Nick and Linda Stratigakis Posted April 29, 2025 Posted April 29, 2025 Currently on a trip.last night I discovered that the water valve is leaking . Understand I will have to replace the valve and found one in Amazon. My question is how hard is to remove the old one and replace with a new one .seems the kit includes everything I need. thank you for any guidance or suggestionsÂ
Galway Girl Posted April 29, 2025 Posted April 29, 2025 (edited) This you tube shows the trick is getting one screw (that's very hard to see on the back) removed before trying to pop out the valve.  See the 2:12 Mark on video...easiest to use a 1/4" socket to remove screw.]\  Edited April 29, 2025 by Galway Girl 1 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG:  https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine in Aug 2024 on way to Nova Scotia. Â
Nick and Linda Stratigakis Posted May 1, 2025 Author Posted May 1, 2025 Thank you for the recommendation of using a 1/4â socket. It made my work much easier. 2
SNY SD UP Posted May 9 Posted May 9 It appears as though I have some issues with my winterizing skills.  That said we are chasing leaks, currently, this one out of the back of a Dometic (310/311, does the model number make a difference) for the "Water Valve Kit". The leak is coming out of the back of the "Water Valve Kit", just a slight dribble, but enough to be worrisome whilst spilling onto the shower floor. I watched the video provided by Craig and "I can do that!!!" I would like to remove the valve and examine it, to see if something on it is cracked or worse yet further up in the toilet. I am going to see if it can be found locally, if not the AMZN... 1 1 Maggie & Bryan | Arnegard, ND | 2020 LE II "Twins" Hull #665 | 2021 RAM 2500 6.4L HEMI Gasser 4dr 6.5' bed  Â
SNY SD UP Posted May 10 Posted May 10 (edited) I was able to remove the valve assembly and examined it. This is before i found the following in a Dometic Manual i had "IMPORTANT: Toilet warranty does not cover freeze-damaged water valve The Dometic 310 and 320 series toilet warranty expressly excludes coverage for any damages to the toilet or vehicle that may occur as a result of improper winterization of the toilet. An indicator of improper winterization is freeze damage to the water valve which results in leaks. Dometic 310 and 320 series toilet water valves exceed maximum water pressure as defined by North American plumbing code agencies. However, if trapped water freezes in piping that supplies water to the toilet, it expands and creates extremely high pressure that can damage the valve (see photo). To avoid this, winterize the toilet as described in this manual. If freeze-damage occurs as a result of improper winterization, replace the water valve with a 300/310/320 toilet water valve kit, part number 385311641. IF WATER VALVE IS RETURNED FOR WARRANTY CLAIM, DOMETIC RESERVES THE RIGHT TO DENY CLAIM IF PROBLEM IS CAUSED BY FREEZE DAMAGE. " Unquote... Fig. 6 A â Freeze Damage Indicator Window: white stress marks indicate freeze damage B â Water valve damage due to severe exposure to below-freezing temperature" a 1/4" Nut-driver works just as good as a 1/4" socket on removing the screw from the back (refer to video). this looks like it may be the issue, just not as bad, before i reinserted the flush valve.  so i believe we have freeze damage to our flush valve. I'll try to source locally before ordering off AMZN, as it will travel by steamship up the Missouri, then by train, stagecoach, and finally by "Dray" Delivery. There is no AMZN Next or One or Two-day up here. but they are more than willing to charge you for it.  Edited May 10 by SNY SD UP 1 2 1 Maggie & Bryan | Arnegard, ND | 2020 LE II "Twins" Hull #665 | 2021 RAM 2500 6.4L HEMI Gasser 4dr 6.5' bed  Â
Moderators topgun2 Posted May 10 Moderators Posted May 10 I guess that it does "pay" to read those manuals? What? Y'all ain't got no Pony Express over there in Missoura?  đ Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
SNY SD UP Posted May 10 Posted May 10 Bill, if we lived in "Missoura", we might have the part in a day or two... However, we are in West Central North Dakota,,, when I track orders, usually it is "UPS", it may say "out for delivery" for a couple of days until it arrives. Not to say the rural lifestyle does not have its advantages.  Our nearest (one i have had the best luck with) RV service center is about 360+mi & 6hrs R/T. However, a google search now shows an RV service center in Williston ND. Tomorrow when they open, and if they have the part... i will head north 90 miles r/t to buy it, and while there evaluate their Service Center.  B~Out   2 Maggie & Bryan | Arnegard, ND | 2020 LE II "Twins" Hull #665 | 2021 RAM 2500 6.4L HEMI Gasser 4dr 6.5' bed  Â
