SNY SD UP Posted June 9, 2022 Posted June 9, 2022 Has anyone experienced this before? We are in the FL Keys where Temp & RH are both quite high. We had it a few nights ago, then nothing for a few days. We ran AC last night, and no drips/water on the floor, and exterior AC drain hose was dripping nicely. Ran the AC today when we left pet inside, and came home to a substantial puddle again, went outside and AC drain hose was not dripping. Anyone experienced this before? Do I remove exterior AC cowling to access anything that would show what the issue is? Do I remove interior Plastic pieces to expose where the water was dripping from? Where is drip pan that collects the condensation from the unit located? The supplied Dometic Thermostat & AC pages in manuals do not address anything like this. Any feedback would be appreciated, Bryan, Out Maggie & Bryan | Arnegard, ND | 2020 LE II "Twins" Hull #665 | 2021 RAM 2500 6.4L HEMI Gasser 4dr 6.5' bed
Moderators mossemi Posted June 10, 2022 Moderators Posted June 10, 2022 This Link covers my experience with a Dometic air conditioner leak. Mossey 1 1 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
Moderators SeaDawg Posted June 10, 2022 Moderators Posted June 10, 2022 The manuals won't help, because (i think) it's the Oliver drain tube is plugged, or kinked.. Just be glad you have twin beds. In the standard configuration, it would be dripping on the bed. (Ask me how I know.) 2 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
John E Davies Posted June 10, 2022 Posted June 10, 2022 On my Hull 218 the AC condensation drain line comes out at the left rear (street side) corner near the cable TV connector, stick a flexible rod of some kind up inside, most likely a bug or mud dawber has taken up residence. Mine is a 1/2” PEX plastic pipe, you won’t hurt it unless you get carried away with something hard and sharp. That line runs up the back side of the cargo area (toward the roof) you can also access it from there. Consider adding some coarse bronze wool to allow the water to come out, but keep the bigger bugs out. I think you can get it way cheaper at Walmart. https://www.amazon.com/Rogue-River-Tools-Bronze-Wool/dp/B079Y1QTY1/ref=sr_1_4?crid=1DFLZT60X80V1&keywords=bronze+wool+coarse&qid=1654821202&sprefix=bronze+wool+coarse%2Caps%2C159&sr=8-4 John Davies Spokane Wa 2 1 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
Moderators SeaDawg Posted June 10, 2022 Moderators Posted June 10, 2022 I think we were able to access the plug from the inside. Paul and I were talking about it. We "think" we stuck a long tie wrap (24") through the drain tube , and cleared it. We so seldom use ac, and that was at least ten years ago. Maybe more. 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
SNY SD UP Posted June 10, 2022 Author Posted June 10, 2022 Thanks to all for your input. Moderators - if you wish to move to "General Discussion" or something more appropriate, please do so. 1 Maggie & Bryan | Arnegard, ND | 2020 LE II "Twins" Hull #665 | 2021 RAM 2500 6.4L HEMI Gasser 4dr 6.5' bed
Moderators SeaDawg Posted June 10, 2022 Moderators Posted June 10, 2022 I think you're in an appropriate spot. Let us know what you find. 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Patriot Posted June 10, 2022 Posted June 10, 2022 14 hours ago, SNY SD UP said: Has anyone experienced this before? We are in the FL Keys where Temp & RH are both quite high. We had it a few nights ago, then nothing for a few days. We ran AC last night, and no drips/water on the floor, and exterior AC drain hose was dripping nicely. Ran the AC today when we left pet inside, and came home to a substantial puddle again, went outside and AC drain hose was not dripping. Anyone experienced this before? Do I remove exterior AC cowling to access anything that would show what the issue is? Do I remove interior Plastic pieces to expose where the water was dripping from? Where is drip pan that collects the condensation from the unit located? The supplied Dometic Thermostat & AC pages in manuals do not address anything like this. Any feedback would be appreciated, Bryan, Out We had a very similar issue last year, and took it to Oliver Service and they discovered the condensate drain tube was kinked like mentioned above by Seadawg. Oliver fixed the kinked drain tube and our AC has worked fine since. Hope you get it resolved quickly. 3 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
