Jps190 Posted May 25 Posted May 25 (edited) FIDISP 12 Volt Water Pump, Portable Transfer Pump, 330GPH Larger Flow, 1/10HP Electric Utility Pump with On/Off Switch, 2 * 6’ Water Hose Kit for Garden Pools Aquariums Hot Tub https://a.co/d/0hzZ7HoS Camco Durable Sewer Cap with https://a.co/d/0h5qZBVm Been using this for 4 years. Takes 3 minutes to fill black tank and takes up minimal space. As a bonus it is simple to hook to a hose bib to flush out. John Edited May 25 by Jps190 3 John and Kim 2021 GMC Sierra 2500 AT4 6.6L Duramax 11350 GVWR 3048lb Payload 2021 Oliver Elite II. Hull #887. 600 Watt Solar Mod
DanielBoondock Posted June 2 Author Posted June 2 Proof of concept; onboard (inboard?) water conditioning and filtering. Quote PSA: Some will think this is way overkill for water and that’s perfectly fine, but we’re really into clean water, and it has the added benefit of not leaving water spots or leaving deposits in the system. And for the mooch camping we’re doing at a relatives which has incredibly hard water it’s a lifesaver so there 😉 The problem has been the water softener and iron filter. So far it’s all be a modular system I move around. A pain but flexible. I gave up on putting the tanks onboard as they’re a bit too tall for any of the storage. But poking around I found that the panel under the bedside drawer is just sitting there so … Pros All contained nicely Puts weight in the back near the wheels (I’ve got plenty in front) Always set up so just takes two hookups, one from the faucet and two to the back water input. For waterpoint boondocking (e.g. national parks) I haven’t used it. Too much to futz with pulled off at some waterpoint and usually blocking the road. Since it’s permanent those hoses won’t kink, they’re a pain as they want to kink up if you use them modular Easy to access the valves for backwashing and regenerating by just taking the drawer out which is easy It just works out nicely with the lines having the right amount of coil Cons Not so great for city water. Unless I jack into the line internally I have to keep the hatch open which isn’t optimal But that’s fine, just use the tank and pump until/if I decide to make it more permanent Takes up the back storage But that’s odd storage anyhow, I finally settled on putting a folding chair and table there, plus dirty laundry shoved through the interior hatch. And now this frees up that storage elsewhere. The tanks have been knocking about, mainly in the truck. The main filter has been in the Sea Biscuit back storage, but now I can put the chairs and whatnot there And … that’s it? I’ll sit with this a few days but I think I like it and will start to make it permanent 👍 1 Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 530 mile pack)
Steve and MA Posted June 3 Posted June 3 2 hours ago, DanielBoondock said: Proof of concept; onboard (inboard?) water conditioning and filtering... Very clever use of basement space. Never thought of removing the panel under the nightstand to gain a few inches of height. Blutech didn't offer their low profile filter system at the time we set ours up, and most softeners small enough for the basement have limited capacity between recharges, so we installed our filter/softener system in our TV, which also has two Blutech hose reels with quick connects for intake from city water and output to the Oliver fresh tank. The reels each hold 50' of hose, so reach hasn't been a problem. Even when full hookups are available, we fill the fresh tank and rarely use the city water port. The basement door stays shut. We also have the Nature's Head, so we only deal with fresh and gray. We run out of fresh water about the same time the grey is full. The inaccuracy of the gauges isn't much of a problem since the grey can't overfill from a single fresh tank, and we haven't ever run out of fresh water before knowing it was low. Steve 1 Steve & Mary Allyn San Antonio, TX 2022 LE II Hull #969 "Un Œuf", 2021 MB Sprinter 3500 "Polly", 2008 Pleasure-Way Excel TS "Val", 1975 GMC Glenbrook "Whoosh"
DanielBoondock Posted June 3 Author Posted June 3 9 hours ago, Steve and MA said: Very clever use of basement space. Never thought of removing the panel under the nightstand to gain a few inches of height. Second choice was opening the hatch under the bed and possibly raising the bed some way to make a space. I’ve got Froli installed plus the condensation mats which might be enough, if I opened a hole in them. Fortunately this works better and makes good use of the space. I rearranged everything last night and like it better than before Quote Blutech didn't offer their low profile filter system at the time we set ours up, and most softeners small enough for the basement have limited capacity between recharges, so we installed our filter/softener system in our TV, which also has two Blutech hose reels with quick connects for intake from city water and output to