Cobra1169 Posted September 30, 2017 Posted September 30, 2017 I have finally had a chance to both tinker and document the modifications & customizations I'm making to my Oliver. This Teak Shower Mat is something I've had for years in my Airstream and really Like it to shoe marks in the shower. Purchased from Teakworks4u. $189 plus shipping. They have the Oliver LE II template in their system. 1
Cobra1169 Posted September 30, 2017 Author Posted September 30, 2017 This mod will most likely create the most questions and I believe is the single most beneficial addition I could make to my Oliver. BTW prior to joining Apple, I lead mobility enterprise solutions for 10 years with AT&T and I know what really works and what is just a gimmick from a cellular and wifi booster reference standpoint. CradlePoint Cellular Router: COR IBR900 Series https://cradlepoint.com/ products/cor-ibr900-series Here is why: Enterprise Commercial-Grade hardware Supports LTE-Advanced (next generation Cellular protocol - next 3 years Future Proof) Supports SIM-Based Auto-Carrier Selection built in 2 SIM trays expandable to 4. Allows you to have either more than 1 Cellular Carrier (AT&T, Verizon, T-Mobile, Sprint, etc.) or allows you do double up on SIMs from same Cellular Carrier to prevent throttling back or exceeding data plan. Fully Ruggedized and built for vehicle vibration, temperatures, etc. Intelligent remote configuration via Cloud Access Redundant Power Capable WiFi: Dual-band, dual-concurrent WiFi (802.11 a/b/g/n/ac)* Wave 2 External Mounted Antenna: 3-in-1 GPS & Modem Screw-Mount https://cradlepoint.com/ products/accessories/3-1-gps- modem-screw-mount Amplifies Cellular & GPS Reception by a full 5 watts (Cellphone & Tablets only 0.5 watts) Significant improves cell & GPS signal reception thereby giving you stronger signal strength and increased bandwidth throughput. Gives you priority ranking of network vs. cellphones, tablets, & consumer hotspot devices. AT&T Data Plan (Unlimited +) You also have the option to buy program month to month or prepaid. Only subscribe when you need to use it or add it to family plan Allows you to use your home DIRECTV account with no charge against your Data Plan or you can subscribe to DIRECTV NOW if you do not have DIRECTV at home. https://www.att.com/bundles/ data-free-tv.html https://www.att.com/bundles/ directv-now-unlimited-plus. html The Cradlepoint router will work as the nerve center for your Oliver. Providing you constant and consistent wifi coverage in about 98% of the US. Also, it gives you the ability to jump from carrier to carrier via a webbed portal. Now that you have WiFi all the time you now have a connected RV. You can use wifi to place wifi calls, FaceTime calls Video or Audio only. Stream video, Music, gaming to your Trailer via laptop, iPad, iPhone, or AppleTV, and stream Over the Air Directv without data charges if you are an AT&T customer. I may use devices inside trailer like Nest Protect battery version (Smoke & CO2 detector). You can hook up WebCams, and other home automation products that run on WiFi. I'll also run my iPads of the trailers WiFi vs the iPads embedded cellular receiver because the trailers wifi will always have a stronger signal than the iPads embedded cellular antenna. I will also run my MacBook via the trailers WiFi which is great for working on the road. 7
Cobra1169 Posted September 30, 2017 Author Posted September 30, 2017 Dependable Flashlight at hand and always in the same place... Olight r50 pro seeker $159 https://www.amazon.com/gp/product/B01MFBMCIG/ref=oh_aui_search_detailpage?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B01MFBMCIG/ref=oh_aui_search_detailpage?ie=UTF8&psc=1 1
Cobra1169 Posted September 30, 2017 Author Posted September 30, 2017 Umbrella anyone within reach and protected. I used a plastic fishing rod holder to secure the umbrella is a great location. 3
Cobra1169 Posted September 30, 2017 Author Posted September 30, 2017 Screen Door Bar. Credit for this idea goes to the Lukens!!!! Thank you!!! Purchased on sale at Camping World $9.47 2
Raspy Posted September 30, 2017 Posted September 30, 2017 Don't know why, but I can't open any of your pictures. 1 John "I only exaggerate enough to compensate for being taken with a grain of salt." LE2 #92 (sold), Black Series HQ19
