Rivernerd Posted October 22, 2022 Posted October 22, 2022 Did you try a heat gun with a plastic putty knife? Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package
Ralph Mawyer Posted October 22, 2022 Posted October 22, 2022 Didn’t today, but likely the solution. I talked to service later in the day. They put two guys on top at the back corner and one inside pushing up. Then peal it back to front. 2020 Legacy Elite II : Hull 625 - 2013 Lexus LX 570 Factory Upgrades: Truma A/C, 640AH Lithionics, Alcan Springs, 5200 Axle, Bulldog Shocks (June 2025) San Antonio/Boerne - Texas Hill Country
bhncb Posted October 22, 2022 Posted October 22, 2022 47 minutes ago, Rivernerd said: Did you try a heat gun with a plastic putty knife? Any heat gun hotter than a hair dry will definitely damage the gelcoat. Be very careful using this method. Better to use a solvent, pressure, and patients. 1
Geronimo John Posted November 11, 2022 Posted November 11, 2022 Not sure where to post this, so picked this one. The Houghton unit uses a remote for control. As such, several have mentioned the desire for a spare one. To those owners this may be of interest from the RecPro web site: GJ TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Patriot Posted November 18, 2022 Posted November 18, 2022 On 10/21/2022 at 9:05 PM, bhncb said: Any heat gun hotter than a hair dry will definitely damage the gelcoat. Be very careful using this method. Better to use a solvent, pressure, and patients. Any further updates on the progress on removal of your Dometic AC and the install of the Truma? Patriot 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Ralph Mawyer Posted November 18, 2022 Posted November 18, 2022 11 hours ago, Patriot said: Any further updates on the progress on removal of your Dometic AC and the install of the Truma? Patriot Nothing on my end. Tech said they’ had an inquiry from Florida. I was going to ping him and see if that went through. 1 2020 Legacy Elite II : Hull 625 - 2013 Lexus LX 570 Factory Upgrades: Truma A/C, 640AH Lithionics, Alcan Springs, 5200 Axle, Bulldog Shocks (June 2025) San Antonio/Boerne - Texas Hill Country
