After 8 years of the Carefree awning, I decided to go with what I a wanted originally. A Fiamma 45s 450 (14 ft 8 in.). The Carefree was well made and incredibly durable but had some shortcomings. Mostly regarding closing completely. The Fiamma has a much lighter weight aluminum pole for extending and retracting. Also, like the pole connector on the right side close to the door.
I ended up using the old brackets (used a square to mark with both awnings on the ground lined up) just to make the install simpler. The awning extension pole bracket holes on the camper weren’t the same so you have to drill another hole, not big deal.
Love the new blue awning and seeing it when closed shut perfectly on both ends of case!IMG_3349.thumb.jpeg.d2c92b912323d770b5e131886e538787.jpegIMG_3351.thumb.jpeg.8e8c972ee7a25c68dbeeabae864bd6af.jpegIMG_3353.thumb.jpeg.754e4e50d9f4af3be1bf99cc60076b41.jpeg
Edited by rideadeuce
  • Like 7
Hopefully you have better luck with your Fiamma than we have had with ours. Within a couple of years the rear part of our Fiamma would not completely shut or close and thus we tend to use strap on the rear of the unit to keep it closed.
Nice looking installation on yours! Really good job.
Legacy Elite II #70
Exactly like ours but not sure for how long. Don't think I used it the first year we had our Oliver and once I did it would not close completely on the rear. We use a rear strap as pictured.
Anybody know it there is an adjustment?
Mike, good work as usual. You've been first on many great Oliver Mods! 😎
We will see how long the perfect closure lasts but there is an adjustment you can try.
I used this method to adjust mine and it worked perfectly. Really like this model awning for its simplicity and ruggedness in windy conditions. It is a good idea to keep a spare gearbox for it on hand, though.. Mine last one went bad and took almost 2 weeks to source another.
Nice job on the install!
Well crap wouldn't you know my earlier unit does not have those adjustments to make. However I did discover two wasp nest buried in the awning compartment and one loose bolt on the mechanism. In fact it was almost all the way out. Doubt this has anything to do with adjustment fore and aft for retrieving the awning into its compartment.
Legacy Elite II #70
Good grief, after washing and cleaning up the Fiamma this morning, now I can't get the thing to retract properly at all. Both ends are stuck partially open. Can't get in touch with customer support at the company either, messages do not go through.
  • Sad 1
Legacy Elite II #70
Better loosen up that bolt and asks the wasps back!🤣
(Now, I'm not touching mine!)
I might just take the thing completely off. Watched a couple of videos earlier illustrating how to change the fabric, doesn't look to be a big deal other than the height we have to work at. Might be easier to do this at a lower height as the video shows.
Legacy Elite II #70
