BillATX Posted April 16, 2023 Share Posted April 16, 2023 Hello, I have searched the forum, but not ben able to find a link to purchase a new water pump filter. I have a 2021 Elite1 and my filter housing has cracked. Where can I purchase a new one? Thank you in advance. Bill Hull #735 - 2021 Elite 1 (Shorty) | 2021 Toyota Tundra Link to comment Share on other sites More sharing options...
John E Davies Posted April 16, 2023 Share Posted April 16, 2023 Complete strainers are cheap and easy to find. SHURFLO (255-313) 1/2" Twist-On Pipe Strainer I read an article that some RV antifreeze brands can affect and crack the plastic housing, you might think about changing brands or researching that topic John Davies Spokane WA 1 2 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT. Link to comment Share on other sites More sharing options...
Frank C Posted April 16, 2023 Share Posted April 16, 2023 Mine had cracked, and judging by the pink discoloration, the cracking was probably due to the winterizing anti-freeze. I couldn’t find just the clear bowl/screen part available as a replacement so I just ordered the entire assembly that John linked above, and swapped out the bowl/screen. When you do replace the bowl, make sure that the O-ring is in place and properly seated when you install the new bowl, otherwise air can get sucked in and prevent the pump from priming. 3 3 Link to comment Share on other sites More sharing options...
Geronimo John Posted April 16, 2023 Share Posted April 16, 2023 For sure my screen/bowl has snagged plenty of installation shavings... especially in the first two seasons. But frankly I would like to change out the unit with a true water filter that would not be a PITA to install and service. Any suggestions along these lines? GJ 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR). Link to comment Share on other sites More sharing options...
Moderator+ ScubaRx Posted April 16, 2023 Moderator+ Share Posted April 16, 2023 7 hours ago, BillATX said: Hello, I have searched the forum, but not ben able to find a link to purchase a new water pump filter. I have a 2021 Elite1 and my filter housing has cracked. Where can I purchase a new one? Thank you in advance. Bill I bought one from Amazon. 3 Steve, Tali and our dog Rocky plus our beloved Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4 Link to comment Share on other sites More sharing options...
