MAX Burner Posted April 18, 2023 Posted April 18, 2023 (Apologies in advance if this has been addressed before... can't seem to find a post that covers it). It's apparent that LPG accessories (fire pits, grills, etc.) with dedicated gas regulators are not compatible with the OTT Quick Disconnect gas port (if so equipped). My understanding is that the first regulator at the tanks drops the working pressure too low for the second regulator at the accessory to operate correctly. Question: What sort of modification/fix/work-around is needed so our LPG accy's are compatible with the gas port(s)? At this point, we're using the dog house access port to connect the grill gas line to one of the LPG tanks - would prefer to use the forward or aft QD. Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Katjo Posted April 18, 2023 Posted April 18, 2023 You can buy low pressure quick connect hoses and adapters to use with your Oliver propane port. Here is an example. DOZYANT 12 feet Low Pressure Propane Quick-Connect Hose, RV Quick Connect Propane Hose, Quick Disconnect Propane Hose Extension - 1/4” Safety Shutoff Valve & Male Full Flow Plug for RVs https://a.co/d/3EucL5u 2 1 2021 Dodge Ram 1500 2021 Oliver Elite ll Hull #732 Michigan
rich.dev Posted April 18, 2023 Posted April 18, 2023 If you have a Blackstone this hose and connection will work. It's specifically listed for use with the Blackstone griddle, don’t know if it would work with other grills/griddles. 1 1 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Moderators Mike and Carol Posted April 18, 2023 Moderators Posted April 18, 2023 I use my Blackstone with no modifications on our QC. For my Weber Q1000 I removed the regulator and it works well that way off the QC. I think our Outland fire pit would also work, but we usually have it far enough from the trailer that I just use a 20 lb tank that I carry. Mike 1 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
MobileJoy Posted April 19, 2023 Posted April 19, 2023 If you have propane powered appliances with built-in regulators you will have to remove or bypass them in order to connect it to the Elite's low pressure QD port. If the regulator is external you can replace its hose with something like what rich.dev mentioned above. If your appliance takes the 1 lbs bottle, you can use a straight hose with no regulator (something like this) to connect to a 20 or 30 lbs tank. I have a Weber Q1200 model designed for RVs, which does not come with its own regulator but does come with a 12' QD hose designed for connection to propane ports on the RV. 1 2021 Elite II Twin #850 "Mojo", 2020 F250 Lariat 7.3L FX4 3.55
MAX Burner Posted April 19, 2023 Author Posted April 19, 2023 Awesome, y'all! I'm thinking I can modify our Weber to make compatible with the QD fitting on the camper. Many thanks! This is an awesome forum...😎 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Moderators Mike and Carol Posted April 19, 2023 Moderators Posted April 19, 2023 7 hours ago, MAX Burner said: Awesome, y'all! I'm thinking I can modify our Weber to make compatible with the QD fitting on the camper. Many thanks! This is an awesome forum...😎 You can search online, there are YouTube videos on the Weber. You can also buy the parts needed. It’s pretty easy. 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
MAX Burner Posted April 19, 2023 Author Posted April 19, 2023 Thanks, Mike - we're thinking its an easy fix to mod the Weber... I'll search the YouTube vids, for sure. We'll probably go that route rather than invest in a new Blackstone (they sure look sturdy, though) 2 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Moderators Mike and Carol Posted April 19, 2023 Moderators Posted April 19, 2023 I like my 17” Blackstone too! I carry both it and the Weber when we camp. Mike 2 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Patriot Posted April 20, 2023 Posted April 20, 2023 38 minutes ago, Mike and Carol said: I like my 17” Blackstone too! I carry both it and the Weber when we camp. Mike Now I know where steaks are served! 😊 2 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Moderators Mike and Carol Posted April 20, 2023 Moderators Posted April 20, 2023 41 minutes ago, Patriot said: Now I know where steaks are served! 😊 Steaks are normal fare whether on the Weber or Blackstone! 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
MAX Burner Posted April 20, 2023 Author Posted April 20, 2023 11 hours ago, Patriot said: Now I know where steaks are served! 😊 ...and the "Smash Burgers"! HA! 2 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
John and Debbie Posted April 20, 2023 Posted April 20, 2023 On 4/18/2023 at 7:44 AM, Katjo said: You can buy low pressure quick connect hoses and adapters to use with your Oliver propane port. Here is an example. DOZYANT 12 feet Low Pressure Propane Quick-Connect Hose, RV Quick Connect Propane Hose, Quick Disconnect Propane Hose Extension - 1/4” Safety Shutoff Valve & Male Full Flow Plug for RVs https://a.co/d/3EucL5u I see a rubber or stainless steel option. Any preference for either and what length is commonly needed? John John and Debbie, Beaverton, Oregon, 2017 Ford Expedition EL 4x4 3.5 liter Ecoboost, with heavy duty tow package. Hull #1290, twin bed with Truma package (a/c, furnace, hot water heater with electric antifreeze option), lithium pro package, picked up November 7, 2022 Alcan 5 leaf springs and Bulldog shocks done May 20, 2025 in Grand Junction, Colorado
Katjo Posted April 20, 2023 Posted April 20, 2023 @John Welte The rubber 12 ft has worked out great for us. 2021 Dodge Ram 1500 2021 Oliver Elite ll Hull #732 Michigan
Moderators Mike and Carol Posted April 20, 2023 Moderators Posted April 20, 2023 I have two 10’ rubber hoses and one 15’ rubber hose. I keep my Blackstone connector on one hose. The Weber doesn’t have a unique connector requirement so I can use either of the other two hoses or connect them together if I need more length. Mike Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
