Moderators topgun2 Posted April 29, 2018 Moderators Share Posted April 29, 2018 Over the past two weeks I have greased the EZ- Flex suspension. Absolutely no problem except for one zerk - street side rear. Loading and unloading the suspension has had no effect - it still will not accept grease. Any ideas on the best way to correct the problem? Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC Link to comment Share on other sites More sharing options...
Mainiac Posted April 29, 2018 Share Posted April 29, 2018 For a 'plugged' grease fitting I usually try the following: clean the fitting and the immediate area around it. Then we spray P B Blaster and wait a few minutes. Then try to grease. If it still doesn't work we warm the fitting with a heat gun on low (a hair dryer probably would work too). That should warm the old grease enough to allow new to enter. Last resort is to screw in a new fitting. A pain sometimes, but better than not getting grease in there. How much grease did all 16 (15) take? 2 Link to comment Share on other sites More sharing options...
GaryJona Posted April 29, 2018 Share Posted April 29, 2018 You can probably unscrew it they will come out and try to clean it out or take it up to the auto parts store and buy a package of a few replacement ones and crew in a new one. They will have them straight as the ones that came on the suspension kit or you can also get some that are at a 45 degree for easier use for some areas. The reason I said to take it up as they cmd in different sizes. Good luck Gary 2 Gary & Jona 2016 Silverado 2500 Diesel Legacy Elite II Hull 81 Link to comment Share on other sites More sharing options...
Mainiac Posted April 29, 2018 Share Posted April 29, 2018 Also there is a tool available that you put on a fitting that you then tap with a hammer. It forces in an oil or air to break up/move along hardened grease. They should be available at most any auto parts outlets, maybe even Tractor Supply type stores or even Harbor Freight, though we have not checked... Link to comment Share on other sites More sharing options...
Moderators topgun2 Posted April 30, 2018 Author Moderators Share Posted April 30, 2018 Thanks guys! I've always simply replaced zerks when I've run into this problem but they've always been on old crusty nasty things. With this being on a less than one year old unit with no signs of dried out old grease I figured there just had to be another way. Bottom line - I'll just replace it. Over the past two weeks I've greased two separate Elite II's with the EZ-Flex. I started with a brand new 14 oz tube of grease and there is still a bit left in the tube - probably about 2 or 3 oz. This job probably could be done with less grease, but there is not much to be lost by over-doing it a bit. Interestingly on one job the zerks were placed on the inside so that you had to crawl under the camper to do the job while (on mine) the zerks were placed to the outside. With the zerks on the outside I didn't have to crawl under but with the tires in place, it can be a slight job in getting the flexible grease gun tube firmly and directly aligned to the zerk. And, the two (on each side) that are directly above the "rubber" between the tires had to be done more by "feel". While I was at it I placed "caps on each zerk in order to keep them a bit cleaner - primarily for when this job is done while out on the road. https://www.amazon.com/gp/product/B0040CWX7C/ref=oh_aui_detailpage_o04_s02?ie=UTF8&psc=1 Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC Link to comment Share on other sites More sharing options...
rideandfly Posted April 30, 2018 Share Posted April 30, 2018 Thanks guys! With the zerks on the outside I didn’t have to crawl under but with the tires in place, it can be a slight job in getting the flexible grease gun tube firmly and directly aligned to the zerk. And, the two (on each side) that are directly above the “rubber” between the tires had to be done more by “feel”. Bill, Installed six pins per side with zerks pointing out for easy access. Built a grease gun stand out of 2X4s for Coy, also pointed his pins/zerks out. Sent him an email to see if he will bring the grease gun stand to the Rally, it works nicely for zerks pointing out. Bill & Debbie / 2015 LE2 #75 / 2024 F-150/5.0L / North Carolina Link to comment Share on other sites More sharing options...
Mainiac Posted May 6, 2018 Share Posted May 6, 2018 Zerks pointing out...if your zerks were installed that way, how much of a problem is it to swap them around? Any safety issues? Link to comment Share on other sites More sharing options...
