On 11/27/2025 at 9:17 AM, taylor.coyote said:
No tv at all in our OLEll. We have Starlink for communication and can get tv content on our laptops if desired.
Can the Starlink Mini II transmit TV on two different chanels at one time to two laptops?
Learning more the easy way!
Thanks
Thanks
The SL Mini doesn’t transmit TV, it provides internet connectivity so the user can stream whatever his device is capable of streaming.  Carol and I are sometimes both on our iPads streaming different video content from the SL Mini.  Mike
Sure!  Each laptop is working independently so it only comes down to the internet "Bandwidth," which simply means how much data can be transmitted over time.  Typical Starlink connections are very fast, usually greater than 100 Mega bites per second (Mbps) so you can easily stream video on more than one device at a time.  That's why trailer park internet can be so slow; the more users means less available bandwidth.
Thanks Mike.  It is obvious I am a Mechanical Engineer.  Fortunately June is a Masters Electrical Engineer and a IT Professional.  So I'm the slow one in the gizmology world of these type of machines.  But power I do get!.  Gathering the base level info lets me ask less stupid C.S. questions though.
Many thanks for your posts!
Edited by Geronimo John
typo
Thanks
When ‘inquiring minds want to know’, ask AI!
My question: Will the Starlink Mini support use of two laptops streaming TV content?
AI response: Yes, the Starlink Mini can support two laptops streaming TV content simultaneously, and often even more devices. The built-in Wi-Fi router is designed to handle up to 128 devices, and real-world tests show it works well for multiple streaming sessions.
The main factor influencing performance will be the available bandwidth at your specific location and time of use, as speeds can vary.
Performance and Considerations
  • Speed: The Starlink Mini typically delivers download speeds over 100 Mbps, and users have reported speeds over 200 Mbps in optimal conditions. This is more than enough bandwidth for two simultaneous high-definition streams.
  • Reliability: While generally reliable, speeds may temporarily decrease during peak network times or due to minor obstructions, which could cause a brief glitch in a stream. However, in most scenarios, users report no issues with multiple concurrent streams.
  • Data Usage: Be mindful of your data plan. The Roam 50GB plan has a data cap, and streaming TV content consumes a significant amount of data. The Unlimited plan may be more suitable for frequent, heavy streaming use.
  • Built-in Router: The Mini has an integrated Wi-Fi 5 router, which is sufficient for a campsite or small area. If you plan to be further away or want maximum performance, some users suggest adding an external hardwired router.
Edited by Ronbrink
2020 OLEll, Twin, 579:
Our Experience with the Starlink Mini is the same as Ronbrink. We traveled for many years with an ATT NetGear portable cellular hub but have repalced the NetGear with Starlink. We spend a good part of time off the grid and Starlink provides service everywhere except when you have abstructions such as trees between you and the satellite. The ATT NetGear is great device, it's portable, simple and easy to use. If we didn't spend time off the grid, we would likely stay with the ATT NetGear hub. With an ATT  business account our NetGear plan was $65 monthly (+ buying it over time as with cell phones) with unlimited data use.
Edited by taylor.coyote
typo
Fieldbrook, Ca
