Trailblazers Posted October 17, 2022 Posted October 17, 2022 My USB ports and AC plugs are not working on the curbside of the trailer (2018 Elite II). I'm assuming it's a fuse, but I can't find it. Any guidance would be appreciated. Thanks, Dan Franklin, TN 2018 Elite II #315 Tow Vehicle: 2020 Ram 1500
Moderators topgun2 Posted October 17, 2022 Moderators Posted October 17, 2022 Is the DC plug working - the one over the kitchen area? 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Trailblazers Posted October 18, 2022 Author Posted October 18, 2022 No, DC plug is not working either. Franklin, TN 2018 Elite II #315 Tow Vehicle: 2020 Ram 1500
Steph and Dud B Posted October 18, 2022 Posted October 18, 2022 Sounds like a 12v fuse but that doesn't explain the 120v outlets... Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
John E Davies Posted October 18, 2022 Posted October 18, 2022 The USB ports are 12 volts DC (input), the AC outlet is 120 volts AC, they are in no way connected (electrically). You need a basic volt ohm meter so you can do some testing. The AC outlets are all wired together, with a single circuit breaker. You are lucky in that you have real wiring diagrams, they quit supplying them after your year I think. While you are checking fuses in that panel (at the converter) check all the little brass “ears” that grip the fuse contacts. These DO loosen and can cause intermittent or complete failure. Remove each fuse one at a time, and carefully squeeze the ears together using needle nosed pliers. You should disconnect the batteries first unless you like taking risks…. When reinstalling fuses, push them straight in, do not cock them or you will just loosen those ears again. That may fix the USB issue, but it has nothing t do with the AC outlet.That may be faulty, it is easy to replace. John Davies Spokane WA 1 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
Trailblazers Posted October 18, 2022 Author Posted October 18, 2022 Thanks for all the help & feedback. Would this be the 12V fuse under the dinette? I've checked that one, but I'm assuming there is another fuse somewhere that controls only the curbside area? Correction - my ac on that side does work. We park the trailer about 30 mins away and I couldn't remember if it was all outlets or just the USB and DC plugs. My wife (her side of the trailer) thought it was all. Sorry for the confusion. Franklin, TN 2018 Elite II #315 Tow Vehicle: 2020 Ram 1500
dewdev Posted October 18, 2022 Posted October 18, 2022 I have an 2018 Elite II, hull 354. This is the directory for the fuses in the attic 2018 Oliver Elite II, Twin Bed, Hull #354, new 3 - 130 Lithonics batteries and Xantrex Freedom XC 3000 Pro Inverter in 2025 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
Moderators topgun2 Posted October 18, 2022 Moderators Posted October 18, 2022 Do you have a fuse sub-panel in your attic? 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
dewdev Posted October 18, 2022 Posted October 18, 2022 This is the directory for the fuses under the dinette: AC BRANCH CIRCUITS (breakers) DC BRANCH CIRCUITS 1 Main 30 AMP 1. Fridge 20 AMP 2. AC 20 AMP 2. Optional 12 V Nightstand 20 AMP 3. Fridge 20 AMP 3. Water Pump 15 AMP 4. 110/Micro 15 AMP 4. Furnace 7.5 AMP 5. Charger 15 AMP 5. Basement ?? 7.5 AMP 6. 12 V Dinette 20 AMP 7. Optional 12 V Nightstand 20 AMP 8. Optional Compost 1 AMP 2018 Oliver Elite II, Twin Bed, Hull #354, new 3 - 130 Lithonics batteries and Xantrex Freedom XC 3000 Pro Inverter in 2025 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
Moderators topgun2 Posted October 18, 2022 Moderators Posted October 18, 2022 Looks to me like #3 in the attic. 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Trailblazers Posted October 18, 2022 Author Posted October 18, 2022 Problem solved, thank you dewdev! It was the #3 fuse in the attic. I've owned the trailer for two years and never would have looked in the attic for another fuse panel. Looked almost everywhere else. Thanks to everyone! 1 Franklin, TN 2018 Elite II #315 Tow Vehicle: 2020 Ram 1500
