There are a number of "install" threads here on the Forum where owners have installed a "clear" glass (usually tinted to match the other windows in the Ollie plus a blind that can be operated from the interior without opening the door.
Many of us have used THIS GLASS and BLIND
Note that if you want this AND you want a white interior handle you will need to call the company direct and ask for the white handle.
Read my posts in this thread. I used a Lippert tinted glass insert because the door is a Lippert. Be sure to get the frame release clips and a new inside and outside frame because you will break some tabs while removing the frames. The new frames will also have new intact seals.
After installing the clear tinted glass I wanted a blind that could be operated without having to open the screen door. I had a friend that sews make me a blind out of heavy curtain material and used 2 spring rods to position the blind in the screen door frame. The top spring rod can be lowered to allow a viewing area at the top.
Edited by Townesw
Bill and Martha
2019 Chevrolet 2500HD Duramax
On 3/19/2026 at 5:39 PM, DavePhelps said:
I replaced my Opaque door glass with a clear tinted one from Zarcor.
Really like it. Make sure to order the glass specific to the door used on your Oliver.
There were changes made over the years that affect the glass specs.
Their Airstream shades also have my attention....
https://www.zarcor.com/rv_products/rv-door-window-kit/spare-parts.php
Dave
Do you have (share) the part numbers of the window and any additional items to order to complete the project?
Thanks.
Thanks.
Just in case no one looked at Zarcor's website, the glass sold there is a Lippert product for their doors.
My older Oliver Lippert door (2015) used screws to hold the window trim and the glass in place (along with some butyl weatherstrip).
The newer doors use clips which complicate the switch but is still very doable. There are a few Youtube videos out there which I would advise watching if your door uses the clip system.
Thanks.
The window I used from Zarcor was
Tinted Glass, Lippert Style A, Valterra Style C
Glass size: 21 7/16" × 12 7/16", Fits frame style A
I would call them with your door information and they will set you up. The kit comes with the glass and butyl so nothing else to buy except maybe some spare clips if your door is that style, I've read that they can sometimes break during disassembly.
Good luck!
Cheers,
Dave
2015 Oliver Elite 1, Hull 107
Oops,
forgot the part #: PR1022. But Check your door. My door is 11 years old!
Dave
Do what DavePhelps says above!
There are at least two different windows on our Ollies and have VERY different mounting methods.  Call the company to make sure that you get the right part(s).