Moderators topgun2 Posted May 8, 2018 Author Moderators Share Posted May 8, 2018 I talked ( at length) to the Dexter rep at the 2018 Rally this past weekend about the problem with the "plugged" zerk. He said that the assembly into which the zerks are threaded come to Dexter with a (plastic) film covering the "tube" that goes from the zerk into the bushing reservoir. While it shold be removed prior to installation, there have been times when that film simply didn't get discarded. This is probably what happened in my case. The fix is simple - take the zerk off, insert a thin piece of wire into the tube behind the zerk and clean it out by moving the wire back and forth (wiping the wire off several times as you are doing this). Screw the zerk back into place and all should be well. On a related topic - when re-greasing the EZ-Flex, only pump enough grease into the zerk so that you can barely see grease coming out of the bushing. Any more than that is a waste of grease. There are no "seals" in these bushings, so, there is nothing to hurt. According to the Rep - the actual primary job of the grease is to help dissipate heat with the secondary function to actually lubricate. Bill 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC Link to comment Share on other sites More sharing options...
geO Posted May 8, 2018 Share Posted May 8, 2018 I was told from Oliver service guys that all I need to do was take some pressure off the suspension by raising the stabilizer jack and that did the job. I had 2 fittings that would not allow any grease. Link to comment Share on other sites More sharing options...
Moderators topgun2 Posted May 24, 2018 Author Moderators Share Posted May 24, 2018 Just to sort of put a period at the end of this "zerk" sentence - I finally got around to taking a look at the original Zerk that I replaced. There was no sign of any foreign material inside it, but, when I applied pressure to the inlet, the little ball bearing seal simply would not release. So, I got an appropriate sized nail punch, applied pressure and still no give - a light tap with a small hammer was what it took to get any movement. However, now it appears that this zerk is back to working as "normal". I'm not sure what got it stuck but it works now. Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC Link to comment Share on other sites More sharing options...
choied Posted October 20, 2019 Share Posted October 20, 2019 Hi, did you replace the fitting and if so, what was the size of the zerk fitting on the Dexter suspension? Have one bad one myself so I was looking to replace it, so I could get some grease in it... 2016 RAM 2500 LARAMIE MEGA CAB 4X4 2017 OLE2 - King Bed - Hull # 253 Link to comment Share on other sites More sharing options...
choied Posted October 20, 2019 Share Posted October 20, 2019 I jacked up and down, every which way, but there was one fitting that simply wouldn't accept any grease. In a closer look at the fitting it looked like the opening was stuck. Need to replace or repair this fitting. What a waste of good grease. LOL. 2016 RAM 2500 LARAMIE MEGA CAB 4X4 2017 OLE2 - King Bed - Hull # 253 Link to comment Share on other sites More sharing options...
Moderators topgun2 Posted October 20, 2019 Author Moderators Share Posted October 20, 2019 Choied - When it came time to replace the one I found "bad", I happened to have one that was the correct size in my spare parts bin. So, I really don't know what the size is - sorry. Unless someone chimes in here shortly with the correct size I would simply call service tomorrow morning and ask. Or, take the old one down to your local NAPA type store and have them check the size. Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC Link to comment Share on other sites More sharing options...
rideandfly Posted October 20, 2019 Share Posted October 20, 2019 I jacked up and down, every which way, but there was one fitting that simply wouldn’t accept any grease. In a closer look at the fitting it looked like the opening was stuck. Need to replace or repair this fitting. What a waste of good grease. LOL. Choied, Have some Dexter pins, Dexter bushings and 45 degree fittings on the shelf to look at. The Dexter pin takes 1/4"-28 thread grease fitting. Ours came with straight fittings, but 45s could be used, too. Hope this helps. 4 Bill & Debbie / 2015 LE2 #75 / 2024 F-150/5.0L / North Carolina Link to comment Share on other sites More sharing options...