the Oliver fresh tank. The reels each hold 50' of hose, so reach hasn't been a problem. If this didn’t work I was going with that approach Quote Even when full hookups are available, we fill the fresh tank and rarely use the city water port. Good to know thanks! Yeah I was leaning in that direction, why use city water at all when you only need to fill the tank every couple days? Quote The basement door stays shut. We also have the Nature's Head, so we only deal with fresh and gray. We run out of fresh water about the same time the grey is full. The inaccuracy of the gauges isn't much of a problem since the grey can't overfill from a single fresh tank, and we haven't ever run out of fresh water before knowing it was low. Good tips … OK yeah with your encouragement this is a go - it’s already basically done. I just need to brace the tanks, maybe I’ll get the Blutech mounting frames or something else. Final bit is I just need some power, right now it has a 120V adapter but it’s 12V so I’ll go that route. For the time being I’ll use a small portable power bank. Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 530 mile pack)
DanielBoondock Posted June 4 Author Posted June 4 OK the filterification of the Oliver is done and tested. Just need a little padding/bracing, I think a foam pad between the tanks is all I need. It’s so tight in there they’re already pretty secure. Here’s a block diagram of what I ended up with The reasoning is that all this filtering greatly reduces water pressure and slows the fill basically. I don’t need the Offgrid Filter (down to .5 u paper filters + UV sterilize) for the fresh water tank, just the softening is sufficient. So I have a loose “To fresh tank” quick connect line when filling, just three easy connections for waterpoint and to tank, just using the softener/Fe I open the offgrid line and snake the hose into a 5 gallon drinking water tank to fill that up. Plus power - I need to get a 12V cig output into the basement The third is for spraying off the truck + trailer. Softened so that ideally it leaves no water spots I don’t know how this worked out but somehow, with the water tanks taking up that back space (leaving room to toss dirty clothes around them) I seem to have more storage overall. I’ll take it though 1 Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 530 mile pack)
DanielBoondock Posted August 18 Author Posted August 18 Trail cam! The Sierra EV has one of if not the biggest screen in the industry, massive 17” tablet, and GM’s got IMO the best cameras in the industry. Anyhow I can have two trailer cams, I’ve got one on the back for transparent trailer etc. I put the second on as a trail cam Spent a long time thinking about where to put it. Up top is pretty well covered with the other cameras, I realized the ground was the weak spot. Use cases you all will be familiar with Shows levelers/chocks etc. When driving on/off levelers it’s impossible to tell where you are and I often overshoot and bung them up as there’s few inches of margin with dual axel When offroad, or even parking lot speed bumps, will be really nice to see them coming instead of guessing for known obstacles. Sometimes I have to drive over a curb too Fun and a good idea to keep an eye on the trailer suspension Backing up to a stop. At my park I have the cement parking stop placed where I want it, but I can’t tell where it is until I hit it. Installation was ridiculously easy. This and only this cross bar was perfect as its the only one not holding anything up, so I could simply zip tie to it. And of course they have these genius cable runs on the two edges. 2 Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 530 mile pack)
jd1923 Posted August 18 Posted August 18 2 hours ago, DanielBoondock said: Trail cam! Please take before and after movies, pre and post Alcan upgrade. 😎 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
DanielBoondock Posted August 18 Author Posted August 18 (edited) 8 hours ago, jd1923 said: Please take before and after movies, pre and post Alcan upgrade. 😎 You read my mind, I anticipated there would be interest lol .. I made sure to wrap this up by the last Dexter trip GM just dropped an Surround Recording feature via OTA, but it ‘only’ records four cameras front/back/sides, so ill have to have my wife point a phone at the screen Just thought I’ll check the trucks App Store and see if there’s a screen record.. Edited August 18 by DanielBoondock 1 Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 530 mile pack)
