Moderators Wayfinder Posted June 7, 2021 Moderators Posted June 7, 2021 After 5 years of use the uncrimped wire, which supplies power to the water pump, finally came loose from the connector. After close inspection I discovered the connector was never actually crimped onto the wire. Only the plastic housing around the connector was crimped to the wire. I also added a tie wrap to the wire protector so it does not pull down on the connector again. Easy fix. Chris 2016 Legacy Elite II o-o Hull #110 o-o "Rock'in 110" o-o Twin Bed (sometimes converted) o-o 5-leaf Alcan Springs (installed Feb 2026) 2020 RAM 1500 Limited 5.7L Augusta, Georgia
bhncb Posted June 7, 2021 Posted June 7, 2021 You might also want to check those water pump mounting screws. They looks as sketchy as the wiring job. 2
Moderators Wayfinder Posted June 8, 2021 Author Moderators Posted June 8, 2021 22 minutes ago, bhncb said: You might also want to check those water pump mounting screws. They looks as sketchy as the wiring job. Thanks. We'll take a look at them. Chris 2016 Legacy Elite II o-o Hull #110 o-o "Rock'in 110" o-o Twin Bed (sometimes converted) o-o 5-leaf Alcan Springs (installed Feb 2026) 2020 RAM 1500 Limited 5.7L Augusta, Georgia
Moderator+ ScubaRx Posted June 8, 2021 Moderator+ Posted June 8, 2021 Looking at that wiring, I could tell you exactly who wired your trailer. 1 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
Moderators topgun2 Posted June 8, 2021 Moderators Posted June 8, 2021 Actually, it is fairly amazing that it took five years for that wire to become detached enough for it to stop working. And, it does not appear that there was any "arching" on the end of that wire. Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Ralph Mawyer Posted June 8, 2021 Posted June 8, 2021 Steve, I think you should write or dictate a history of Oliver development, to include all the internal insight you have....to be published posthumously, of course. 🙂 12 hours ago, ScubaRx said: Looking at that wiring, I could tell you exactly who wired your trailer. 2020 Legacy Elite II : Hull 625 - 2013 Lexus LX 570 Factory Upgrades: Truma A/C, 640AH Lithionics, Alcan Springs, 5200 Axle, Bulldog Shocks (June 2025) San Antonio/Boerne - Texas Hill Country
