In my teardrop, I'd leave the lid on the Fantastic Fan open all winter for ventilation. Never had moisture problems, but it was completely different than the Oliver.
I received a pack of the DampRid tubs and a pack of the IV bag style from Amazon today. I've never used them before, and to me it seems like they would counteract each other. One removes moisture, and the other allows air circulation, which would include moisture.
Winters here are moderate, with only a few days below zero, maybe a couple feet of snow total, and plenty of overcast days. What's the recommendation on leaving the roof vent open?
Thanks!
Steve - Northern Ohio, USA
Facebook - Instagram
Steve, do you store your trailer inside or outside?
I'll let people from your climate zone answer your question.  In Florida, I leave it open.
Ours will be sitting outside in Indiana. I'll be leaving the vents closed.
I'm leaving a counter top dehumidifier running all winter in the Oliver. I don't think it's going to do much as when the temps drop below the 40 degree mark, it's readout on the front as well as a second hydrometer in the camper usually read a humidity level of less than 45%. I'm also leaving a small electric heater running all winter to keep the inside temps above freezing. This will allow the compressor style dehumidifier to run all winter without low temperature issues. It has a drain hose hanging in the galley sink so it won't have to be monitored regularly. Of course ours will remain connected to shore power throughout the winter storage.
https://www.amazon.com/gp/product/B0BTBYT96F/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B0BB725X9J/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Thanks!
To directly address your question Steve, I would recommend closing the trailer up tight if you are using moisture absorbing packs. If you leave the vent open, whenever the humidity level outside rises higher than that in the camper, new moisture will be introduced into the camper which the desiccant will have to absorb. These packs only have so much capacity. If the camper is closed tight and the humidity level is brought down, the camper should remain dry after that until it's opened up again.
On our boat, and in the Ollie, out of season, we remove anything that absorbs moisture.  Cushions, bedding, towels, etc. (Florida) Those items live in semi-comdtioned space, in the garage.
We clean the heck out if the interior, before storage. And, I wax the interior walls and other fiberglass surfaces. The one year I didn't, I got som mildew in the bath sink top. (Not granitefiber-original white , that was a pita to remove.)
  • Wow 2
Here in Western North Carolina our winters are a tad milder than yours.  The advice from Ollie-Haus above is sound.
I use Damp-rid "tubs" so that I can simply use them year after year and just buy the "refill" jugs to keep them topped up during the winter - I only usually all an inch or two once during the winter.  Never had a problem with moisture although like Seadawg I too remove my mattress and cushions and rugs for the winter.
I buy the sort of damp rid tubs at my local dollar tree (now dollar + a quarter tree) store. They work very well. I keep them un sinks, and shower floor.
damp rid us quite expensive.
An important bit of info I left out! It will be sitting in the driveway uncovered.
We’ll be in Florida for the Egg Rally in January and then visiting my brother in New Smyrna Beach afterwards. We’d planned on bouncing around Florida for a bit until I found out all the campgrounds are booked solid a year ahead. Then a stop in Murfreesboro to seem some guys about ceramic coating and then home until spring.
Bill, I saw the refillable tubs, and will use those in the future if this works out okay.
Chris, I can imagine how fast my electric meter would spin leaving an electric heater going all winter! 😳 I do that in March this year instead of winterizing for just a few weeks, and could almost feel my wallet getting lighter.
I’ll close the vent. Thanks for the help, gang!
If you poke around, you can find sites, especially weekdays. But, it's tough.
We rarely camp in Florida in season. Some beautiful state parks, outside of urban areas, may still be available.
😆 I get what you're saying Steve, and to make it clear, this is an experiment first and foremost. I know I'll have the "climate" under control in the camper, but what I don't know is how much this will cost. 🙄
If it's ridiculous I'll simply revert to plan B. I do plan on keeping the camper just above freezing inside, we'll see how that works. Part of the experiment is on how well the little heater can keep up. Also how warm the basement spaces stay throughout the season. I have recording WIFI sensors in both sides and the battery compartment for tracking. Here's to throwing money out just for the fun of experimentation. 🍻
Those "tubs" that are available at the $1.25 store are very small relative to the ones I'm talking about.
I do place one of those $1.25 jobs in the shower pan, but I also put tow of the larger "re-fillable ones" in the aisle.  I know that the large tubs have been available at WalMart in the RV section from time to time.
I have used DampRid 1 gallon containers for years. I keep everything closed and install one in the rear and one by the dinette with the bathroom door open. I keep EvaDry charcoal packets in the closet and another in the bathroom. Very happy with the job they do
On 10/28/2023 at 5:53 PM, Steve Morris said:
DampRid
Beware of potential ill effects from formaldehyde. Many people are fine with exposure, but others suffer greatly.
my Oliver has camped here
I was not aware of the potential for problems. Thanks! I'll look into that
As far as I know - the "active ingredient in DampRid and "like products" is nothing but salt.
However, I'm not a chemist - therefore, there may be reactions to salt that I'm not aware of.  But, certainly there are no "warning labels" on these products that mention anything with regards to formaldehyde.
Since I’ve had bad reactions, I haven’t shopped these products in years. Maybe they have changed them, but I believe they still have the distinct odor of formaldehyde that I remember — as I encounter them on store shelves now and then.
A quick Google search produced this:
Damprid Moisture Absorber, Refillable, 10.5 oz, Twin Pack Packing, Solid, White to Off-White, Composition: Calcium Chloride, Sodium Chloride and Potassium Chloride, 2.15 Specific Gravity, OSHA Approved, For Bathrooms, Basements, Clothes Closets, Laundry Rooms, Bedrooms, Offices and Kitchens.
I looked at the chemical composition of formaldehyde (and the EPA data sheet) and I don’t know enough about the chemistry to know its various forms. It could very well be that many product manufacturers have stopped using it, given its carcinogenic effects. It’s still used in a lot of things though (wood products, clothing, building materials, etc). One article actually reports on the use of desiccants to absorb and remove formaldehyde from the air — so it’s hard to say. Maybe just ignore my comment about it.
