My cellular antenna has become unattached from the roof, holding on only by the attached cable.  It appears that it was attached by some sort of adhesive only.  Does anyone know what type of adhesive I should use to reattach it?  Would exterior double sided tape work? What does the factory use?
No, it appears to be yellowish. I haven’t tried to remove it as yet, maybe it’s adhesive tape?
  • 5 weeks later...
Sorry, just seeing this a month later...
I would use 3M VHB 4950 tape. You must clean ALL old adhesive, down to bare metal or plastic, clean with alcohol on both surfaces. I get so many products with two-sided tape included and if the mount is important, I throw it out and use the 3M product.
Hi John, yes I believe this is what Oliver recommends.  Unfortunately I couldn’t find it locally and was leaving on a trip so I ended up using ext/int Gorilla double sided tape. We traveled from CT to PA to VA to SC and back and encountered rain, sleet, and heat along the way with no problems.  This may not be the best solution but I don’t believe that the antenna will detach again.
  • 1 year later...
Mine also came loose, on my way to pick up some 3M VHB 4950 or the redialy avalible Gorilla DST
Hull #1238 - Legacy Elite II, TB. TV 2017 Tundra TRD.
Gorilla tape OK for a trip to Depot or True Value… Get this instead and at this price, buy two and keep a roll in the Oliver. Since I found this for you and the price dropped from $20, I just purchased an Oliver-only roll!
https://a.co/d/dMG8apM
Edited by jd1923
Same issue a few years ago. I cleaned the hull area where it was mounted with alcohol first removing any residual factory adhesive. I secured it with 3m VBH tape and it has not moved. 👍🏻
Edited by Patriot