DanielBoondock Posted August 21 Author Posted August 21 Towed it back home after a trip. The following observations are preliminary pending what I see after I install the Alcan. They’re not scientific or measured in any way, but my impression from watching the trail cam for an hour over a variety of road conditions. Having said that I’m pretty confident of the patterns I’m seeing. I’ll try and post good video captures before/after so you can make up your own minds (I got some video from this trip but I really need a phone mount), but for now here are my impressions … Suspension Run, don’t walk and get yourself set up with a set of Alcan 5 leaf! For reference I started as an Alcan skeptic to agnostic, now I’m a raving convert. The stock suspension is undersprung, I’m convinced of it. Confident I’m seeing that the springs have too little travel and bottom out too quickly. After this I can’t unsee it, just sitting there parked they’re too compressed. Alcan’s assessment that for this trailer you need five leaves is 100% accurate, and for an engineer to say that is as strong an endorsement I can make. The stock suspension works, that’s the best I can say, but they’re not performing as they can (or should). I’m really curious to see the Alcan’s in action but I have no doubt it’ll be better than this. Five springs? All the way. Tire Pressure Stop underinflating your tires! Its ruining milage and stressing your tires. It’s perfectly clear the suspension is doing what it’s supposed to do and absorbing the bumps and rattles. Whatever makes it through that doesn’t matter and there’s little you can do about it anyhow. This is most obvious on hard, quick impulse hits like going over a pothole. That suspension is getting brutalized! But it’s taking it, I can see it rattling around like crazy but I’m not seeing an ounce of rattle making it to the hard mounted camera. Think of it this way, imagine a 7 thousand pound weight going down the road. Lots of mass and momentum right? Hard to get it to move out of a straight line according to Newton, correct? But it’s got a spring connecting it to the road which is designed to move and quickly. What I see is 100% clear - the trailer plows ahead like an aircraft carrier that doesn’t care one bit about the road, while the suspension is getting beat to hell. By the way I’m able to judge the trailer vibration I think by how ‘steady cam’ it is, and compared to the road/lines/etc as a reference. Basically it looks like an actual steady cam, while the suspension is rattling away and moving all over the place, while the trailer just isn’t seeing it. If you see stuff getting knocked around inside it’s the porpoising. That’s the biggest trailer movement I could see, with a little minor waddle, but road rumble isn’t making it up there much as far as I can tell. Tank drain Kind of an interesting one. I opened the fresh drain valve and it continued to drain intermittently for over an hour, from 30%. Going from a stop would always get a gusher. Anyhow FWIW - feel free to keep your Dexter’s and low pressure, but I wouldn’t touch it after seeing it in the real world. 1 Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 530 mile pack)
DanielBoondock Posted August 21 Author Posted August 21 I looked over my footage, not worth uploading. I was holding the camera, there’s too much camera shaking from holding it to be useful. Second it’s not long enough, you’d need an hour of watching the footage to see it, and ideally you’re also seeing the road too. In other words, ideally you’d be watching it while driving. It’s not something that jumps out at you, it’s not obvious as first glance. Initially I was thinking “move along, there’s nothing to see here”. But after 45 minutes or so of watching a story emerged which I wrote about above. It took that long to see the pattern, which I’d characterize as … Trust your suspension. Baby it, inspect it, religiously do your maintenance and inspections. It’s doing its job but is taking a hell of a beating. After this I’m going to religiously inspect before every drive. Upgrade it with the best components you can (Alcan) Factory suspension is clearly undersprung (Alcan) And now I am going to carry all these Dexter parts as spares on the road Trust your trailer, don’t underinflate your tires The Oliver is built like a tank - that’s why we bought it right? As detailed above the aircraft carrier is the best description. I’ve seen other suspension drive videos with conventional trailers and you can see them rattling and moving. In fact there are RV tech videos talking about the need for those panels to move relative to each other, ideally with a good angle bracket covering the edge. The Oliver is nothing like this from frame to body. Nothing is meant to move, it’s stiff like crazy, and from what I can see at best only very high band/high frequency vibrations make it through. But in a fiberglass four body trailer like this they’ll just damp themselves away. Avoid porpoising as best you can All the shaking going on inside the trailer? It’s that. Comparing that from the side mirrors to the underbody cam was night and day. Clear that any internal trouble comes from that Somewhat related, I had my Anderson installed from the factory. They recommended slightly slack chains. It’s bothered me ever since, how could these possible be doing any weight distribution? Didn’t get any response here about it but consulted Gemini which was clear that the chains need to be tensioned for WD to occur. So this trip I tried it, lifted the truck back end a couple inches, tightened the chains and then lowered. End result was the truck towed a bit better. I run a heavy trailer with a 700 lb tongue. 2 Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 530 mile pack)