Cobra1169 Posted September 30, 2017 Author Posted September 30, 2017 LevelMatePRO is a wireless vehicle leveling system that utilizes Bluetooth® 4.0 to connect with your smartphone or tablet. The system allows you to know how much height is required to reach a level position and where that height is needed. LevelMatePRO also allows you to save and recall your hitch position for quick and easy reconnects to your tow vehicle. It was designed for use with both driveable and towable vehicles. For driveable vehicles, the height required to reach a level position is displayed for each wheel so you can stack all of your blocks for each wheel and drive onto them once. Eliminate the trial and error associated with multiple attempts to get your vehicle level...level it on the first try! Recommended uses are RV's, mobile medical vehicles, food service vehicles, concession vehicles, mobile emergency command post vehicles, race car trailers, horse trailers and more. Simplify your vehicle setup, reduce setup time and increase safety with the LevelMatePRO system. Amazon $139.99 https://www.amazon.com/LevelMatePRO-Bluetooth®-Vehicle-Leveling-System/dp/B01FGGSWPW Hidden in the bulkhead above closet door very close to the center of the trailer. 1
Cobra1169 Posted September 30, 2017 Author Posted September 30, 2017 Custom-made Nautical themed bedspreads from Sumbrella material. The strips give the illusion of a longer interior. 2
Cobra1169 Posted September 30, 2017 Author Posted September 30, 2017 Crucifix for spiritual oversight and as a reminder to pray for our many blessings. 3 1
Cobra1169 Posted September 30, 2017 Author Posted September 30, 2017 Marinco EEL Pigtail Adapters. Allows me to plug into a standard 110 in my storage unit and run A/C (thanks, easy-start) and lighting, etc. I have a bucket under the A/C drain not to flood out my concrete slab in the storage unit. I love the built-in flashlight and quick grip lock no more misthreading outlet $63.84 https://www.amazon.com/gp/product/B009IJJLZO/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1 2
Cobra1169 Posted September 30, 2017 Author Posted September 30, 2017 110 Outlet Surge Protector for Storage Unit. Tripp Lite Isobar 2 Outlet Surge Protector/Suppressor, Direct Plug-in, & $10K INSURANCE (ISOBLOK2-0). Amazon $22.76 https://www.amazon.com/gp/product/B0000510R4/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1 1
Overland Posted September 30, 2017 Posted September 30, 2017 I'm curious if the CradlePoint WiFi is strong enough to reach the vehicle. Is the antenna that you had on the back of your Ollie part of the CradlePoint package or is that from a third party? I dig the umbrella stand. I'll have to look into the LevelMate - it sounds like a great solution especially when traveling solo.. 1
Cobra1169 Posted September 30, 2017 Author Posted September 30, 2017 Here is a great one that I learned from the Marine Industry: Viking Composite LP Tanks 22 Pounds each. Half the weight of steel tanks and they do not rust. Plus they are see-thru so you always can visually inspect your propane levels. Does require you to install an RV mount tray in place of the standard mount since these tanks have a flat bottom. Tanks were $149 each on Amazon and RV Mount is $40 direct from Viking Cylinder web store. 4
Cobra1169 Posted September 30, 2017 Author Posted September 30, 2017 They may be large file size pictures and take a while to upload. 2
Cobra1169 Posted September 30, 2017 Author Posted September 30, 2017 Overland, CradlePoint does have a 5in1 antenna on their website that amplifies both the Cellular, GPS, & WiFi signal which would be more than capable of reaching your tow car and a 50-yard radius around your trailer. The antenna is made by Pantheon Antenna SKU: 170654-000. I PM'ed you additional info. Thanks --- Jim 1
Kayrae51 Posted September 30, 2017 Posted September 30, 2017 Nice job...I really like your modifications & additions! I’m going to check out your wifi set up for sure. We have had the TeakWorks4u shower mat on our ‘wants’ list since we ordered our Ollie....great to see one in an Oliver! Are your 22# propane tanks larger/taller than the standard steel 20# tanks? We currently have 30# tanks in ours - the weight difference is awesome. Thanks for sharing! Clair & Kathy Reed - plus our travel companion: Emma 2017 Legacy Elite II - Hull# 245 2014 Ram 1500 3.0 V6 Eco-diesel 4x4
