Mountainman198 Posted November 30, 2025 Posted November 30, 2025 I am on my fourth (and hopefully last) mattress for my twin bed E2. Each version was a improvement over the prior and so far v.4 has all of the attributes I was looking for (easy to move mattress to access valves under bed, firm base so bed can be used for sitting during the day yet soft enough to be comfortable for a side sleeper). If the deep memory foam mattresses work for you thats great. Consider this an option for those of us who want something firmer yet easy to move to access the hatches beneath the bed v.1 was the standard cushions. Not comfortable for side sleeper v.2 was a 4” thick air mattress on top of standard cushion. This was firm but with a dog and cat quickly sprung a leak and I was back to v.1 v.3 was a custom cut innerspring mattress with a 30” wide Hest foamy topper. This worked great but after two years of travel the mattress developed sagging tendencies and since it was radiused in only one corner it could not be flipped or rotated v.4 is a hest sleep system (30” wide) which features a inflatable base made like a inflatable stand up paddleboard with chambering so that it inflates perfectly flat. The 2-3” thick memory foam topper is attached to the inflatable base, which once inflated in place is secure but is easily flipped-up as a single unit to access the hatches beneath the bed. v.4 has only been tested a few nights but will soon be on the road for 2.5 months of daily/nightly use. Will report back with updates 2 2021 Elite II, Hull# 898 2018 Toyota Tundra, 2003 Dodge Ram 3500 5.9l SRW
dewdev Posted November 30, 2025 Posted November 30, 2025 We have KTT mattress. It is very comfortable, but is heavy to move around. 1 2018 Oliver Elite II, Twin Bed, Hull #354, new Lithonics batteries and Xantrex Freedom XC 3000 Pro Inverter in 2025 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
Moderators SeaDawg Posted December 1, 2025 Moderators Posted December 1, 2025 This one? https://a.co/d/47jQ7XM 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Mountainman198 Posted December 1, 2025 Author Posted December 1, 2025 1 hour ago, SeaDawg said: This one? https://a.co/d/47jQ7XM That’s it 2021 Elite II, Hull# 898 2018 Toyota Tundra, 2003 Dodge Ram 3500 5.9l SRW
Ronbrink Posted December 1, 2025 Posted December 1, 2025 17 hours ago, dewdev said: We have KTT mattress. It is very comfortable, but is heavy to move around. I too have the KTT twin bed mattresses; and yes heavy, but manageable. I simply stand them on edge when securing the fitted sheets with Bed Scrunchies or to access the hatch areas, I use the hatch doors to prop them up. I also place them on edge when in storage to prevent mildew. 2 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
jd1923 Posted December 5, 2025 Posted December 5, 2025 We had the KTT mattresses which on our very first trip seemed uncomfortable, too soft and too difficult just to sit up in bed to watch TV. We have Brooklyn Bedding and home and went with two of these" https://rvmattress.com/products/brooklyn-wanderlust-memory-foam/rv-bunk-30x75-12-inch I went with the 12" for its 3 layers of foam and medium firmness. They are very heavy and 12" is really too tall! Added Bonus: at this height our old dog Charley can't jump up on the beds anymore! (He has his own bed.) We opened the stitching on a corner seam and with an insulation knife cut a 14" radius to fit. They have the 30x75" size in several mattress heights. As far as lifting beds. Stop doing that! We use our boondocking port almost every time out. When I'm ready outside, Chris just throws two switches under the bed to refill the FWT from the backup water tank in the bed of our truck! OTT should read the below post for new design ideas, but who cares about what comes in a new Oliver anyway? Not me, now that this has been corrected! Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
