T-Oliver Posted April 13 Posted April 13 It's a lovely day in Minnesota, so I decided to reintall the Epoch batteries.  This is the wire arrangement that I came up with. What could be improved or what is absolultly wrong? 3
jd1923 Posted April 13 Posted April 13 (edited) 44 minutes ago, T-Oliver said: What could be improved or what is absolutely wrong? Looks good to me! I moved our 6 AWG cables inside, but I do like the extra terminals you added. Only detail it's better to connect the + cables first and lastly connect the final ground. This way you cannot accidentally short the + while connecting. Not a change in wiring, just your order or assembly. You should add a heat shrink and optional wire loom to the main positive cable like you did the others. Ours is very similar. Both arrangements work fine since the main positive is connected to one battery and the main negative is on the other. Edited April 13 by jd1923 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
ADKCamper Posted April 13 Posted April 13 Looks good! Sure wish I could fit 2x Epoch 300Ah into the Elite I battery tray... Maybe someday Epoch will come out with a slightly smaller 200Ah Essentials battery such that 2 of them would fit side-by-side into the Elite I battery tray, and with no height issues. Tom & Holly 2018 Oliver Legacy Elite #409 - 320W rooftop solar, 300Ah Epoch LiFePO4, Victron Smart Solar MPPT 100/30 charge controller, PD4060CVS 60Amp Lithium-capable Converter, Xantrex PROwatt SW 2000 inverter;Â Tow Vehicle: 2017 Silverado 1500, 5.3L Gas, 4x4 Z71, Dbl Cab, Std Bed. Â Â Â Â
T-Oliver Posted April 13 Author Posted April 13 All buttoned up, with the exception of the temperature sensing wire. I got rid of all the split loom in battery compartment. The Blue Sky Solar seems to remember it's settings, making it a good day! 2
jd1923 Posted April 13 Posted April 13 (edited) 1 hour ago, T-Oliver said: All buttoned up, with the exception of the temperature sensing wire. This is as clean an installation as I've seen! đ Excellent work. I didn't bother with a temp sensor wire. As per the Epoch manual: Wide Temperature Range Engineered to perform reliably across a broad temperature spectrum, it operates effectively from -20°C to 60°C (-4°F to 140°F). Integrated Heating System The built-in heating system enables charging in cold conditions, safeguarding the cells and ensuring battery efficiency in freezing temperatures. But then again, we do not live in Minnesota (nor would plan a winter visit).Â đ€Ł We will be traveling through your area this June though. Where we live and travel, we could never possibly be outside of this very wide temperature range. You go Epoch! Edited April 13 by jd1923 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
T-Oliver Posted April 14 Author Posted April 14 The temperature sensor is scheduled for removal, as the BMS tells temperature. The weather has been unpredictable this year (50s followed by 20 below zero. The BMS does shut down in the cold, the batteries clicked off just as we got home from Florida.
johnwen Posted April 14 Posted April 14 Another way...I went with terminals on opposite ends. No particularly good reason. John  1 Oliver II #996 "Bessie", 2019 Silverado LTZ 5.3, Veterans https://wenandjohnsadventure.com/
Moderators topgun2 Posted April 14 Moderators Posted April 14 15 hours ago, T-Oliver said: The weather has been unpredictable this year (50s followed by 20 below zero. WOW!  I've never actually seen RV antifreeze - FREEZE. Nor do I want to ever see it freeze. Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Patriot Posted April 14 Posted April 14 22 hours ago, T-Oliver said: All buttoned up, with the exception of the temperature sensing wire. I got rid of all the split loom in battery compartment. The Blue Sky Solar seems to remember it's settings, making it a good day! Very clean install, well done! 1 2020 OLEII - Hull #634 aka-  âXPLORâ TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - âBeast of Burdenâ Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina đșđž Â
