1 hour ago, Wayfinder said:
I'm thinking to recommend to use a mini-vacuum attachment to suck out any dry debris.  That might make it easier to clean out when it does get wet.
Good idea.
Maybe first a dry clean using compressed air on the high side and a wet/dry vac on the low side.
Then do it wet with some dawn soap clean process with the hot water tank wand and a wet/dry vac involved.
Both aided by poking with extra long pipe cleaners.
Problem is we only have two hands......
I do really dislike these windows overall.  Waiting for the better windows.  We'll see what gets announced soon.
Chris
2020 RAM 1500 Limited 5.7L
Augusta, Georgia
Same here, this is our 5 trailer and must say I really don’t like these windows!
**Sold😞**
Here’s a quick and easy shortcut!
After following this thread, I decided to clean our window tracks too.  We live in the rain forrest and they were full of redwood needles, moss, dirt and mildew.  The white rubber seals were terribly stained even after a hard scrubbing with a stiff brush.  I was going to order new seals until  I gave them a quick soak in “30 Second Outdoor Cleaner” from Ace Hardware.  It's amazing!  They looked brand new.
I picked up some pipe cleaners to clean the track, but I didn’t need them.  Instead I used a straight brush and a water hose nozzle.  The water jet went under the fixed window section and washed all kinds of dirt out of the weep holes.  I just pulsed the water jet until it ran clear.  We moved the bedding and seat cushions out of the way, but there was minimal leakage inside.  I'll be doing this every year now.
Cheers, Geoff
IMG_4245.thumb.jpeg.ab0a069b7dc1b80c6dd1e3aeaaab7fbc.jpegIMG_4246.thumb.jpeg.06cd528d507ebcec59b913f2643cbc84.jpeg
  • Love 3
My family and I have  had way over a dozen trailers.  Most had boats on them, and one was a pop-up.  As we approached retirement we knew we had had enough wave rocking and flapping canvas and needed a serious upgrade.
So compared to all my previous experiences, the Ollie windows are super fantastic!  Especially now that I have seen Chris's video!!!  LOL
Amazing product to remove these mildew stains! Yes, water pressure is all you need to clean the internal dirt out of the weep holes.
Still happy with the $100 upgrade to switch to black rubber and have them fit tightly end to end without the 1” gap we had on each piece with the OEM installation.
Great tip @Snackchaser. I'll try to remember as I am asked often about them.  I gave my new white strips to another Oliver owner when I received the new windows. I had Oliver put on the black weather stripping.  I'm afraid to see if it's a separate line item on my invoice. No, I will not look.  No.
@Ollie-Haus add that to our list of "to-does". “30 Second Outdoor Cleaner” (ACE)
LOL
Chris
Edited by Wayfinder
Chris
Augusta, Georgia
  • 1 month later...
On 4/30/2023 at 8:15 PM, Wayfinder said:
This is neither Mechanical nor Technical, but more maintenance.  Not sure what other channel to place this.  Hope it helps our new-comers.
Someone on the Oliver Owners Facebook page saw my first video and asked me if I could video record actually how to clean the tracks under the windows.  So, it was a beautiful day and I figured I'd see if I can clean and record at the same time.  This is kind of new to me.
https://youtu.be/-oEpon3iaPc
Just watched your video. We had a very hard rain yesterday and had a leak coming in the back street side window. Will follow your advice/video this weekend on Hull 292.
Thanks
Gary
2017 Oliver Elite II Hull 292
2018 Nissan Armada
Tampa, FL
On 5/2/2023 at 10:57 AM, RoadKingsofGA said:
Well, I was so inspired by your video, I went right out this morning to clean ours. I gathered my wand sprayer, flathead screw driver, rags, pip cleaners, etc.   I first pulled the white rubber gasket, then found the cut place of the black track and began to pry it up...lots of cracking and tearing sounds.  I could barely raise it a bit.  I pulled out past the furry inset.  So we stopped and forced it back down.  It seems very brittle and is tearing up rather than pulling out.  This is the second time we've tried this.  Same results.  I'll just keep the dirty window tracks.  🙂
Bummer
2018 Nissan Armada
Tampa, FL
On 7/10/2023 at 12:11 PM, wolfdds said:
Does anyone know where to buy replacement rubber strips and the felt sides for these windows? It was pouring out and our windows were leaking, in desperation I pulled the gaskets and felt but pretty much ruined it getting it out. The good news is that I was able to stop the leak after pulling out the gasket and cleaning the weep holes.
Any info on buying new parts to replace the ones I ruined would be appreciated.
This is the link for replacing. It was earlier in this post. https://www.pellandent.com/RV-Window-Seal
2018 Nissan Armada
Tampa, FL
