I have not seen this one on the forums before. I have a ticket out to Oilver support, but I thought I would post here in case someone has the "easy button." I also tried Truma, but they are closed for the weekend. At the very least, as I figure it out, it will be here for others to reference. E8H seems to be either a fuse issue or something off with the gas. I have checked the control panel fuse, and it is fine. I cannot find an inline fuse. I have turned the heater off and back on. I have also turned the gas shut-off switch off and then back on. I have even reset the CP control panel. So, no luck. I have verified that gas is flowing, as the water heater works and the stove does as well. I have also verified that the vent to the outside is not obstructed.
Todd & Kat
You probably already know this but that error code relates to fuel or power supply issue.  The suggested remedy is a system reset.
Edited by FloraFauna
Incorrect info
Did a CP control panel reset. No joy.
Todd & Kat
Hmmm.  I think you are entering the realm of Oliver service and an authorized Truma service center.  It seems this error code is unusual or there would be alot more responses to this thread by now.
I've been chatting with another Oliver owner who had the exact same error yesterday.
My understanding is that it's some sort of "E"lectrical error with the "H"eater.
That could mean:
  • loss of signal between heater and the display (loose wire?)
  • loss of power to the unit (different loose wire?)
  • loss of power to the igniter
  • or something else
I think that's where the suggestions of resetting the various power supplies comes from.
I've been told that listening the heater start up may narrow the investigation.
e.g. If you hear the fan, the heater has power?  If you hear the igniter clicking, it's got power? If you hear nothing, power is not getting to the unit? etc.
Alas, I have no answers.  But, if they report back a solution, I will let you know.
If you find it first, please report back.
Thanks,
Dennis
Thanks @Dennis and Melissa
Had a ticket with Oliver and did a call with them. Oliver support did not have an answer. Now working on a ticket with Truma. I saw someone else post about this on Facebook as well. Will report back what we find out.
Todd & Kat
Update for anyone out there wondering. The trailer is in the shop at Bretz RV in WA. Truma needed the issues confirmed by a certified rep, of course. They thought it was part A, and it was confirmed to be part A. However, the shop reached out to order part A, and Truma is saying they don't sell just that part, so now there is a debate about whether we have to buy a new furnace! The warranty is 2 years, and the trailer was built in 2023, so that is nice that it recently expired. At this point, no idea when we will get her back, and we have a departure date of next Saturday for a long long trip. urgh.
  • Sad 3
Todd & Kat
z
Edited by taylor.coyote
typo
Fieldbrook, Ca
@Todd B, what was the part / component / assembly called that was associated with the error code?  Were you able to get a reasonable solution from Truma without the expense of replacing the entire unit?
@Tom and Doreen did you have the same error code? The part was the combustion sensor. They originally thought it was the room temp sensor which sounds like it can be replaced. The combustion sensor is not sold in the US. I called Truma and they confirmed that for the combustion sensor it requires a new unit 😠
The shop found a refurbished unit that comes with a one-year warranty and will install once it shows up. The worst part is RV shows sell the units at their own retail price, which in my case is a 40% markup from Truma's own MSRP! The said they can't adjust their price but did cover the $450 overnight shipping charge to try and make up for it. So we have taken it on the chin in this case for this incident. I just hope Truma stays stable for us now and we can enjoy our long trip.
  • Sad 1
Todd & Kat
Thanks for the update.  Unfortunately Truma doesn't publish all of the error codes and it can add additional stress to an already stressful situation when you have failures on the road so it's good to document them here. Sadly often times, as you've found out, there is little that can be done as an owner to fix these appliances being that Truma equipment is extremely proprietary, they won't sell repair parts to owners and they require that all repairs be done only by certified Truma technicians. The problem of course is that Truma service centers are few and far between which is a problem when you're stranded on a trip.  I will say that their service centers are top notch if you can make it to one of those locations.
I haven't experienced your error but I did experience an E5H error code at one point which at the time was not documented anywhere. The response from the Truma service person was; "ionisation voltage recognized during standby mode.  Could have been from a solenoid sticking for a moment due to moisture on the sensor, or a voltage spike".  As it turned out the service person was correct and it was simply moisture on the sensor which I was able to dry out.
The other unfortunate thing about Truma appliances is that often times the "fix" is to replace the entire unit no matter how simple or inexpensive the failed component is. Along those lines the unit to replace the failed unit is a refurbished unit of unknown age / history.  The unit will be "factory certified" so there is that but be sure to fill out your warranty card!
Hopefully you'll be good to go and you won't experience any further problems.  Enjoy your trip!
Agree to all that. The shop has been good to work with and I have called Truma a few times as well. But sadly yes, Truma does not allow any internal part of the VarioHeat to be replaced, even by their certified tech. The full unit has to be replaced 😞
It does sound like moisture and corrosion is the main issue with the VarioHeat. One suggestion is to run the heater every couple of weeks to help "dry it out" when high level of moisture /humidity is present.  I am curious how you dried out your sensor?
Todd & Kat
Interesting story: I actually had fixed the problem before I got the official description from Truma due to the time of day that I had the failure.  I had been driving through a raging rain storm during the day, ended up at a campground near Allentown PA in early January 2024. Temperatures dipped to freezing , set up late evening  at 4 County RV Park that night and could not get the furnace to run. Because I had driven all day in the pouring rain I suspected that water may have entered the exhaust / inlet port of the furnace.  I could find no description for the error that I was getting in the documentation or on line.  I decided to take a hair dryer and blow warm air into the furnace exhaust / inlet port and after several minutes I was able to get the furnace to fire up ( luckily ).  Called Oliver the next day and they had no listing for the error.  I then put in a ticket with Truma and I got an email a day later explaining what the cause may be.  I haven't had the problem since.
If this ever happens to me I will certainly be looking to change brands. Are there any other options?
Good idea, Dennis! It irks me that Truma doesn't support sales of repair parts for DIY, only OEM installations. "They don't sell a listed part in the US market!" This is just not right. I'm very happy after reading 100+ posts re Truma issues (mostly their HWH) that we have no Truma products in or on our hull. It would be good to have a planned upgrade path vs. waiting until you get stuck.
There are posts here on replacing the Truma hot water heater but I do not recall any re the furnace. Based on a quick look, their furnace design is not standard to Dometic and other RV furnaces so installation could be tricky. And from what I've read here, the ducting may also be different.
Our hull came with a Dometic furnace and after two complaints of it "being noisy" on a second 2020 visit to OTT service, the work order stated, "Replace Dometic furnace with Atwood." After replacing some worn flexible duct work with rigid, deleting the underbed duct, adding an return duct filter and basement vents, our furnace is relatively quiet and has always run well (knock on forehead)! 🤣
Chatted with another owner who reported the same error code in Facebook. They tried the hairdryer hot air blown up the vent. No luck for them 😞
Hard part about switching out is everything is controlled via the Truma control panel. So putting in a new furnace is no small tasks. Will wait until I am closer to mothership to consider an undertaking like that.
Todd & Kat
