ScottyGS Posted June 21 Posted June 21 4 hours ago, Geronimo John said: We laid out the gutter in HOT Florida sun I said "Summer Day".... not Nuclear Winter in FL! :-) 1 Gregg & Donna Scott and Missy the Westie - The Flying Sea Turtle - 2016 Hull # 145 2024 Nissan Titan XD - Western NC
routlaw Posted June 27 Posted June 27 We've had rain off and on since last night and a sizable downpour mid morning, so with new weather stripping gaskets installed on the windows thought it would be a good time to see how well they have performed. Initially no leaks a good thing given the amount of rain. Brought out my portable wet/dry vac and vacuumed all the weep holes and ended up with around 6 oz of water collected from the windows. IOW's the new gaskets did little to nothing to stop infiltration. Photo posted below to illustrate the amount of water collected. Water was poured into a measuring cup to verify amount. Until this point there were no leaks inside the trailer, but it kept raining. This afternoon I checked again and sure enough a small leak had started to occur on the street side rear window. Not enough to be a major issue yet but the fitted sheet had a wet spot about 3-4 inches in diameter. Weep holes were not emitting or leaking water which was no surprise. The tracks have been cleaned twice in the last month alone. The upside down weep holes at the top of the frames have been plugged all to no avail. The new installed gutters do avert water running down the side of the trailer but offer no benefit from rain hitting the windows directly. I can't imagine living down south where torrential downpours are normal and putting up with this. I'm at a loss for how to deal with this going forward. Thanks Legacy Elite II #70
DavePhelps Posted June 27 Posted June 27 I posted this pic a couple years ago in another leaky window thread. Those weep slots are just not up to the task of keeping water from building up in the tracks (capillary attraction really hinders water flow). Folks talked about using pipe cleaners and lantern wicks to help wick out the water (maybe they work as well) but I find that 1/8" paracord works great. Cut some 3" lengths and stuff them in the slots. It's amazing how well they work! Don't heat seal the ends! Easy to replace and everyone has some paracord around right? Some may think it's kind of ugly looking but better than a wet bed! Cheers, Dave 3 2015 Oliver Elite 1, Hull 107 2025 GMC Sierra HD 2500 AT4, 6.6 L8T (gas)
routlaw Posted June 28 Posted June 28 Dave I remember seeing that photo in the past. For me the pipe cleaners do next to nothing unless I go out and manually pump them back and forth which will remove quite a bit of water from the weep holes. On one window I have enlarged the weep holes, curb side rear, and that window seems to consistently have much less water in the channels and doesn't tend to leak either. I have never heard of paracord though, what the heck is that? Will have to look into this. Thanks Legacy Elite II #70
Katy McAnarney Posted June 28 Posted June 28 We had a torrential downpour last weekend and had the rear emergency window leak terribly. Both beds wet a good deal. We ended our trip early and came home. I did not use pipe cleaners in the weep holes. I will do so now. I've cleaned and replaced the original molding on the outside about 1.5 years ago. Upon inspection of the gutter and molding on the emergency exit window, the gutter the window slides on was brittle and about rotten. I opened a ticket with Oliver and I received a response with step by step instructions on how to replace the gutter after cleaning the trays. This included removing the window pane. So we did that. Cleaned everything up, replaced the gutter and replaced it with a product from the company Oliver suggested, steelerubber.com. The gutter is one, continuous running piece, that starts at the street side bottom and runs to curb side, up and then over the top of the window and terminates at the top street side. Everything has been done and the new track gutter fits perfectly. But, now we cannot get the window back on track. I've tried just about everything. I've even swung the window outwards hoping to be able to clearance over the shade track to re-seat the window panes on the track. Didn't work. I've tried putting the gutter around the window first and then popping the window back in. Again, couldn't get the window pane over the last steel rim to seat it into the track. The idea being putting in the top part of the pane first, and the pushing it up and seating the bottom. I cannot get clearance over the trim of the window frame. It lacks probably 1/8 of an inch. I even attempted to put the old gutters back in, thinking the new gutters were too thick. I compared the two pieces side by side and they are exactly the same thickness, but that didn't work either. I'm so frustrated. Any suggestions would be appreciated. 2021 LE II, twin bed set up, Hull #920, La Dame Blanche
