jason Foster Posted February 16, 2025 Posted February 16, 2025 I just deadlift mine. If it hurts, it will be fine on my 2500. Seriously, I don't really think too much about tongue weight but I might if I decide to haul it with a half ton like you are. 1 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
