Wayfinder Posted May 13, 2023 Share Posted May 13, 2023 While considering to replace my grey tank seal, I found a lose spare part, a pex fitting end/stop. LOL. Been there's likely since 2016. Not something I want rolling around with electrical connections. Does have a brass crimper and the brass connector. Also finger-checked all my electrical connections under the driver's side bed to ensure everything is still snug. 2 1 Chris 2016 Legacy Elite II o--o Hull #110 o--o Wayfinder o--o Twin Bed o--o 2020 RAM 1500 Limited 5.7L Augusta, Georgia Link to comment Share on other sites More sharing options...
rich.dev Posted May 13, 2023 Share Posted May 13, 2023 20 minutes ago, Wayfinder said: grey tank seal Was it easy to replace that grey tank seal/gate valve? 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison Link to comment Share on other sites More sharing options...
Wayfinder Posted May 13, 2023 Author Share Posted May 13, 2023 10 minutes ago, rich.dev said: Was it easy to replace that grey tank seal/gate valve? Funny you should ask. Still trying. The bottom bolts are right on the basement floor. TIGHT, very! No curse words yet, but no promises. I tried to shim under the pipe, but man it would budge. So, slow going with big man fingers. 2 1 Chris 2016 Legacy Elite II o--o Hull #110 o--o Wayfinder o--o Twin Bed o--o 2020 RAM 1500 Limited 5.7L Augusta, Georgia Link to comment Share on other sites More sharing options...
Wayfinder Posted May 13, 2023 Author Share Posted May 13, 2023 I hope Oliver lifts this up off the floor even 1/4". He'll, I'd be happy with 1/8". Chris 2016 Legacy Elite II o--o Hull #110 o--o Wayfinder o--o Twin Bed o--o 2020 RAM 1500 Limited 5.7L Augusta, Georgia Link to comment Share on other sites More sharing options...
Wayfinder Posted May 13, 2023 Author Share Posted May 13, 2023 A small chisel helped to wedge it up a tad bit. 3 Chris 2016 Legacy Elite II o--o Hull #110 o--o Wayfinder o--o Twin Bed o--o 2020 RAM 1500 Limited 5.7L Augusta, Georgia Link to comment Share on other sites More sharing options...
rich.dev Posted May 13, 2023 Share Posted May 13, 2023 11 minutes ago, Wayfinder said: So, slow going with big man fingers Haha feel your pain, I also have sausage fingers! 1 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison Link to comment Share on other sites More sharing options...
Wayfinder Posted May 13, 2023 Author Share Posted May 13, 2023 13 hours ago, rich.dev said: Was it easy to replace that grey tank seal/gate valve? NOOOOOOOO, no it was not easy. LoL OMG that was two hours I'll never get back. It's done and with no leaks. I filled up the grey tank to 100%, and then some. I let it sit for over an hour, checking for leaks very carefully and with a very bright light and white glove test. I also opened and closed the gate valve a few times and checked for leaks. The grey tank valve in this 2016 model is extremely difficult to do. Unlike the black tank valve that has rubber pipe connectors to loosen up for wiggle room. Next time, I drive to Tennessee and let Oliver curse through that grey tank valve. Errrgggggg. If you have a bad back, are over weight, or have arthritis in the hands I would think twice before attempting this. I hope the newer models have improved this part replacement. I had to rest my head on the jack motor several times. Oh, long arms are required. I've annotated some pictures. No certain order. Hopefully the plumbers grease will add an extra two years of life. I think the job could have been substantially easier if the gate valve could have been 1/8 to 1/4 inches off the basement floor. It would have at least saved time getting the two lower nuts off and on again. It's tricky for sure. I'm considering doing a short video with the pics and doing a voice-over to describe the challenges. In some of the pictures you can see what I believe is the grey tank sensor board in the background. Be careful with tools around the sensor, it could be damaged and work even less affective than it already does. I used a hammer as leverage to separate the grey tank side of the valve with the main black tank pipe. On my TT many of the electrical wire bundles were between the hull and the main drain pipe, preventing movement. I was however able to lift the bundles up to relieve some of the pressure on the drain pipe. 2 8 Chris 2016 Legacy Elite II o--o Hull #110 o--o Wayfinder o--o Twin Bed o--o 2020 RAM 1500 Limited 5.7L Augusta, Georgia Link to comment Share on other sites More sharing options...
Harley Posted May 14, 2023 Share Posted May 14, 2023 Wow! Awesome job and awesome pictures to illustrate! I'm a master plumber and I'm not looking forward to tackling that project. 1 Link to comment Share on other sites More sharing options...
rideandfly Posted May 14, 2023 Share Posted May 14, 2023 When replacing the black tank valve, used a piece of double sided tape to hold the nut while threading into it: 10 2015 LE2 #75 / 2024 F-150/5.0L Link to comment Share on other sites More sharing options...
Moderator+ ScubaRx Posted May 14, 2023 Moderator+ Share Posted May 14, 2023 3 hours ago, rideandfly said: When replacing the black tank valve, used a piece of double sided tape to hold the nut while threading into it: That's cheating... 3 1 Steve, Tali and our dog Rocky plus our beloved Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4 Link to comment Share on other sites More sharing options...
MAX Burner Posted May 14, 2023 Share Posted May 14, 2023 7 hours ago, ScubaRx said: That's cheating... If ya ain't cheat'n - ya ain't try'n!!! 1 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX Link to comment Share on other sites More sharing options...
rideandfly Posted May 14, 2023 Share Posted May 14, 2023 12 hours ago, ScubaRx said: That's cheating... 4 hours ago, MAX Burner said: If ya ain't cheat'n - ya ain't try'n!!! Yep!!!! 😁 1 2015 LE2 #75 / 2024 F-150/5.0L Link to comment Share on other sites More sharing options...
Patriot Posted May 26, 2023 Share Posted May 26, 2023 On 5/13/2023 at 8:53 PM, rideandfly said: When replacing the black tank valve, used a piece of double sided tape to hold the nut while threading into it: That’s wisdom! Learned this sticky trick years ago. Great to see it still being used. Thanks @rideandfly! 3 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina 🇺🇸 Link to comment Share on other sites More sharing options...