Cobra1169 Posted September 30, 2017 Author Posted September 30, 2017 They are approximately the same size as a 30lb steel propane tank. I also think that the lighter weigh help reduce young weight as well. Here is the comparison: Viking Cylinder 22 lbs - Gallons: 5.24 Height: 22.5" Diameter: 12" 17 lbs - Gallons: 4.20 Height: 18.3" Diameter: 12" Standard Steel Propane Tank 20 lbs Steel Tank Gallons: 4.7 Height: 18" Diameter: 12.5" Weight Full: 37 lbs 30 lbs Steel Tank Gallons: 7 Height: 24" Diameter: 12.5" Weight Full: 55 lbs 1
KarenLukens Posted September 30, 2017 Posted September 30, 2017 Nice job…I really like your modifications & additions! I’m going to check out your wifi set up for sure. We have had the TeakWorks4u shower mat on our ‘wants’ list since we ordered our Ollie….great to see one in an Oliver! Are your 22# propane tanks larger/taller than the standard steel 20# tanks? We currently have 30# tanks in ours – the weight difference is awesome. Thanks for sharing! Using the shower mat really depends on how tall of people will be showering. At 6'1" we took ours out and gave it away because I could no longer stand up in the bathroom, I prefer the bare white floor for the most room when using the bathroom, plus it's a quick rinse if you bring mud in. Reed Did you put your awning crank in the closet Cobra? 1 1 Happy Camping, Reed & Karen Lukens with Riffles our Miniature Poodle 2017 Oliver Legacy Elite II Standard, Hull #200 / 2017 Silverado High Country 1500 Short Bed 4x4 Past TV - 2012 Mercedes-Benz ML350 4Matic BlueTEC Diesel Click on our avatar pic above to find the videos on our Oliver Legacy Elite II
Cobra1169 Posted October 1, 2017 Author Posted October 1, 2017 Reed, The factory installs the Carefree awning crank now in the closet since it has the bend in the handle it no longer fits between the closet & entry doors. Also, I listed the dimensions of the Viking LP tanks above for reference. Thanks --- Jim 1
DavidS Posted October 1, 2017 Posted October 1, 2017 Cobra1169, Great post!! I use the WiFi Ranger to create my own local network, but the CradlePoint looks really interesting, as do the Viking Composite LP Tanks. These will go onto my wish/research list! I love the idea of an umbrella! One will definitely be going into my Ollie! We got the Teakworks4U shower mat after Malcolm Monlezun posted about it. My wife was lukewarm about the idea before I ordered it, but now she really likes it. The teak mat is very nice, both functionally and esthetically. David Stillman, Salt Lake City, Utah 2016 Oliver Elite II Hull 164 | 2017 Audi Q7 tow vehicle. Travel and Photography Blog: http://davidstravels.net
Moderators Mike and Carol Posted October 1, 2017 Moderators Posted October 1, 2017 Great mods! I’m especially interested in the propane tanks. I like the weight reduction and being able to visually check the level. Your CradlePoint install is something I’m going to look at too. Thanks for posting these. Mike Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
rideadeuce Posted October 4, 2017 Posted October 4, 2017 Hi Jim, This may be a silly question but is there any way to mount 3 in 1 antenna without drilling through hull? And would it be simple enough for me to direct wiring down from top myself. Just wanting your opinion. Thanks, Mike - Mike Brentwood, TN - 2018 Elite II - Spirit of Adventure Hull #308 - 2016 Toyota Tundra Limited 5.7L Class IV hitch with 12k lb coupler, Weigh safe adjustable trailer hitch, Dobinsons HD 2in Leaf springs, Timbren bump stops, Dobinsons 3in coilovers and UCAs, Mechman 370 amp HO alternator. Oliver upgrades: Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp DC/DC charger with Anderson connections, Toshiba 6-in-1 Microwave oven - air fryer combo, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar on top, Custom aluminum bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires, Seabiscuit Metal Designs front storage box and moose rack.
Kayrae51 Posted October 4, 2017 Posted October 4, 2017 Using the shower mat really depends on how tall of people will be showering. At 6’1″ we took ours out and gave it away because I could no longer stand up in the bathroom, I prefer the bare white floor for the most room when using the bathroom, plus it’s a quick rinse if you bring mud in. Reed ———————- I remember you mentioning these points about the shower mat in a previous post. I am short so the added height won’t be a problem but you do bring up a good point re: mud & dirt. Thanks Reed Clair & Kathy Reed - plus our travel companion: Emma 2017 Legacy Elite II - Hull# 245 2014 Ram 1500 3.0 V6 Eco-diesel 4x4
MikeandGerri Posted October 4, 2017 Posted October 4, 2017 Great mods!!! Thanks so much for sharing!! 1