routlaw Posted June 28 Posted June 28 @Katy McAnarney welcome to the dysfunctional Oliver window club but sorry you are having this issue like so many of us. This is how I have re-installed the sliding window with either new or cleaned and refurbished gutter track. First put the siding window into its channel without the rubber track. Coat the rubber track with silicone and wipe off excess. Position the sliding window approximately half open/closed and gently start feeding the rubber track into the bottom of the channel and below the sliding window first. You will only get so far, then start to close the window part way, hold the rubber track against the sliding window then start to push open again as far as it will go. Repeat this back and forth process for a few efforts until the rubber track appears on the far side of the sliding window at which point you should be able to grab the rubber track and pull the it through as far as it needs to go. Open the window all the way and feed the rubber track into the remaining channel along the bottom then up the vertical side and into the top leaving several inches of dangling rubber track. At this point you will need to slide the window forward into a partially closed portion so that you can repeat what was done on the bottom channel. This will also take a few passes to complete. It will be virtually impossible to do this without the use of silicone. The rubber alone just has too much friction. Once you get the hang of it the process will go much easier in the future. I don't think it is possible to do this with the rubber track already installed. The silicone allows for very easy back and forth maneuvering of the rubber track and window. It's far easier to start on the bottom rail first before the top. Hope this helps 2 Legacy Elite II #70
DavePhelps Posted June 29 Posted June 29 10 hours ago, Katy McAnarney said: I did not use pipe cleaners in the weep holes. I will do so now. I would personally stay away from the pipe cleaners. My main worry is the wire core might rust and streak your trailer. Paracord for the win! Its kernmantle construction wicks water very well. Google it! It also has tons of uses around camp. I think most every hardware store carries some form of it. Get the 1/8" version. Paracord Planet is a good online resource, I think they have an Amazon store.... Dave 2 2 2015 Oliver Elite 1, Hull 107 2025 GMC Sierra HD 2500 AT4, 6.6 L8T (gas)
routlaw Posted June 29 Posted June 29 Bought skein of paracord today and confirm @DavePhelps suggestion this stuff works, way better than the pipe cleaners. Immediately it was obvious the cord was wicking water out of the weep holes. Very Effective solution. Thanks 1 Legacy Elite II #70
Galileo Posted June 29 Posted June 29 On 5/26/2025 at 12:41 PM, jd1923 said: Now we could wish for blinds 3/4” thick vs. these clumsy things that stick out 3” into our living space, my big body or arms hitting them every night, and you can't fully lean back sideways at the dinette table. We don’t, though some have issues with them falling off on bumpy roads. Edited May 26, 2025 by jd1923 Amen to that! We have one that likes to fall off - but it gives my wife and I something to bet on at the end of each trip before we set up the trailer. “Do you think the window shade fell off?!” I find that the one prone to falling off has cracks in the channel in the back where it “snaps” over the U shaped metal clips. You may want to try moving the clips up different locations if you find yours are cracked as well. They are more than a bit clunky - so if/when they start to fall apart, I’ll certainly look for other options. Perhaps “old fashioned” curtains have some merits after all. As for the windows themselves - I’ve just resigned myself to the fact that they’re about useless if it rains - at all. I haven’t delved into awnings or other devices to keep water from hitting the screens if the window is open. I also never leave the Girard awning extended when we’re gone, at night, if it’s windy, or in heavy rain. As @TimD discovered - the black, plastic inner “track” or guide the windows slide on isn’t (easily) removable from the frame. I’m sure there’s a way, but I haven’t gotten that ambitious yet. It turns out our leak wasn’t really due to fuel or clogged weep holes or drains. It was the screw that hold the window stop in place. The little plastic “foot” that keeps the window from sliding too far open-forward. The knucklehead who decided it would be a good idea to drill a hole in the bottom of the window frame is OFF my Christmas list. Happily, some sealant on that screw seems to have remedied the leak. 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
jd1923 Posted June 29 Posted June 29 19 minutes ago, Galileo said: We have one that likes to fall off... I believe there are 4 clips holding each blind. Bend them very slightly to tighten the hold on the shade! 😎 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Galileo Posted June 29 Posted June 29 (edited) 6 minutes ago, jd1923 said: I believe there are 4 clips holding each blind. Bend them very slightly to tighten the hold on the shade! 😎 I think I mentioned that the actual channel on the back side of the shade is cracked and doesn’t give the clip much to hold onto. Moving the clip to an untracked area helps - but once an area of the channel is cracked, it’s easy for the crack to spread to adjoining areas. So the clip needs to be moved more than one screw away on the window frame. I actually did try to bend the clip. Unfortunately, it’s pretty stout spring steel - so that didn’t work. One of ours was actually broken and half missing upon delivery - probably from either attempts to re-form it, or just whacking the window shade too hard when it was initially installed. Not surprisingly, that’s the shade with the cracked channel that likes to fall off. Edited June 29 by Galileo Bad typing 1 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
