Trainman Posted November 9, 2021 Posted November 9, 2021 So after a 2 1/2 year period of owing our Elite II and setting outside in the Texas sun our fiberglass gelcoat was beginning to show some chalking and dulling and in need of a buff and wax job. Now being a retired body shop mgr. for some 35 years at a large DFW dealership doing the proper job was not a problem for me, but at 76 it wouldn't be doing it like I was 40, for sure. I used my 7" buffer and wool buffing pads, I used the Velcro system pads and buffer backing plate, the tie on pads are pretty much useless. I first buffed with Mequiar's #67 RV and Marine compound which did a very good job and really cut the oxidation, probably running the buffer back and fourth on the surface 8-10 times till the gelcoat what at a very high luster, due note here, the top of the trailer and ends we the most dulled areas on the trail, but I did the whole trail just because I didn't want to do a partial job when it comes to doing something. Due note here, I did have to use scaffolding to do the top, you will not be able to reach far enough in with a ladder, plus the scaffolding is much more safe for this old guy. I did the top and ends in one day and the sides the next day. Now for the Mequiar's Flagship RV and Marine polish which I put on by hand and took off with a orbital buffer and a polishing pad for it's final on this project, I hope this will last another couple of years before it needs another buff job, but will polish once a year to help preserve the finish. I watched several video's on YouTube on this and this guy knew what he was doing, or the way I would do it, trainman 4 2019 RAM 1500, 5.7 Hemi, 4X4, Crew Cab, 5'7" bed, Towing Package, 3.92 Gears. Oliver was sold.
John Dehne Posted November 12, 2021 Posted November 12, 2021 I have had great success with the Mequiar’s Flagship wax. Been using it for years. Holds up great and gives me some exercise. I will apply twice a year. 1 John & Chris Dehne Manchester, MD. 2021 Elite II twin Hull# 901 “Fiberbeergrass” 2021 Ram 2500 Cummins 4x4 Life is good!
LongStride Posted November 13, 2021 Posted November 13, 2021 Meguiar's Flagship appears to be the choice of many others as well. We used it to wax our Elite just prior to putting it to bed for the winter. 1 Mike and Yasuko 2021 Legacy Elite Hull #820
rideandfly Posted November 14, 2021 Posted November 14, 2021 We had water spots that normal waxing would not remove. Called Meguiar's and they recommended using Meguiar's #67 compound first then using Meguiar's Flagship wax, the combination worked great removing water spots and putting a great finish on Ollie! We used both during a two day "workout". 4 Bill 2015 LE2 #75 2024 F350 6.8L
dewdev Posted November 14, 2021 Posted November 14, 2021 I also used both Meguirs products on my newly purchased used Olliver this spirng. I found that the 67 One Step Comppound took off the water spot markings easier than 2 other non-Meguiars products I tried. I used the Meguiar's Cleaner Wax this spring after the 67. This fall I used the Meguiars Flagship Premium Marine Wax. The Premium Marine Wax was a lot easier to apply than the Cleaner Wax and appeared to leave a far superior finish than the Cleaner Wax. Having owned a few boats in the past, these Meguiars products are a lot better than any of the other waxes I used in the past. 1 2018 Oliver Elite II, Twin Bed, Hull #354 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