DanielBoondock Posted August 24 Author Posted August 24 I’m graphene coating the Oliver, just completed the roof. Basically following the CG Detailing method, which they graciously provide if you dig for it. They don’t come out West so I need to DIY which is a ton of work but satisfying. If there’s any interest I’ll provide details and tips Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 530 mile pack)
2008RN Posted August 24 Posted August 24 Sounds interesting 1 Early 1999 Ford F250 SD 7.3L Diesel 2020 Elite II Twin - Hull # 648
DanielBoondock Posted August 25 Author Posted August 25 On 8/23/2026 at 11:31 PM, 2008RN said: Sounds interesting Some things I’ve found out that will be of interest, a lot of it from consulting with various AI’s which have gotten really good and more reliable than humans Trailer Cover I’ve debated getting a cover, but that’s more for the traditional trailers with leak prone seams that need protecting. Other than cost and difficulty to get on/off there’s a ‘greenhouse effect’. I’m seeing it now, I’ve got a tarp on the roof to keep morning dew off while the graphene cures. Already in the morning that inside ceiling gets hot. A cover bakes the trailer, better to graphene coat and no cover which lets moisture evaporate and radiate heat UV Protection What about preventing chalking? Hands down SiO2 without or without graphene is the best solution. Gel coat is rather porous, providing a perfect base for the coating to adhere to and it perfectly seals and prevents basically 100% UV protection. Just make sure to refresh it every few years, depending on use and climate it can last up to eight Graphene This is an additive to a regular SiO2 coating and solvent. By itself it can’t coat, but as a dopant it greatly improves the performance in many ways Which brand? Glidecoat. Originally made for marine applications it’s Elite level protection for your Oliver. Additionally its rated multi-surface, get the 30’ kit and you’ll have plenty to coat all the aluminum too, and probably much of your truck Why? Basically its the best protection for this trailer other than garaging it. Even then it’ll be easier to travel, you want to get bug guts off, droppings and sap because they eat the gelcoat. But after this treatment they just wipe off. Looks great too. And its cheaper than the alternatives. Garaging is expensive (and rare out West) and you want protection on the road anyhow. CalMark covers are near $2k and a pain, and this only requires minimal upkeep and maintenance. Total cost and tools was around $1k + sweat equity, or you can have CGI do it. Application The CGI Detailing is the best method, which is roughly Do a deep, deep clean For heavily oxidized trailers use a rotary polisher and heavy cutting compound Then (and for trailers in good condition) use an orbital polisher working in 2x2 or 3x3 squares with Inox Cutmax, four dots on a particular pad. Three passes, Wipe off Go to 6-4 polishing compound, same method IPA wipe off, two towel method Coat Lots of particular details here that are important, highlights Moisture must be managed. The solvent uses humidity to cure, but actual moisture will ruin it. Working outside is fine - I’m doing it - but I time it to periods during the day and cover the trailer at night for the first 48 hours to avoid morning dew and be out of the sunlight so it doesn’t flash off too quickly. Don’t wash the trailer with soap for at least a week. Do two coats, three doesn’t add anything In general use a two towel method and rotate pads. It took me two days do the roof, partly because I think it’s on the ladder so lots of moving that around, fiddling with the odd areas, and getting used to it. Next I’m taking three days to do the sides and back. First day to compound, second to polish and coat one side, final day to do the other side. Much easier outside as can pop the awnings to avoid any sun. Then finally I’ll take two days to do the front as that’s the most important 1 Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 530 mile pack)
