geO 14 Posted November 16, 2018 Share Posted November 16, 2018 I changed out a propane bottle today and was surprised to see the indicator gauge stuck on red when I opened the valve. Wonder if anyone else has had this happen and found this on amazon. https://www.amazon.com/Fairview-Propane-Automatic-Regulator-Pigtails/dp/B071D1SYLY/ref=pd_day0_hl_86_3?_encoding=UTF8&pd_rd_i=B071D1SYLY&pd_rd_r=21b994f9-ea00-11e8-9f7e-2132386dfc7d&pd_rd_w=epuul&pd_rd_wg=MeUy1&pf_rd_i=desktop-dp-sims&pf_rd_m=ATVPDKIKX0DER&pf_rd_p=ad07871c-e646-4161-82c7-5ed0d4c85b07&pf_rd_r=PAX5QKSHA5TE7S5WGH3E&pf_rd_s=desktop-dp-sims&pf_rd_t=40701&psc=1&refRID=PAX5QKSHA5TE7S5WGH3E Think changing the hoses might not be a bad idea as well. Link to post Share on other sites
geO 14 Posted November 16, 2018 Author Share Posted November 16, 2018 I've noticed my propane hoses are very stiff and I'm thinking they present a possibility of leaking when changing out bottles. Does anyone change these out once a year? Link to post Share on other sites
Moderators ScubaRx 280 Posted November 17, 2018 Moderators Share Posted November 17, 2018 I changed out a propane bottle today and was surprised to see the indicator gauge stuck on red when I opened the valve. This sounds like normal operation. When the bottle is empty and it auto changes, the indicator goes red to let you know that one is out of propane. Same thing happens if you unhook a bottle. The valve sees that hose as empty. Steve, Tali and the dogs: Reacher, Lucy and Rocky plus our beloved Storm and Maggie (both waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, HULL NUMBER: 0026 2014 Legacy Elite II - Outlaw Oliver, HULL NUMBER: 0050 2017 Silverado High Country 2500HD Diesel 4x4 Link to post Share on other sites
Moderators Overland 1,227 Posted November 17, 2018 Moderators Share Posted November 17, 2018 I’ve had mine stick on red after swapping tanks. Turning the valve off and on again has always reset it. Having a backup regulator and set of pigtails is a good idea, and if you carry a set of pigtails then I think inspecting them for cracks and leaks is probably sufficient, rather than replacing them every year. I’ve seen solid copper pigtails for sale. Snowball • 256 • 2018 Ford Raptor Link to post Share on other sites
geO 14 Posted November 17, 2018 Author Share Posted November 17, 2018 Mine stayed red and will not allow any propane to pass through into the Oliver. Link to post Share on other sites
Moderators topgun2 952 Posted November 17, 2018 Moderators Share Posted November 17, 2018 George - If this were mine I would first remove and then reinstall both tanks. Then I would move the switch over lever back and forth a few times. Then, assuming that neither of the first two have corrected the problem, I would GENTLY tap the pressure regulator and move the switch over lever. Of course I am assuming that you are sure that you have propane in the tanks and that the tanks are in the "open" position. If none of this works and your operating temperature is not too cold, I would then assume that you have a bad regulator and would replace it. Good luck! Bill 2017 Ford F150 Lariat 3.5EB FX4 Max Towing 2016 Oliver Elite II - Hull #117 "Twist" Link to post Share on other sites
geO 14 Posted November 17, 2018 Author Share Posted November 17, 2018 Thanks for the reply Bill. I did exactly what you said yesterday and still stuck on red. I refilled one tank yesterday and the other was not completely empty. When I changed over it than went red. Got another regulator coming from Amazon. Link to post Share on other sites
Moderators topgun2 952 Posted November 17, 2018 Moderators Share Posted November 17, 2018 George - Bummer! These regulators don't go bad very often (at least in my experience). In all the campers I've had over the past twenty years not one of them has failed. I don't use the "automatic" switch over feature in that I prefer to know when a tank is emptied. Certainly there have been times when cold weather was forecast for the night and I knew that the tank I was using was getting low on propane. In these circumstances I simply switched tanks before going to bed and then switched back the next morning. There was only one time when the red window failed to turn green and that was corrected by shutting off the full tank and quickly turning it back on. Obviously it is that change in pressure that is causing the window to show the green and it would seem that yours got stuck for some reason. I'm sure that they could be repaired but I would also think that for the price of a new one the repair cost is probably at least as much money - if not more. I hate adding to the landfill but that is the way it is particularly since even finding someone qualified to work on one of these is problematical. At least the removal and install of the new one is not difficult. Just be sure to use sealing tape or compound. Bill 1 2017 Ford F150 Lariat 3.5EB FX4 Max Towing 2016 Oliver Elite II - Hull #117 "Twist" Link to post Share on other sites
Moderators topgun2 952 Posted November 17, 2018 Moderators Share Posted November 17, 2018 Mark - I thought of that but didn't think that it was very likely for both bottle to get stuck at the same time. However, I've heard of stranger things and it is worth a check. Bill 2017 Ford F150 Lariat 3.5EB FX4 Max Towing 2016 Oliver Elite II - Hull #117 "Twist" Link to post Share on other sites
geO 14 Posted November 17, 2018 Author Share Posted November 17, 2018 I just got back from trying that method Mark and it's a no/go... It was worth a try though and appreciate the article. Link to post Share on other sites
dbp05ret 21 Posted October 7, 2019 Share Posted October 7, 2019 Had a 30 pound propane tank filled today. I placed it back in the Oliver. I turned it on slowly and lighted the stove in the Oliver to bleed any air out of lines. The regulator gauge turned green. After turning the stove off, it went back to half green and half red. I retried and always got the same. The other tank shows solid green when I try it What have I done wrong? Why is it half green and half red? Link to post Share on other sites
Moderators topgun2 952 Posted October 8, 2019 Moderators Share Posted October 8, 2019 Have you tried switching the position of the tanks? Also, I noticed in your pics that the control lever is pointed to the left in both pics - I assume that you have moved it to the right and then back to the left just to see if you still get the half red indication? Bill 2017 Ford F150 Lariat 3.5EB FX4 Max Towing 2016 Oliver Elite II - Hull #117 "Twist" Link to post Share on other sites
dbp05ret 21 Posted October 9, 2019 Share Posted October 9, 2019 Bill, It took me numerous attempts and the regulator gauge is now showing solid green. I kept lighting the stove to clear any possible air from the gas lines. The propane regulator indicator gauge would go green and then go to half green/red upon turning the stove burners off. I did this about 6 times. Somewhat baffled by this, I then turned on the hot water heater with propane switch heating the water. After approximately a half hour, the regulator indicator turned green and has remained green every since. Not sure if air can get in the hot water tank gas line or not. With that said, minor issue has been corrected. Thanks! Link to post Share on other sites
Moderators topgun2 952 Posted October 9, 2019 Moderators Share Posted October 9, 2019 "air" can get into any line (and does) when the tanks are removed from a line. And, I'm sure that there is a small percentage of air in the tanks themselves. However, the gauge in question would only show the situation on the tank - not the lines. I'm thinking that the most obvious problem here was simply a gauge that was stuck and by "working" it several times you got it unstuck. In any case - glad you got it fixed. Bill 2017 Ford F150 Lariat 3.5EB FX4 Max Towing 2016 Oliver Elite II - Hull #117 "Twist" Link to post Share on other sites
