Steve-Gwenne Posted April 20, 2022 Posted April 20, 2022 Part of Annual Maintenance is to Check Tire PSI. We have TPMS on our tires. At last year's Maintenance service, per the invoice the PSI was not checked due to our TPMS. The TPMS keeps track of PSI. We can remove the TPMS upon arrival at the service center. If you remove your TPMS, how do you keep track of each sensor to its tire. What do people do? I know many have TPMS. I would like Oliver to be able to check the PSI as we believe one tire may be low. Maybe I am being overly concerned about something of little consequence. ty SGC & GRC Hull 224 [2017] 2017 GMC Sierra HD Crew Cab Diesel
Moderators topgun2 Posted April 20, 2022 Moderators Posted April 20, 2022 6 minutes ago, sgcausey said: We can remove the TPMS upon arrival at the service center. If you remove your TPMS, how do you keep track of each sensor to its tire. I have placed a small number (1-5) on the inside of each of my tire sensors and then coated these numbers with clear nail polish so that the number stays put and does not wear off or come off. I then marked in my TPMS owner's manual which tire went with which numbered sensor. This way it is easy to get the right sensor back on the right tire in the event of removal. Bill p.s. if you'd like a picture of this just let me know. 1 3 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Moderators Mike and Carol Posted April 20, 2022 Moderators Posted April 20, 2022 TST supplied little stickers and, like Bill, I have stickers on each monitor so I know which one goes where. Actually, I’ve never had them all off at once. If your TPMS is telling you that one tire is low, I would remove the sensor and check with a gauge then fill if necessary. I carry a small tire compressor I got at Lowes a few years ago. It doesn’t fill fast but is good for “top offs” when necessary. Mike 1 4 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
dewdev Posted April 21, 2022 Posted April 21, 2022 I numbered each sensor cap using a white paint stick. I numbered them in such a fashion that I would not forget where they go. 1 Richard, Marianna and Annie (our minature poodle): 2018 Oliver Elite II, Twin Bed, Hull #354, new 3 - 130 Lithonics batteries and Xantrex Freedom XC 3000 Pro Inverter in 2025 2027 RAM 1500 Rebel, 4 x 4; 5.7L Gas V8 Hemi; 3.92 rear axle; 4 corner air suspension Maine
Moderators topgun2 Posted April 21, 2022 Moderators Posted April 21, 2022 9 hours ago, dewdev said: I numbered them in such a fashion that I would not forget where they go. Obviously you are still a bit younger versus some of us!😇 1 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
dewdev Posted April 21, 2022 Posted April 21, 2022 Not really, probably as old as most. I just marked them for instance: DF which stands for Driverside, Front. Can't forget that type of marking. 2 1 Richard, Marianna and Annie (our minature poodle): 2018 Oliver Elite II, Twin Bed, Hull #354, new 3 - 130 Lithonics batteries and Xantrex Freedom XC 3000 Pro Inverter in 2025 2027 RAM 1500 Rebel, 4 x 4; 5.7L Gas V8 Hemi; 3.92 rear axle; 4 corner air suspension Maine
Moderators topgun2 Posted April 21, 2022 Moderators Posted April 21, 2022 2 hours ago, dewdev said: Can't forget that type of marking. Really?😁 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Moderators mossemi Posted April 22, 2022 Moderators Posted April 22, 2022 On 4/20/2022 at 6:47 PM, sgcausey said: If you remove your TPMS, how do you keep track of each sensor to its tire. Although my TPMS sensors were marked at the time of the original installation, if I install them one at a time, the monitor shows the location of the sensor I just installed. Then I could mark them using dewdev’s labeling method or move them to the correct tire if they are already marked. Or you can clear the monitor memory and reprogram the system. Mossey 1 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
