Imelda Posted July 17, 2020 Posted July 17, 2020 Does the refrigerator have a light in it? Imelda Donnelly, Oliver Elite 2, Hull 642 year 2020 pulled with 2022 Nissan Titan
Moderators SeaDawg Posted July 17, 2020 Moderators Posted July 17, 2020 Which fridge do you have? The dometic rm2454 does not have a light. I don't know about the current model Norcold, but most single door 3 ways don't have interior lights, in my experience. Sherry 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
AndrewK Posted July 17, 2020 Posted July 17, 2020 The Norcold does not have a light either. Andrew 1 Andrew 2019 Legacy Elite II 2018 BMW x5 35d
Ray and Susan Huff Posted July 17, 2020 Posted July 17, 2020 (edited) 23 minutes ago, AndrewK said: The Norcold does not have a light either. Andrew Perhaps in a small fridge, a light would take up precious space? Our RV Dometic fridge (which I do not like) has plastic shelves and blue LED lights. However, I find the light is mostly blocked by food in the fridge, so pretty useless. Edited July 17, 2020 by Susan Huff Ray and Susan Huff Elite II Twin "Pearl" - Hull#699; delivered December 7, 2020 2013 F350 6.7l diesel Super Duty 4x4 long bed crew cab 1UP-USA Heavy-duty bike rack 2017 Leisure Travel Van Unity Twin Bed (sold)
Moderators SeaDawg Posted July 17, 2020 Moderators Posted July 17, 2020 27 minutes ago, Susan Huff said: Perhaps in a small fridge, a light would take up precious space? Our RV Dometic fridge (which I do not like) has plastic shelves and blue LED lights. However, I find the light is mostly blocked by food in the fridge, so pretty useless. Do you know the model # of your current dometic, in your van/ motorhome? Is it all electric, or a 3 way? Thanks. Sherry 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Ray and Susan Huff Posted July 18, 2020 Posted July 18, 2020 (edited) 3 hours ago, SeaDawg said: Do you know the model # of your current dometic, in your van/ motorhome? Is it all electric, or a 3 way? Thanks. Sherry RMD8555. It is 3-way, but really only works well on propane. It is not as efficient storage wise, with no shelves in the freezer door and the plastic fridge shelves are poorly situated with little adjustment. We added the wire hanging shelf (picture 3). The crisper bin, as supplied by Dometic is one big drawer with a divider; we replaced it with two pull out plastic bin drawers. It has never cooled well, for us anyway. We have to run it on the coolest setting (level 5) and make sure to avoid direct sun on the fridge side of the van to keep the temp below 40 degrees. I suspect the plastic shelves impair airflow some which makes cooling less efficient. It could also be something about the installation in our particular RV. We had one of the older Dometic two-door fridges with wire shelves in a 5th-wheel and it worked so much better. No electronic controls; the temp adjustment was a sliding mechanism on the front of the cooling fins. I will be so glad to be rid of the RMD8555; but it does have cool blue lights. Edited July 18, 2020 by Susan Huff 1 Ray and Susan Huff Elite II Twin "Pearl" - Hull#699; delivered December 7, 2020 2013 F350 6.7l diesel Super Duty 4x4 long bed crew cab 1UP-USA Heavy-duty bike rack 2017 Leisure Travel Van Unity Twin Bed (sold)
Trainman Posted July 18, 2020 Posted July 18, 2020 If you just think you need a light in your fridge I'm sure there is an LED stick-on one for sale out there, of course you would have to turn the switch on to use it. So I counted all the LED lights on the inside of the trailer, our trailer has 29, that the standard ones, that's not counting the LED'S on the switch panels and other control panels. trainman 2019 RAM 1500, 5.7 Hemi, 4X4, Crew Cab, 5'7" bed, Towing Package, 3.92 Gears. Oliver was sold.
Moderators SeaDawg Posted July 18, 2020 Moderators Posted July 18, 2020 There are some sticking, led battery operated lights, motion sensor activated, that might work. 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
