Has anyone successfully registered their Booster with AT&T?  Every time I call support after going through several levels, they try to hook me up on their Base Station (stationary) or act like they haven't heard of it.  I tell them it is an aftermarket booster used in vehicles.  Am I not using the right terminology?
Jack and Kathryn
2022 LEII Hull 1260 - 2020 Ram 2500
The cell booster on our 2022 doesn't require registration. It simply picks up the cell signal outside and retransmits it through the antenna over the dinette into one of our phones. We're Hull 1150. I'm pretty sure you have the same one.
Are previous OE2's pre wired for these devices?
If so, where?
Thanks
  • 1 month later...
Our 2017 H#226 has one - don't know if they come pre-wired unless it was a requested option from the factory buy...
  • (SOLD) 2022 TUNDRA
If so, where?
Hull 193 is pre wired for power.  The pink B+ and yellow B- are accessed from the left end of the bath overhead cabinet.  Mossey8D0F1D40-8098-4159-AC7F-357FEAC93F43.thumb.jpeg.1abb77b6b6ed9d14e935e73a8cdaae1b.jpeg
 Our older hull 342 Owners Manual does show a cell Switch and a WiFi switch wiring.   But it's location is not "to scale" shown.  Where are your switches located?  Knowing that would greatly reduce my "Easter Egg Hunt".
thanks,
image.png.41dc476e8e58d47543b249b85483193f.pngGJ
I do not have any switches installed, just the power wires.  I think the cellular booster/WiFi antennas are located on the front port corner and the active components are mounted in upper cabinet above the front dinette seat and the switches are then mounted on the outside of the cabinet between the bathroom wall and the cabinet door.  You would get the switches when the active components and antennas are installed.  So you should wait until April 9th to continue your Easter 🥚Hunt.
If this helps:
In 2019 - Hull 505 - The Cell Booster and WIFI power switches are mounted to the right of the upper storage bin above the front dinette seat.  There's an access port in the left side of the upper bathroom storage cabinet (above toilet with the mirrored front.)
Inside that access port is where the cables run down from the WIFI Booster on the Drivers Side FRONT of the trailer.
The WIFI Router is mounted on the wall inside the upper cabinet on the right end (against that cabinet wall). The actual external WIFI Booster/Antenna's are mounted outside on the top of trailer just above bathroom cabinet.
The Cell booster is at the far end in the upper cabinet mounted against the pantry wall.  There's an access port inside the pantry wall.
The outside cell antenna is a magnetic mount on a plate on the roof.  The cable runs through that plate with lot's of sealant around it. The cable snakes it's way between the two hulls and eventually ends up in the pantry access area.
What I've learned is new "wifi boosters" use a different kind of cable than the ones put in older vintage trailers. (Sigh) So even if the cable is inside the trailer it might not be the correct cable for todays boosters.
Hope this helps a bit.
 Craig
Thanks Craig for filling in the gaps!  And now we know the rest of the story!
Thanks Craig.   Many thanks.
Also, nice wire racks!
