Ralph Mawyer Posted May 5, 2022 Posted May 5, 2022 I’m wanting to mount two 2-gal Rotopax containers. My initial thought was to mount them outboard on the cargo box, but with a Honda 1000cc generator in the box now I’m not crazy about adding another 40 lbs to the tongue weight. It looks like I can mount them horizontally on the rear bike rack, which also helps balance the tongue weight of the generator. It looks to be a simple mount, but the closed beam mounting structure will require 2” bolts for the depth of the beam vs the simple bolting up front. (That and getting the top and bottom holes to line up. With the hitch u-bolts opening up the inside of the beam, I wondered why they didn’t drill drain holes. Small holes so not that big a deal I guess.) Thoughts? 2020 Legacy Elite II : Hull 625 - 2013 Lexus LX 570 Factory Upgrades: Truma A/C, 640AH Lithionics, Alcan Springs, 5200 Axle, Bulldog Shocks (June 2025) San Antonio/Boerne - Texas Hill Country
John E Davies Posted May 6, 2022 Posted May 6, 2022 That is a really hazardous location for gas cans. I used to carry two 5 gallon steel NATO cans in back, before I removed my cargo basket entirely. Those are super tough and can take a big impact without rupturing. I think you could mount the Rotopax vertically in the same spot, with the thin sides facing to the rear so they don’t block the lights. But you will have to fabricate brackets. Rotopax offers an L Bracket but it weighs 20 pounds! …. https://www.amazon.com/Rotopax-L-Bracket-Single-Mounting-x13-95/dp/B01LRDVZHA You also need to consider security, is there a way to lock the caps? Unfortunately that diamond plate sewer cover is not designed to support any weight, it has a single thin piece of reinforcing angle running across the back. You could beef it up, so it could actually support the gas cans. I made a long tie down rail for my ebike, it is a 2”x2”x0.188” section of 6061T6. I riveted it down with common 3/16” aluminum pop rivets at 2” spacing. It is hell for strong. If you were willing to get rid of that tire cover, you could easily fabricate a double can mount that attaches to the center threaded rod, I think it is 3/4” diameter. That would put them up out of the way and would look cool! John Davies Spokane WA 1 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
Ralph Mawyer Posted May 6, 2022 Author Posted May 6, 2022 Thanks John. I was hoping for your input. I considered some of your concerns, but the wall thickness on the tube was something I hadn’t considered. Worse case they’ll go on the truck roof. 1 2020 Legacy Elite II : Hull 625 - 2013 Lexus LX 570 Factory Upgrades: Truma A/C, 640AH Lithionics, Alcan Springs, 5200 Axle, Bulldog Shocks (June 2025) San Antonio/Boerne - Texas Hill Country
John E Davies Posted May 6, 2022 Posted May 6, 2022 7 hours ago, Ralph Mawyer said: (That and getting the top and bottom holes to line up. With the hitch u-bolts opening up the inside of the beam, I wondered why they didn’t drill drain holes. Small holes so not that big a deal I guess.) No drain holes = lazy technician. I drilled 1/8”: holes in my bumper at each end, and also in the bottom of the entry steps where water pools. My DIY rack is wide open on the ends so water cannot get trapped, and I can blast inside when I wash the trailer. You can use a drill guide block to get the top and bottom holes to line up. It isn’t as precise as a drill press, but it is good enough for this kind of project. I bought this one, it is super well designed, but $$$. There are some adequate ones with fewer features for less that $20. 30 45 90 Degree Angle 4 Sizes Drill Hole Guide Jig with 4 Drill Bits for Angled and Straight Hole, Portable Cable Railing Lag Screw Drilling Template Block for Cable Wood Post, Wire Metal Handrail John Davies Spokane WA 2 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
Geronimo John Posted May 6, 2022 Posted May 6, 2022 I would not have a problem with this for water storage. But for gasoline, when I saw the below, all I could think of is some jerk with an axe to grind. Giving a perfect opportunity to torch your beautiful trailer. Twist the cap, light it off and go. 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Ralph Mawyer Posted May 7, 2022 Author Posted May 7, 2022 Had that done to a car once when I was a pretty active soccer referee…unhappy players I expect. Don’t think I want to repeat the experience. Will likely go on roof mount at this point. 2 2020 Legacy Elite II : Hull 625 - 2013 Lexus LX 570 Factory Upgrades: Truma A/C, 640AH Lithionics, Alcan Springs, 5200 Axle, Bulldog Shocks (June 2025) San Antonio/Boerne - Texas Hill Country
dewdev Posted May 7, 2022 Posted May 7, 2022 As a alternate to carrying gas cans, you could switch your generator to burn propane. 1 Richard, Marianna and Annie (our minature poodle): 2018 Oliver Elite II, Twin Bed, Hull #354, new 3 - 130 Lithonics batteries and Xantrex Freedom XC 3000 Pro Inverter in 2025 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
Geronimo John Posted May 8, 2022 Posted May 8, 2022 On 5/7/2022 at 3:57 AM, dewdev said: As a alternate to carrying gas cans, you could switch your generator to burn propane. A good option for sure! Do consider that most generators do lose capacity due to the energy content decrease between gas and propane. Something to run to ground so that you "know before you go" that path. 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Trainman Posted May 10, 2022 Posted May 10, 2022 I have a new Rotopax fuel tank and mounting that I purchased for my motorcycle off road riding to carry extra fuel, common for dual sport motorcycle riders to carry extra fuel. Now since I don't ride anymore I just need it to find something that I need fuel for when camping. I will say these are very good fuel container and very sturdy for all uses, many carry then on there ATV's and UTV's. trainman 2 2019 RAM 1500, 5.7 Hemi, 4X4, Crew Cab, 5'7" bed, Towing Package, 3.92 Gears. Oliver was sold.
