Imelda, Thanks for the update, and I’m glad you’re able to get home with things as they are. Just a quick reminder—the jacks don’t receive their power from the converter, but more of a direct connection from the batteries through the 60 amp Optifuse shown in my above image.
TV: 2019 F-150 Super Crew Lariat, 3.5L EcoBoost, 10 Speed Transmission, Max Tow and Offroad package.
Oliver: 2022 – Hull 953, Twin Bed, with Lithium Platinum Package (640ah Lithionics lithium batteries), Outdoor Pro Package, 16” wheels, D52 axles, 5-leaf Alcan Spring package, Bulldog HD Shock Absorbers, 2 5/16 Bulldog coupler and LT tires.
After market: Victron MultiPlus-II 4000, Two Victron 100/50 MPPT Solar Charge Controllers, Victron IP65 500A/50mV SmartShunt, Victron Lynx Distributor, Orion DC – DC charger, Cerbo GX MK2 with GX Touch 70 Display.
Misc: Custom Wood Accessories by Foybles. Seabiscuit Metal Designs front storage box and moose rack.
1 hour ago, Imelda said:
the 60A fuse is good just checking the low resistance (not the voltage but I will) across it.
Does this mean the "fuse is good?" it's certainly not a conclusive test and it doesn't mean there's a 12V source connected to the breaker. +12V on the source side of the breaker shows you have connection to the batteries. +12V on the load side shows the breaker is closed providing a power connection to the bus.
I am starting to suspect the converter.
A dead (or disconnected) converter will only keep you from recharging batteries when connected to shore power. A running converter is not required to operate lights, the jacks or anything else 12VDC. Converter status is independent of these 12V loads getting power from the batteries.
4 hours ago, Dean and Mary said:
jd, thanks for sharing the photo of your original 12‑volt distribution. It’s definitely cleaner than what my original setup looks like. I’ve attached a photo of mine—minus the 8‑gauge input wire. I’m in the middle of replacing everything and wanted a picture before I completely disassemble it.
On my install, there are two wires on the input side of the Optifuse (not counting the main 8‑gauge battery feed that’s been removed). I haven’t traced them yet, but I suspect one may be for the breakaway switch. I don’t want to hijack the thread until the main issue is resolved, but identifying these wires would save me some time.
Dean, WOW! I've seen some strange wiring but what happened here? Did they run out of buses on install day? The installer just bolts everything to the breaker, OMG! 🤣
BTW, this is the famous Optifuse! Many of these have failed, so that OTT has stopped using them! Search the Forum for keyword Optifuse. I'd be surprised if this isn't the answer to the issue of this thread, since everything not working, lights, jacks etc. is connected to this breaker. Do yourself a favor with your upgrade and replace the Optifuse breaker with an 60A ANL fuse and holder. Oh, and add a +bus, LOL!
Back in 2016, OTT used Bussman breakers (at least on our hull). They installed a 40A for all 12VDC lighting, jacks, etc. (pictured above) and a 30A Bussman for the rooftop solar. Keeping things standard, I purchased a 35A Bussman breaker to protect the Victron MPPT 100|30 SC that I added for our 400W Renogy suitcase solar.
Three Bussman breakers, 2 of them 11 years old, the new one 2 years old, no issues. ANL fuses are more reliable as you certainly know when they are blown (always have a spare). Fuses will blow when there's too much current on either side of the fuse. Breakers are directional, so they only protect on the load side of the breaker.
I have no idea what your two black wires are on the source side of your breaker. Trace them back if you can. If not, I'd wire them to a new bus with everything else. I have no wires before a breaker anywhere, meaning power to the breakaway switch on our hull does pass though the 40A breaker (OTT had not wired this to code). I know the breakaway switch works because I pull it to test for amperage to the brakes.
When I moved these breakers to the dinette area, I found the wiring from the jack fuses to all 3 jacks ran towards the dinette area first (was surprised since one jack is right there and the curbside jack is another direction). I removed all that excess wire and removed 3 butt connectors on each of the 3 wires along the way. I crimped one fresh butt connector on each of 3 much shorter wires to clean things up. 😎
Edited by jd1923
20 hours ago, Hokieman said:
Did you see the manual?   It’s got over a dozen diagrams in it, I just did a snip of one of them.   Most of the circuits are shown.
Thank you. I had not checked out the 2019 Oliver Manual before. I just downloaded a copy. I see many differences comparing our older hull but still can be helpful.
Thanks for the detailed response. I agree—the wiring is a mess, and that’s exactly why I’m redoing all of it. I did not know about the failure rate of the Optifuse. I’m also curious about the maximum of three wires on a lug, and why there are two connections ahead of the Optifuse. For my upgrade, I’ll be using the Victron Energy Lynx Distributor with ANL fuses.
Those are probably the emergency breakaway switch for the breaks and the CO monitor.  They take a direct feed from the battery.