DanielBoondock Posted Sunday at 12:32 PM Author Posted Sunday at 12:32 PM Top half is done (plus the roof from the previous week). That was brutal, don't attempt unless you're fit. Once you start coating it goes fast on a schedule, ideally you'd have two people working it, but I pulled it off. Just three mistakes, small spots where the coating wasn't properly wiped off, I'll adjust those later. I'd recommend the following approach, do the roof in one go, the top half including the midline belt, then the bottom half in either two steps (e.g. curb/street) or all at once. Splitting at the midline belt is an ideal seam. The top half should be done at once ideally - tough but its the most visible and takes a lot of wear. So you want to apply the coating and second coat overlapping before it's cured so it can form a seamless matrix. The bottom half has a natural split with the spare and propane housing so can be done in two parts, I'll do that next weekend. So the worst is behind me ... We get coastal fog rolling in and keeping morning dew off the first 24 hours at least is really important. Fortunately with our trailers its easy, I got a 20'x10' tarp which covers it and overlaps the side by about a foot. stitch each side with some good hold down rope, and I tied microfiber cloths at the grommets to prevent wear if there's any breeze. The AC/solar/etc and awnings act as standoffs, ideally you also have the streetside. With this you don't need to have a garage to cure, as long as you can work in the shade with little wind. Fortunately my parking spot at the lot fits the bill. Anyhow, I bought the 30' new RV kit but the 25' or 20' would have worked, I'll have at least a full bottle left over to do the truck. I'll also do the works on this trailer, awnings, solar, AC, frame and underbody, why not? btw ... this graphene coating is like having armor. It's unbelievable stuff, I tried buffing a mistake out and it was not easy. It creates this incredibly hard and smooth coating, it ain't foolin around ... Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 530 mile pack)
DanielBoondock Posted Sunday at 02:49 PM Author Posted Sunday at 02:49 PM Forgot to add, in 4k miles the only non superficial damage I found is the lower half street has three pin pricks in the lower part. On the curb side there's a single bigger rock strike near the propane housing, again in the lower 1/4 section. Even with the graphene I'll put a wrap on it for the bigger ones. I don't want to go with mud guards because one, it'll disrupt the underbody airflow and two, there's no way to attach them. The whole underbody is one smooth surface for aerodynamics. Applying it is easy, just use a little soapy water to position, main problem is cutting it to lay over the area well. Exaggerated but I think this would work. If anybody has any ideas on this one ... Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 530 mile pack)
jd1923 Posted Monday at 03:33 AM Posted Monday at 03:33 AM (edited) 18 hours ago, DanielBoondock said: That was brutal, don't attempt unless you're fit. I’m fit, I used to always weigh 240+ now 220 LBS or less. We played 2 hours of pickleball today, and generally play 3 times a week. We play against couples in their 50s, winning more often than not, just us in our early 70s! 😎 No fricken way I’m washing/waxing a vehicle anymore! After 50 years of keeping every vehicle I have in A+ condition, my energy for wax-on/wax-off has grown extremely weak! I’ll pay $100 to have a neighborhood kid work all day long washing my truck! Paid $2K for the best Ceramic Coating I’ve ever seen (just one guy, he kept our Oliver for 2 weeks). Taking our hull back to “the guy” for our first annual decontamination wash. I could not believe when just last week he said, the annual will be $180 (based on how I kept it, mostly untouched). Thanks Dan, I enjoy reading “Dan’s Mods!” Edited Monday at 06:56 AM by jd1923 1 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
DanielBoondock Posted Monday at 01:14 PM Author Posted Monday at 01:14 PM 9 hours ago, jd1923 said: Thanks Dan, I enjoy reading “Dan’s Mods!” Aw thanks, good to hear. I was wondering if anybody is listening Yeah definitely I'd pay somebody, but let me tell you how expeeeeensive it is around here to do anything. Remember that $1500 Alcan install quote I got? It's wine country, Bay Area money and generally rich people around here which makes you a DIY. I called around on coating my truck and couldn't even get anybody willing to do it 🙄 Anyhow unfortunately the front has more minor coating defects, but only from the right angle in the light. Sides/back/top is perfect, but on the front I was really tired and let the coating dry for too long before attempting to buff off. I did find later that you can reapply and the new will liquefy the old, if you don't wait too long. Oh well, nobody will notice except me, and it'll abrade off eventually and I'll do it better next time in X years. In other news I found my breakaway battery was dead. Put in a ticket, diagnosed no 12V AUX off the seven pin. Chased down a burned out 30A fuse in the frunk/eTrunk fuse box I should say an expensive $8 30A fuse. Hard to find too ... did various investigations, unfortunately the SLA in the controller is dead, they don't take getting run down for long, so that'll need replacing. Everything looked fine, maybe it blew on an adapter I use for the lights on my bike rack and ... no. It blew again. I have one fuse left, tried it without the trailer hooked and it's fine, so it's not the truck. So will need to figure this one out ... the wires deadhead into the front bulkhead through the propane. There's probably junction there I'll need to get to by taking the small towel hanger off the bathroom cabinet. Or, maybe the controller is just bad. Don't know what Oliver did in the past but now if it's any component they send you off to the manufacturer. Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 530 mile pack)
