Ronbrink Posted September 8 Posted September 8 (edited) I have repeatedly stated how the Cielo Breez Max thermostat is effective in resolving inherent humidity spikes due to the a/c supply fan running continuously in the Oliver. This particular device has a Comfy Mode feature that will turn off said fan in sync with the compressor and thus, significantly lessen moisture from being reintroduced back into the cabin space. I would like to share the results of a test performed yesterday as tangible proof of its effectiveness: As I rolled up to the COW Barn with my Starlink Mini’s new Standby Mode unpaused (low-speed data plan), the Cielo phone app was used to start the Drieha Atmos 4.4 from my vehicle to begin cooling. I spent about twenty minutes reorganizing inside the van before opening up the CB and entering the Oliver. I should mention we had a temperature drop from the day before, so not real hot (83°), but relative humidity was high (72%) (P1). The Atmos was still cooling in Comfy Mode (preset to turn off when temp falls below 76° and turn on when temp goes above 77°) and the Oliver was 77°/49% (temp/humidity) at entry per the Cielo’s display (P2). A few minutes later the Atmos turned off in total (supply fan and compressor), the display was 75°/45% (P3). As the interior temp increased the Atmos turned back on in total, the display was 77°/51% (P4). It is important to note that the humidity rose 6% during this total off period. The Atmos then turned back off in total, the display was 75°/47% (P5) with a 4% drop in humidity. I let the Atmos continue to cycle in like manner a while longer before switching from Cielo to remote operation (P6) set at 75°. Since the Cielo can still be used to monitor temp/humidity, at time of remote start the display was 75°/52% (P7) and the compressor shutdown soon after (supply fan continued to run). When the compressor came back on, the display was 76°/75% (P8). Yikes, a 23% spike in humidity! The compressor shutdown once again, the display was 75°/53% (P9) and back on again, the display was 76°/74% (P10); a 21% spike. Compressor off at 75°/53% (P11), on at 76°/72% (P12); a 19% spike. As demonstrated, it is evident that the Cielo’s Comfy Mode does in fact lessen those dreaded humidity spikes experienced at times, you be the judge! Edited September 8 by Ronbrink 1 4 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
CRM Posted September 8 Posted September 8 Nice! Looking forward to installing a Cielo Breez Max along with the Greenland Turbro unit that I'll be installing soon. Thank you for making us all aware of this thermostat and it's capabilities! 4 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
Treasure Coast Vault Posted September 9 Posted September 9 @Ronbrink I get the same results using the Cielo in my garage with a mini split. Always had humidity spikes in there. Thanks for showing us the Cielo. 2
jd1923 Posted September 9 Posted September 9 21 hours ago, CRM said: Nice! Looking forward to installing a Cielo Breez Max along with the Greenland Turbro unit that I'll be installing soon. Good to know and we're looking forward to your build thread! 😎 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
CRM Posted September 9 Posted September 9 6 minutes ago, jd1923 said: Good to know and we're looking forward to your build thread! 😎 Just need to get my Ollie back first... right now my brother is using it as temporary housing. Loves it so much he's planning on buying one himself. 3 1 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