Thanks Snackchaser, that makes sense.
i got back home fine and with a voltmeter i did some more checking and there is 13V coming out of the batteries, I checked but there’s no 12 V on either size side of the optifuse. The fuse is good as i checked with ohmmeter. There is a one amp in line fuse I also checked it’s good also. the 2000 inverter is turning on fine and turning on the microwave and all the stuff that runs off the AC so it’s puzzling why there is no 12V DC power in the trailer. there has to be a  bad fuse or switch somewhere. I am going to try to reach out to OTT but it usually takes them a while to get back to me. any other ideas?  could a fuse be blown in the inverter.
Imelda Donnelly, Oliver Elite 2, Hull 642 year 2020 pulled with 2022 Nissan Titan
I'm a little confused because you've said there is no power on either side of the optifuse, but you've also said that it tests good?  Also, you mention a 2000 watt inverter, where you talked about a converter before.  These are different things and wired differently.  BTW, a 2000 watt inverter should have another ~200 amp breaker or fuse between the inverter and battery.  That's not the problem, but you should be aware of it.  Mine is mounted on the vertical wall above the inverter.
At any rate, the battery and/or the inverter both feed the 12 volt panel (and jacks) via the 60 amp optifuse breaker.  Re-check it for 12v from each terminal to ground.  There are grounds all over the place in that area, the jack post, trailer frame, or the inverter chassis will work.  If there is voltage on the line side, but no voltage on the load side, then you have a bad breaker.  These breakers are readily available, and the failure rate is pretty low for the millions of them out there.
Edited by Snackchaser
On 10/9/2026 at 5:44 PM, Hokieman said:
I saw a previous post from you that indicated you had LiTime batteries installed by a technician. Did they by chance install an ANL fuse or a circuit breaker?
3 hours ago, Imelda said:
i checked but there’s no 12 V on either size side of the optifuse.
There must be a direct positive (+) battery connection to the Optifuse. Geoff ask you to retest, but when you're certain there is no power on the battery side of the breaker (or both sides) then the +battery cable feeding the Optifuse is either 1) disconnected, 2) switched OFF or 3) has an added inline fuse that is blown. You must have an open circuit for there ot be no power on "either side of the optifuse."
OTT in their OEM build did NOT add a switch or redundant inline fuse in this circuit. The Optifuse is the breaker that protects your batteries from shorts in ALL DC lighting and appliances (all DC loads).
If you have anything but a solid stretch of 6 or 4 AWG between the Optifuse and your batteries it must be an aftermarket installation, perhaps something was added during April 2025 when you had LiTime batteries installed.
Your solution is simple. Just follow the battery cable from the Optifuse to the batteries. Given your Optifuse is under the streetside bed, the cable will run a whole 5 ft total, first under the pantry area, then up through a drilled hole/grommet into the battery bay, then connected to a positive battery terminal. Your "Tech" could have added a +bus somewhere interior, if so test for +13V there.
But if the retest shows +13V on the battery side, but NOT on the load side of the Optifuse, then replace the Optifuse with a 60A ANL Fuse.
There are no other possible causes for the full loss of DC power in the Oliver.
You either have an open circuit in the battery cable or a bad Optifuse breaker.
Edited by jd1923
i think i checked all the fuses on the 12V line and they appear good but there is this connector on both the positive and negative wires coming from the batteries to the fuses and i wonder if they are open circuit.  I have never seen this type of component before. is it a connector or fuse or what but it goes to the fuses where i cannot get any voltage reading of any kind even though the fuses test good  what is this type of connector for?
All i found the problem. a loose battery connection. i feel like an idiotic not checking it first. sorry i wasted a lot of your time. i am good to go now.
No worries!  It gives us something to do!  That is a Wago connector to splice two wires together. It has little levers on it so that you can pull the wires out.  Other connectors might look similar, but without the lever, and the wires won't come out!
Glad you found it!  Happy camping!
About two weeks ago my wife reported to me that her cloths dryer was not working.  After a quick inspection I called an appliance repairman who explained that there was a short in the heating elements and/or an internal relay - neither of these parts were available for a repair.  So, off to Lowe's we went and spent $2,000 on a new washer and dryer (had to get the pair due to them being "stacked" in the laundry room.  A few days later once again my wife got my attention by saying that once again the "new" dryer was doing the very same thing that the old "broken" dryer did!  This time I suspected that the circuit breaker was faulty, so, I removed the cover panel from our sub-panel "A" and inspected the breaker and wiring closely.  Yep - one of the wires entering the circuit breaker for the dryer was loose.  Odd that none of the other wires were loose and that the loose wire showed virtually no signs of heat.  But, a five minute "fix" was all it took to solve the problem.  However, obviously, it was too late to get the old dryer back let alone the $2,000.
What are the odds that your battery cable was loose?  What are the odds that a single wire into a breaker was loose?  At least yours didn't cost you $2,000.😵‍💫
I'm going to save $2000 and a week of troubleshooting and check the last issue first.  I always start at the bottom and not from the top.  So silly.
I could not wait to see what happened, but I read the entire thread.  Still, we all learned something. 😉
Was that a loose or completely disconnect battery connection?
Chris
o-o  2016 Legacy Elite II (demo) - Hull #110 -"Rock'in 110"
o-o  2024 Ford F-250 Lariat, 7.3L Godzilla gasser
o-o  Augusta, Georgia
