rideadeuce Posted yesterday at 01:35 PM Posted yesterday at 01:35 PM (edited) After 8 years of the Carefree awning, I decided to go with what I a wanted originally. A Fiamma 45s 450 (14 ft 8 in.). The Carefree was well made and incredibly durable but had some shortcomings. Mostly regarding closing completely. The Fiamma has a much lighter weight aluminum pole for extending and retracting. Also, like the pole connector on the right side close to the door. I ended up using the old brackets (used a square to mark with both awnings on the ground lined up) just to make the install simpler. The awning extension pole bracket holes on the camper weren’t the same so you have to drill another hole, not big deal. Love the new blue awning and seeing it when closed shut perfectly on both ends of case! Edited 20 hours ago by rideadeuce 7 - Mike Brentwood, TN - 2018 Elite II - Spirit of Adventure Hull #308 - 2016 Toyota Tundra Limited 5.7L Class IV hitch with 12k lb coupler, Weigh safe adjustable trailer hitch, Dobinsons HD 2in Leaf springs, Timbren bump stops, Dobinsons 3in coilovers and UCAs, Mechman 370 amp HO alternator. Oliver upgrades: Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp DC/DC charger with Anderson connections, Toshiba 6-in-1 Microwave oven - air fryer combo, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar on top, Custom aluminum bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires, Seabiscuit Metal Designs front storage box and moose rack.
routlaw Posted 17 hours ago Posted 17 hours ago Hopefully you have better luck with your Fiamma than we have had with ours. Within a couple of years the rear part of our Fiamma would not completely shut or close and thus we tend to use strap on the rear of the unit to keep it closed. Nice looking installation on yours! Really good job. Legacy Elite II #70
jd1923 Posted 12 hours ago Posted 12 hours ago 4 hours ago, routlaw said: the rear part of our Fiamma would not completely shut or close and thus we tend to use strap on the rear of the unit to keep it closed. Exactly like ours but not sure for how long. Don't think I used it the first year we had our Oliver and once I did it would not close completely on the rear. We use a rear strap as pictured. Anybody know it there is an adjustment? Mike, good work as usual. You've been first on many great Oliver Mods! 😎 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
rideadeuce Posted 3 hours ago Author Posted 3 hours ago (edited) We will see how long the perfect closure lasts but there is an adjustment you can try. Edited 3 hours ago by rideadeuce 2 - Mike Brentwood, TN - 2018 Elite II - Spirit of Adventure Hull #308 - 2016 Toyota Tundra Limited 5.7L Class IV hitch with 12k lb coupler, Weigh safe adjustable trailer hitch, Dobinsons HD 2in Leaf springs, Timbren bump stops, Dobinsons 3in coilovers and UCAs, Mechman 370 amp HO alternator. Oliver upgrades: Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp DC/DC charger with Anderson connections, Toshiba 6-in-1 Microwave oven - air fryer combo, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar on top, Custom aluminum bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires, Seabiscuit Metal Designs front storage box and moose rack.
CRM Posted 1 hour ago Posted 1 hour ago 1 hour ago, rideadeuce said: We will see how long the perfect closure lasts but there is an adjustment you can try. I used this method to adjust mine and it worked perfectly. Really like this model awning for its simplicity and ruggedness in windy conditions. It is a good idea to keep a spare gearbox for it on hand, though.. Mine last one went bad and took almost 2 weeks to source another. Nice job on the install! 1 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
routlaw Posted 1 hour ago Posted 1 hour ago Thanks @rideadeuce will give that a try today. 1 Legacy Elite II #70