DanielBoondock Posted yesterday at 03:21 PM Author Posted yesterday at 03:21 PM Update on the breakaway unit. The 12V is dead and won’t take a charge, supposition is the 12V is internally shorted. Under warranty Brightway is sending out a new unit as they can’t break out the battery separately. Which brings up a DIY project … I have a Honda 7000is generator which has a similar small 12V SLA. Got it long ago before the EV came along which now powers the house in an outage. Early on I found that the starter battery dies after a couple months of not being used, pretty much like any lead acid. With a battery minder on it doing the conditioning its fine. What about the breakaway battery? If these trailers sit for a couple months off seasons I’d expect those to become very unhappy. When’s the last time you checked your breakaway battery, is it still viable? I think what I’ll do is make up a 7 pin socket to 12V port and make sure it’s plugged in at least once a month to top off. Ideally later with a more permanent solution. Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 530 mile pack)
jd1923 Posted 23 hours ago Posted 23 hours ago 1 hour ago, DanielBoondock said: When’s the last time you checked your breakaway battery, is it still viable? I'm not getting this. Do Oliver TTs have something new in late model units? And I don't recognize the fuses in the picture above. Not familiar with Brightway either. On our Oliver I'm pretty sure the breakaway switch uses power from the house batteries applied to the brakes when the pin is pulled. I often pull that pin manually to test for amperage at the trailer brakes. I have a breakaway battery on a flatbed trailer we own. It needs one since it doesn't have house batteries. On 8/31/2026 at 6:14 AM, DanielBoondock said: diagnosed no 12V AUX off the seven pin. Is this not disconnected by design? (so that truck starter batteries and house batteries are isolated.) 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
DanielBoondock Posted 18 hours ago Author Posted 18 hours ago 5 hours ago, jd1923 said: I'm not getting this. That’s just the fuse box for my truck in in the frunk. Basically the high power ones including a 30A for the trailer 12V Quote Do Oliver TTs have something new in late model units? And I don't recognize the fuses in the picture above. Not familiar with Brightway either. Don’t know what they had before, just assumed this was standard but sounds like not. In the ‘26’s (mine) my understanding is the 12V truck power is only used to charge the Brightway controller unit. It’s a closed circuit, so there’s three power systems in the truck, this, the 12V and 120V. One of the electrical mounting panels has lettering for a DC to DC controller, so presumably the ‘27’s will offer an upgrade for that to charge the house batteries off the truck (don’t want/care about myself) Quote On our Oliver I'm pretty sure the breakaway switch uses power from the house batteries applied to the brakes when the pin is pulled. I often pull that pin manually to test for amperage at the trailer brakes. So there’s no battery in your breakaway unit? Interesting … oh! OK, I think this was done in preparation for the DC-DC upgrade. You can’t have the house battery feed back to the brake controller, so they put in the independently powered unit above, and then they can tap off with a DC to DC converter too. Good thing; safer, in the rare case that the house batteries are offline or dead. Bad thing potentially; I need to make sure that battery is taken care of. And already I’ve got a short. So for ‘26’s and on, a potential failure is if your trailer isn’t towed for a couple months, these batteries might die. I get the impression that Oliver might not have thought of this. Quote Is this not disconnected by design? (so that truck starter batteries and house batteries are isolated.) No starter battery in an EV, it’s a very small 12V SLA to power the computers and act as a buffer from the internal inverter. But that’s not important, if I understand you yes the ‘26’s have isolated circuits, but sounds like yours the breakaway is powered off the house batteries. Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 530 mile pack)
