During winterization (which makes me sad but thats a different topic), I found the strap holding the Truma water heater had broken on both sides in very symmetrical locations.  Easy to splice on a new strap but how did the failure happen?  I suspect these are fatigue failures and thus that same strap material is the wrong fix.  I also am not completely certain of the complete purpose of the strap other than to restrict the back of the water heater from jumping around.  Thoughts?
Ours did the same thing, hull #1373. I replaced and added additional screws on the sides. We'll see if they hold up longer than the original strap.
Oddly, ours did as well. It seemed like pretty soft strapping material.
Steve - Northern Ohio, USA
Facebook - Instagram
I am not a Truma guy, but PLEASE submit a ticket to OTT on this.  In my eyes this is a clear safety issue as unrestrained movement of this machine could impace one of the gas lines down there and cause a BOOM with your family personally involved.
OTT certainly used the wrong material. Is the Truma heater currently hanging by the faceplate only? Better materials must be used for this application. This strapping material is for hanging pipe without a strength rating at only 28-gauge. Don't buy this stuff:
https://www.homedepot.com/p/Oatey-3-4-in-x-25-ft-28-Gauge-Galvanized-Pipe-Hanger-Strap-33530/301505501
Go with Simpson Strong-Ties made in the USA. You could mount two hard corners with straights or use their Coiled Strap. This item is 16ga and should be extremely strong. I have a coil of their lighter 22ga. I doubled the ends at mount points and used it to strap our inverter against the basement wall. The 22ga might be strong enough for this case but I promise the 16ga will be harder to bend but would never fail. They have an array of thicknesses, chose from 12, 14, 16, 18, 20, 22 gauges. The lightest 22ga is thicker, wider and stronger than what OTT installed. Buy this instead:
https://www.homedepot.com/p/Simpson-Strong-Tie-CS-25-ft-16-Gauge-Galvanized-Coiled-Strap-CS16-R/100375320
Edited by jd1923
FloraFauna, Ollie-Haus, and Steve:
PLEASE today take the time to send OTT a safety ticket on this topic.
I have alerted Jason E off line.  But the system should be documented with your inputs and how you chose to fix your discovery.
My second worst fear is that other owners who do not read this forum will not know about this hazard.  To them, the only way they may become aware is if an OTT Tiger Safety Team gets the word out.  Your personal input is needed for that.
My WORST case fear is that a Truma trailer with this banding gets a cracked gas line and over time leaks enough gas for the interior to reach into the explosive range of concentration.   There are several possible ignition sources (I.E. some switches, Dometic three-way, or the gas heater) that could start a rapid disassembly event... with them inside.
Please share your experience with OTT via a ticket.
Thanks
Edited by Geronimo John
typos as usual....
Will do so on Sunday.  I assume over the weekend no one will see it.
Your worst case fear is not unreasonable.  But I have concerns now about how much movement was happening even when the banding intact.  Obviously one doesnt want the unit bouncing around relative to the plumbing both gas and water but some of that is probably happening anyway.  So how best to dampen out and restrict movement.  I think the strap fatigued from repeated vibration suggesting things are bouncing around there.  Just fyi, i am a pretty slow driver with no recollection of single severe jolts.
Edited by FloraFauna
Yeah I think so too which is why I posted.  I am debating in my head whether locking it down to the bottom with angles in the corners as you suggest OR would it be better to have a slight flexibility?  I am concerned the strapping was stressed to the extent of two symmetrical fractures - that's kind of weird.  I have to look closer but yes perhaps it is only being held by the face plate now and the plumbing (not good).  I am going to wait to talk to OTT service before pursuing a fix.
Were you able to do this without removing or loosening the furnace (in the bottom of my photo and allowing very little clearance around the one side of the strap)??
Depends on what you have to work with, how far you can reach under and around it. I’d like it bolted down sitting on rubber bushings vs floating with only a pipe strap keeping it from bouncing down the highway!
What a LAZY installation! An on-demand heater doesn’t have the 6 gallons/50 LBS additional weight so they figured, “let’s just hang it.” And “Figured” is a polite word for lack of installation procedure. Shows the state of “professional installations” in the trades today! 🤣
I'm pretty sure our water heater is sitting on the floor. It’s wrapped in a foam casing, so it’s hard to tell.
i understand what GJ is stating, but I’ve never received a company email re a safety warning in 3 years except the one time when they mounted a Bulldog receiver not 7K rated on one hull (was Bulldog’s fault for mis labeling their product).
They’re not going to give you repair advice. You got this! 😎
Edited by jd1923
The further back something is from the tongue, the rougher the ride is back there.  An unknowing driver's rear utilities on a washboard road can easily see 2 to 5 G's of verticle acceleration back there.  Which makes JD's statement that the wrong material used is on point.  I add to that that it was not properly engineered.  Hence care is needed in engineering a solution.  Hence the need for OTT's involvement.
The trailer axles and springs can help or hurt this issue.  Stiffer suspensions genarally makes payload shocks worse.  The exception is when the frame and axle slam together from having too soft a suspension.  Compliant suspensons help things a bit.  Having a heater hard mounted generally hurts.  Allowing it the ability to float a litte ... is good.... so long as all the attachments (such as controls, water and gas lines) are engineered to accomodate such movement as well.
Think about a wash board with bumps every 6" and 5 miles long.  That's generation over 10,000 fatique cycles every time you pass on it.  This is why so many people have trailer issues going to Alaska....
Bottom line is that the way your Truma's were secured was not up to the job.  And that's a real problem.   How big a one is TBD.  How many trailers have this very same issue and don't have a clue about?  I for one have never checked my Suburban hot water heater's attachment.  Dittofor the 3,000 watt Renogy, the furnace, and everything else hidden below decks.
Can I move the vertically?  If so, how much?   What's attached to that item and does it have the ability to flex enough not to become damaged.
When doing so, I will pay a LOT of attention to anything with a gas connection first.  Hence my "Safety John" approach to this topic.
I’ll send a pm regarding my fix.