routlaw Posted June 29 Posted June 29 44 minutes ago, Galileo said: As @TimD discovered - the black, plastic inner “track” or guide the windows slide on isn’t (easily) removable from the frame. I’m sure there’s a way, but I haven’t gotten that ambitious yet. It turns out our leak wasn’t really due to fuel or clogged weep holes or drains. Actually there is a way to easily remove and re-install those black tracks. Read my post above that describes I think well enough how to do this. Is it a PITA that any of us shouldn't have to do, yes, but once you do this a time or two it becomes fairly easy. Good that you figured out your leak. Your windows seem to be different than ours given your description of that stop bumper screw. Our windows have yet another type of rubber seal installed on the track that acts as a bumper when sliding the window open. I've said it before but it's worth repeating, imagine buying a new truck or auto and having to put up with this terrible flawed design of a window. And yet these are installed by the hundreds of thousands on US made RV's of all brands. All that out of the way the paracord is on an order of magnitude better at wicking water out of those weep holes compared to anything else I have tried other than the wet vacuum. Legacy Elite II #70
Galileo Posted June 30 Posted June 30 5 hours ago, routlaw said: I’ve said it before but it's worth repeating, imagine buying a new truck or auto and having to put up with this terrible flawed design of a window. No need to imagine. My previous tow vehicle had an engine harness wiring that ran too close to an exhaust heat shield. At precisely 1,000 miles after warranty, the heat shield wore through the wiring harness and shorted out a fuel injector. I’m just lucky it happened within easy motor club towing distance of a dealer. (“Lucky” if you call having to change camping reservations at the last moment, rent a car, and fork over $500 for the repair.) Still, I guess I should count myself lucky that it happened in a city rather than the narrow, winding mountain roads I was driving with the trailer the week before. Anyway, it seems that just as with everything else, we’re often beta testers for the things we buy. If stuff holds together for the first couple of years, you’re basically in your own. 2 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
jd1923 Posted July 11 Posted July 11 On 6/29/2026 at 3:55 PM, Galileo said: I actually did try to bend the clip. Unfortunately, it’s pretty stout spring steel - so that didn’t work. Yeah, I tried this today and you are correct. I hosed our blinds this week with a fine mist spray setting. I did this 2 years ago and it was about time again. When I reinstalled I found a couple of clips where the mounting screw needed tightening, so check for this first. Then of all the 24 clips, 6 per window, only one would not seat properly (guess we're lucky). I removed it, tried to stretch it wider on my vise and no-go on the spring steel. So this is my solution and it worked great, tight as can be! just one wrap of electrical tape. 😎 1 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
John Dorrer Posted July 11 Posted July 11 On 6/27/2026 at 7:21 PM, DavePhelps said: I posted this pic a couple years ago in another leaky window thread. Those weep slots are just not up to the task of keeping water from building up in the tracks (capillary attraction really hinders water flow). Folks talked about using pipe cleaners and lantern wicks to help wick out the water (maybe they work as well) but I find that 1/8" paracord works great. Cut some 3" lengths and stuff them in the slots. It's amazing how well they work! Don't heat seal the ends! Easy to replace and everyone has some paracord around right? Some may think it's kind of ugly looking but better than a wet bed! Cheers, Dave They do the job on our trailer. John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Galileo Posted July 11 Posted July 11 17 hours ago, jd1923 said: Yeah, I tried this today and you are correct. I hosed our blinds this week with a fine mist spray setting. I did this 2 years ago and it was about time again. When I reinstalled I found a couple of clips where the mounting screw needed tightening, so check for this first. Then of all the 24 clips, 6 per window, only one would not seat properly (guess we're lucky). I removed it, tried to stretch it wider on my vise and no-go on the spring steel. So this is my solution and it worked great, tight as can be! just one wrap of electrical tape. 😎 I think I mentioned in a previous post that the shades staying tightly attached to the frames is dependent upon two things: The clips The channels on the back side of the shades On our problem child shade, one of the “fins” molded into the plastic frame of the shade is cracked. So there is no firm channel for the clip to snap into. I attempted to remedy this by moving the clip to a different position behind the shade. Unfortunately, once the crack on that fin is started, it creates a stress point that causes the crack to grow and extend to wherever force from the clip is applied. If the clip can be moved far enough away from the crack, you -may- solve the problem at least for a while. Though the shade doesn’t -always- fall off while towing, to make it stay up reliably, another method to hold the shade to the window frame is required. 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
