Moderators Wayfinder Posted August 13, 2022 Moderators Posted August 13, 2022 It was time to touch-up the bulldog hitch. I used a pretty good Rust-Oleum flat paint, after wire bushing and cleaning well. Should I bother with a clear coat enamel on top? What would you do? Thanks, Chris 1 Chris 2016 Legacy Elite II o-o Hull #110 o-o "Rock'in 110" o-o Twin Bed 2020 RAM 1500 Limited 5.7L Augusta, Georgia
Moderators Mike and Carol Posted August 13, 2022 Moderators Posted August 13, 2022 I just use Rustoleum black after cleaning the rust. Clear coat may cause the paint to last longer. Let us know if you try it. Mike 4 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
John E Davies Posted August 13, 2022 Posted August 13, 2022 I don't think clear coating flat black is necessary, nor IMHO would it look very good, I use Duplicolor Ceramic Brake Caliper Paint, gloss black, no primer is needed like regular spray paints, it flows out beautifully, is dry to the touch in five minutes, and after a week it cures rock hard. This paint is now my "go to" product for just about anything that needs one of the six available colors. Any good auto parts store should carry it. https://www.duplicolor.com/product/caliper-paint/ I just painted the receiver area on my LC200 a couple of weeks ago. The "spots" are weld splatter, that doesn't look so great with a gloss paint.... maybe next time I will grind those all away. And use the Satin Black instead. 8 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
Katjo Posted August 13, 2022 Posted August 13, 2022 We used Rustoleum black also with no clear coat over. 3 2021 Dodge Ram 1500 2021 Oliver Elite ll Hull #732 Michigan
Steve Morris Posted August 14, 2022 Posted August 14, 2022 No trailer yet, but for jobs like this here in the rust belt, I use Eastwood’s original chassis paint. I see that there’s now an extreme and ceramic, but I’ve never tried them. https://www.eastwood.com/search/?q=Chassis Before: After: 14 Years later: 1 4 ----- Steve - Northern Ohio, USA Wandering around on occasion, always lost. 2021 Toyota Land Cruiser - 2023 Oliver Elite II Twin Hull #1360 “Curiosity” Facebook - Instagram Camped in Curiosity = Green —— Visited with Curiosity = Gray
Moderators topgun2 Posted September 13, 2022 Moderators Posted September 13, 2022 On 8/13/2022 at 11:10 AM, Wayfinder said: Should I bother with a clear coat enamel on top? What would you do? No, I would not clear coat it. Given the wear and tear the hitch gets you are probably going to need to give it a shot of paint every couple of years anyway. Having said this, I would not paint the hitch black in the first place. A black hitch is difficult to see when using those rear cameras in most vehicles today. This is particularly true if the road surface is dark. For the past several years I've used Rust Oleum hammered silver on the front part of the hitch and Krylon satin black on the rear portion. Bill 3 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
