Lori L Posted May 25 Posted May 25 The lever on my kitchen faucet will move from side to side, but I cannot pull the lever towards the sink to allow water flow. I don’t want to force it. It worked when I winterized IMG_2389.mov the camper two months ago and I just had the camper serviced. But the kitchen faucet lever seems to be locked and will not come forward.
Moderators topgun2 Posted May 25 Moderators Posted May 25 I do not have your type of faucet in my trailer or home. However, these faucets virtually all have a cartridge inside and it appears to me that there is something stuck inside that. I'd look at your manuals to see what cartridge it uses and how to disassemble the top of the faucet in order to get to it. Good luck! Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Steph and Dud B Posted May 25 Posted May 25 1 hour ago, Lori L said: I just had the camper serviced. What service was done? 1 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
Lori L Posted May 25 Author Posted May 25 4 hours ago, Steph and Dud B said: What service was done? I take it into Hohenwald and get the entire service/maintenance package done. I did take the allen screw out and removed the lever to see if calcification had occurred or if something else was blocking the lever from being pulled forward. Couldn’t really find anything. Just have to do without the kitchen sink this trip. I also did submit a service ticket. Thank you for your reply!
SNY SD UP Posted May 26 Posted May 26 (edited) I would definitely contact OTT Service. if you just had the “Full Monty” service then they should have noticed this. Edited May 26 by SNY SD UP Maggie & Bryan | Arnegard, ND | 2020 LE II "Twins" Hull #665 | 2021 RAM 2500 6.4L HEMI Gasser 4dr 6.5' bed
Steph and Dud B Posted May 26 Posted May 26 We've had decidedly mixed results with service at Hohenwald. 1 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
jd1923 Posted May 26 Posted May 26 (edited) 3 hours ago, Lori L said: I did take the allen screw out and removed the lever to see if calcification had occurred or if something else was blocking the lever from being pulled forward. Just looked at our faucet which overall looks similar except we do not have an Allen screw on top. I would remove the handle again to see if with some kind of tool it can be moved. You can’t make it worse! It’s likely not serviceable, so if it remains to be stuck it will have to be replaced. I was back there a couple years ago because the water lines on our faucet were loose and leaking. It will not be a fun job to R&R since there is so little room and you’ll need a mirror to see behind the sink. Hope you can get it to work somehow. Edited May 26 by jd1923 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