jd1923 Posted 14 hours ago Posted 14 hours ago 3 hours ago, DanielBoondock said: So there’s no battery in your breakaway unit? Interesting … Why should there be? My flatbed trailer which we use to haul dirt bikes has one (no house batteries on board). Have you touched one on your Oliver? 3 hours ago, DanielBoondock said: No starter battery in an EV, Something starts your 9K LB sled of batteries! 🤣 You’re going to have to realize 99% of us have “starter batteries.” When you go off in EV-land, like what the F is a Frunk? 🤣 Please translate to those of us who turn the key to start a combustion engine, gas or diesel. We have “starter batteries” and we all have “house batteries.” Pics if your EV fuses, hence my confusion. Thank you. And we have many posts here on disconnecting the AUX wire on the 7-blade connector. This winter, please come to Quartzsite! I’d love to meet you! Spend some time with us, including Steve @ScubaRx. He’s The OTT elder, the guru of everything OTT. Me, I’ve rebuilt everything I’ve ever put my hands on, after 3 years with Hull #113, there’s honestly no better Oliver out there, IMHO of course! 😎 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
jd1923 Posted 13 hours ago Posted 13 hours ago (edited) On 8/31/2026 at 6:14 AM, DanielBoondock said: Aw thanks, good to hear. I was wondering if anybody is listening Dan, we disagree half the time and you always come back with something good. Edited 13 hours ago by jd1923 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
DanielBoondock Posted 59 minutes ago Author Posted 59 minutes ago 12 hours ago, jd1923 said: Dan, we disagree half the time and you always come back with something good. I love meeting people who disagree with me 😄Chance to learn something new, happy to find I got something wrong or just see another perspective 12 hours ago, jd1923 said: Why should there be? My flatbed trailer which we use to haul dirt bikes has one (no house batteries on board). Have you touched one on your Oliver? Sorry not following Quote Something starts your 9K LB sled of batteries! 🤣 ikr 🙂 Actually its interesting, we get a fair number of automotive engineers in my field (we sell into the 'software defined vehicle' space). Talked to one about the computers in ICE and EV; they're always awake. Can't have them boot everytime you jump in. But for safety they do need to quietly reboot to ensure some random bits didn't flip from a cosmic ray. So they have to do fancy stuff to make sure they reboot when you're unlikely to use the vehicle, like 3AM .. Quote You’re going to have to realize 99% of us have “starter batteries.” Just got rid of my last ICE vehicle, a 2000 era mommy van. Gave it to my BIL. Owned a number of ICE trucks in the past too, midsize, this is my first full sized. Actually my love affair with EV's started as a teenager, I tried fixing up a Triumph Spitfire, those carbs are something to behold (not in a good way lol). I studied internal combustion, and was blown away at what a mess it is 😅 You waste half of this incredible energy source, and have complicated mechanical breakdown-prone systems just to take all that unused energy away. Anyhow I've been waiting ever since for electric to mature and now here we are finally 😇 Quote When you go off in EV-land, like what the F is a Frunk? 🤣 Please translate to those of us who turn the key to start a combustion engine, gas or diesel. We have “starter batteries” and we all have “house batteries.” Pics if your EV fuses, hence my confusion. Thank you. Sorry 😅 Tesla term for the storage under the hood. "Front Trunk". GM calls it an 'eTrunk'. I usually call it a trunk but used frunk thinking that was pretty well known by now lol .. but when you don't have a big engine there's the possibility of having front storage space Anyhow this thing has two electric motors, one per axel. Ford - with their Lightning truck, squeezed the motors and associated stuff low enough to have a ginormous storage space which established the standard for EV trucks. Here's what I've got in mine under the front hood. The side panel covering the battery/fuses has been taken off, the rest of it is tools and tire changing gear Quote This winter, please come to Quartzsite! I’d love to meet you! Spend some time with us, including Steve @ScubaRx. He’s The OTT elder, the guru of everything OTT. Me, I’ve rebuilt everything I’ve ever put my hands on, after 3 years with Hull #113, there’s honestly no better Oliver out there, IMHO of course! 😎 Love to! I'm expecting we'll meet one of these days. My wife however is shall we say, 'easing into this lifestyle'? I'm the outdoorsy type of the family, so I think Quartzite will be a while, not quite civilized enough. Anyhow I'm retiring the following March and saving vacation to get paid out (I'm maxed out), so won't happen this year at any rate. Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 530 mile pack)