Moderators topgun2 Posted May 10 Moderators Posted May 10 1 minute ago, SNY SD UP said: if we lived in "Missoura", we might have the part in a day or two... Sorry about that - I should have checked before I opened my mouth đ”âđ«. Or, I should read better in that you were referring to the Missouri River - NOT the State. In any case - While I too live in a fairly "rural" area it is not quite as "out there" as you are. If it helps (I really doubt this) I too have had "issues" with deliveries. Just this past week a new pair of hiking boots that were supposed to be delivered in 3 to 5 days actually took almost three weeks! Of course I agree with you in that the rural lifestyle does have its advantages - the bear walking through the yard this morning and the bobcat last week. Heck, I was stopped at a traffic light the other day as the 4th vehicle back and complained that we now have "traffic jams"! Bill  2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
SNY SD UP Posted May 10 Posted May 10 (edited) no problem.  B~Out Edited May 10 by SNY SD UP Maggie & Bryan | Arnegard, ND | 2020 LE II "Twins" Hull #665 | 2021 RAM 2500 6.4L HEMI Gasser 4dr 6.5' bed  Â
SNY SD UP Posted May 13 Posted May 13 (edited) The Dometic "Flush Valve Kit" arrived by pony express (3 days) and I installed it late last night. It is the proper part for our model of toilet. However, during re-assembly when I inserted it into the back of the toilet, it did not âClickâ as mentioned in the Video or Forum comments.  I pressed it in the best I could, but no âCLICKâ, removed it and re-inserted the old one and âClickââŠÂ re-inserted new one, no "CLICK".  I did however add the âsecond screw as was suppledâ, so now I have (2) screws holding the âFlush Valveâ in place. And what is with the worm gear clamps (existing & supplied), the heads are not 1/4 or 5/16's, sheeez but I did snug them up tight. This morning I will look for any subtle differences between the old and new Flush Valve. And I still have a very slight drip coming out of the back of the toilet where the âFlush Valveâ insertsâŠÂ  I believe I have a work-around, in that I found out where I will re-locate Willisâs water dish.  Maggie was not impressed.  B~Out   Edited May 13 by SNY SD UP 1 2 Maggie & Bryan | Arnegard, ND | 2020 LE II "Twins" Hull #665 | 2021 RAM 2500 6.4L HEMI Gasser 4dr 6.5' bed  Â
jd1923 Posted May 13 Posted May 13 2 hours ago, SNY SD UP said: The Dometic "Flush Valve Kit" arrived by pony express (3 days) and I installed it late last night. It is the proper part for our model of toilet. However, during re-assembly when I inserted it into the back of the toilet, it did not âClickâ as mentioned in the Video or Forum comments.  I pressed it in the best I could, but no âCLICKâ, removed it and re-inserted the old one and âClickââŠÂ re-inserted new one, no "CLICK".  I did however add the âsecond screw as was suppledâ, so now I have (2) screws holding the âFlush Valveâ in place. And what is with the worm gear clamps (existing & supplied), the heads are not 1/4 or 5/16's, sheeez but I did snug them up tight. This morning I will look for any subtle differences between the old and new Flush Valve. And I still have a very slight drip coming out of the back of the toilet where the âFlush Valveâ insertsâŠÂ  I believe I have a work-around, in that I found out where I will re-locate Willisâs water dish.  Maggie was not impressed. B~Out By Pony Express do you mean Amazon? Are you sure it is a Dometic brand part. I'm with you in wanting to hear the 'click' like the original part. If not Dometic brand, time for another Amazon return and get the part from eTrailer, Camping World or some legit RV store. https://www.etrailer.com/Accessories-and-Parts/Dometic/DOM93FR.html A lot of hose clamps these days have 7mm screw heads. 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
SNY SD UP Posted May 14 Posted May 14 issue resolved. We bought a Genuine Dometic Water Valve, it is now installed and working as designed. 3 Maggie & Bryan | Arnegard, ND | 2020 LE II "Twins" Hull #665 | 2021 RAM 2500 6.4L HEMI Gasser 4dr 6.5' bed  Â
SNY SD UP Posted May 14 Posted May 14 Do not buy a "Lippert" replacement part. Sales ppl will say it is a match, but it is not. Tech will say put in the 2nd screw and it will stop that leak. maybe-maybe not. As the ppl at carnivals (not to disparage any OTT owner who has done that) would tell this 10-year-old who just spent his $5 on basketball, ring toss and water pistols, in the midway, "Close, but no cigar, Son"... The upside, I may have found an authorized Dometic dealer to work on our awning... just not before we head-out. B~Out 2 Maggie & Bryan | Arnegard, ND | 2020 LE II "Twins" Hull #665 | 2021 RAM 2500 6.4L HEMI Gasser 4dr 6.5' bed  Â
