We live in San Antonio and our RV storage place is expanding and I have options that I haven't had until now and need to make a decision. We have few freezes but the sun is brutal most of the summer.
  1. Enclosed: most secure, most protected, most expensive. Question: Do I need to plug in (only 20A) to keep the batteries charged since no sun to have solar do it?
  2. Covered: currently have an end spot so more exposed to the sun. We have the Ollie cover so we can do that, but not convenient and do we have to plug in (same question as above)?
  3. Covered, but not necessary to put the Ollie cover on it.
  4. Exposed
Do I need tire covers?
Any thoughts on how to smartly store an Ollie in between uses would be appreciated.
John and Jodi
San Antonio, TX
2022 Elite II - Hull #1126 being pulled by a 2022 F-150 Powerboost.
Map Legend: Red - Driven Through; Orange - Stopped In; Blue - Explored Parts; Green - Explored Whole
With "brutal" sun, a fully enclosed space is perfect. Just back the trailer in, level it,  plug into the 120 volt outlet with a heavy gauge 15 amp extension cord, be on your way. The type of batteries you have determines how you should store/ charge them. I would choose this over any exposed space in a desert climate. "Mouse" is fully enclosed in my RV bay, I do not have to worry about UV degradation, sidewall rot or rodents, and being out of sight makes it super secure. You will sleep better at home if you aren't worrying about that!
If the tires are exposed for long periods, they should definitely be covered. Oops:
If the solar panels can get just an hour exposure per day of sun, you don't need to plug in.
Sun exposure to the hull will not hurt it, but you will definitely need to spend a lot more time cleaning and waxing the gelcoat. An inside trailer can go long periods and still stay nice. Mine gets a Rejex application every other year.
If you want better recommendations, post pics of the potential spots with notes about sun exposure.
John, you’ve seen our storage, covered and deep enough I can park all the way in the back and avoid any sun except at the very end of the day on the front of the trailer.  I’ve not used tire covers because the tires never see sun while in storage.  If your space gets sun on one side and the tires get that sun then I would get tire covers.  When I had AGMs I plugged in to a 20a.  With lithiums, I just turn them off.  If your solar doesn’t get sun, either in a covered space or enclosed I would turn off or disconnect your batteries.  If your panels get some sun then I’d let the solar do your battery maintenance.
We’ve talked about getting an enclosed slot here in Boerne, but the extra cost doesn’t seem worth it since security is good.  Could you get a spot that is more covered than your end spot?  Mike
I never thought about turning the batteries off. Thanks.
How important is the leveling with an empty trailer, empty tanks, and refrigerator off?
John and Jodi
San Antonio, TX
I'd say, the only big leveling issue is if you have a 3 way fridge. Then, leveling is important.  At least enough that you feel comfortable on the trailer.
As long as the absorption refrigerator is completely turned off, the RV can be off-level to any degree (maybe not upside down) and not harm the cooling unit in the refrigerator. It is only while in operation must the refrigerator be relatively level in order to work properly and safely. So if the unit is turned off, there’s really nothing to worry about if you store the trailer off-level over the winter.
You should take a little weight off the suspension and tires for long term storage, so you might as well get the trailer level while you are doing that.
If the trailer is significantly off level, at least hang a red steamer (surveyors tape works) near the fridge so somebody doesn’t start it up that way.
Yeah, I  had a senior "brain fart moment." Thanks for the catch, @ScubaRx.
Just don't turn on the fridge while seriously off level. It's the burner that causes the crystallization and failure,too far  off level and running.
We've made that mistake, only once, and it was an expensive error.
  • 2 months later...
Well the hypothetical has become reality: we have our enclosed spot, no sun. Just checking in with y'all that the recommendation for lithium batteries is to turn them off. I'm assuming that means the button on each battery, correct? Then when it's time to use the trailer, turn the batteries back on and let the solar recharge them?
John and Jodi
San Antonio, TX
