Moderators topgun2 Posted April 1, 2025 Moderators Posted April 1, 2025 FYI - Garmin has released a map update for GPS devices (at least the 890 and the 2797 models). This update must be fair large in that it took about 45 minutes to download and install. Bill 1 7 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Moderators bugeyedriver Posted April 2, 2025 Moderators Posted April 2, 2025 20 hours ago, topgun2 said: FYI - Garmin has released a map update for GPS devices (at least the 890 and the 2797 models). This update must be fair large in that it took about 45 minutes to download and install. Bill Your update took so long because you tasked it with displaying all the best trout holes in the US. 1 3 1 Pete & "Bosker". TV - '18 F150 Super-cab Fx4; RV - "The Wonder Egg"; '08 Elite, Hull Number 014. Travel blog of 1st 10 years' wanderings - http://www.peteandthewonderegg.blogspot.com
Moderators topgun2 Posted April 3, 2025 Author Moderators Posted April 3, 2025 22 hours ago, bugeyedriver said: Your update took so long because you tasked it with displaying all the best trout holes in the US. If Garmin only knew - even you with that Japanese fishing pole might be able to land a couple.😇 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Trailblazers Posted April 3, 2025 Posted April 3, 2025 Thanks for the heads-up. I've got a 780, and it needed a software and map update (estimated time 3 hours). 2 Franklin, TN 2018 Elite II #315 Tow Vehicle: 2020 Ram 1500
rideandfly Posted April 3, 2025 Posted April 3, 2025 (edited) We have a RV780, took about 45 minutes. Updated a few months ago, too. Edited April 3, 2025 by rideandfly Bill 2015 LE2 #75 2024 F350 6.8L
John and Debbie Posted April 11, 2025 Posted April 11, 2025 On 4/3/2025 at 9:22 AM, rideandfly said: We have a RV780, took about 45 minutes. Updated a few months ago, too. Have you found it necessary to have an RV Garmin or is it just superfluous given that Google will give you directions too? I would think it might come in handy to not take you on a road with a low overpass or bridge structure. John John and Debbie, Beaverton, Oregon, 2017 Ford Expedition EL 4x4 3.5 liter Ecoboost, with heavy duty tow package. Hull #1290, twin bed with Truma package (a/c, furnace, hot water heater with electric antifreeze option), lithium pro package, picked up November 7, 2022 Alcan 5 leaf springs and Bulldog shocks done May 20, 2025 in Grand Junction, Colorado
Tom and Doreen Posted April 11, 2025 Posted April 11, 2025 50 minutes ago, John and Debbie said: Have you found it necessary to have an RV Garmin or is it just superfluous given that Google will give you directions too? John I don't have an RV specific GPS but I have been in areas where there was no cellular service, the on-board truck navigation ( based on cellular ), Google maps, and Apple Maps would not work as a result. I'm glad that I had my old Garmin GPS. I would imagine that an RV specific GPS would be helpful. I know that maps can be downloaded and used off-line but I never seem to be able to remember to do that. 1 1 Tom & Doreen • 2023 Elite ll • Hull #1321 • 2023 Tundra Platinum Crew Max • Cheshire CT
Moderators topgun2 Posted April 11, 2025 Author Moderators Posted April 11, 2025 (edited) 19 hours ago, John and Debbie said: Have you found it necessary to have an RV Garmin or is it just superfluous given that Google will give you directions too? I would think it might come in handy to not take you on a road with a low overpass or bridge structure. John - With the relatively low height of the Oliver, I've never had a "problem" with height for overpasses and/or bridges. Since I travel alone a fair percentage of the time, I find that the large screen of the Garmin 890 really helps, plus, I don't use any of my cell phone data with the Garmin. Also, the Garmin will automatically re-route me in the event of an accident or road closure or simply heavy traffic (if it determines that there is a quicker route available). Having said all this - I do also use the Ford Navigation on longer trips. There have been a few times when arriving at an intersection, the Garmin and the Ford do not give the same directions. If I'm not familiar with the roads and/or where I'm headed, I'll usually default to the Garmin. Bill Edited April 12, 2025 by topgun2 spelling 1 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Patriot Posted April 12, 2025 Posted April 12, 2025 (edited) On 4/11/2025 at 1:01 PM, John and Debbie said: Have you found it necessary to have an RV Garmin or is it just superfluous given that Google will give you directions too? I would think it might come in handy to not take you on a road with a low overpass or bridge structure. John John, We have found the Garmin RV 890 to be invaluable on our extended 43 and 48 day trips in the last two years. Super intuitive and my copilot/nav can pull it off the dash mount and quickly look up and map up just about anything CG, site seeing or travel related. We also programmed our trailer height which provides plenty of warning and keeps us off those routes. A nice piece of tech that simplifies our travel experience. I would buy again. Edited April 13, 2025 by Patriot 1 2 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
