re-installing rear egress window
Faust
we had to replace the glass in our rear egress window because of an altercation with a weedeater and some rocks (argh).  anyway…when the window was pulled out 4 black clip-like plastic pieces fell out and my husband didn’t see how they were installed.  We are wondering if anyone could tell us how to use these?  are they necessary?
Can you post a picture of the clips?
Truma water heater & AC
Your rear window is likely double pane. The clips, as photoed, appear to be wide/ created for double pane.
In Florida,  I'd have taken the mess to Suncoast Design.
I'm sorry for your troubles.
I don't have your windows, so I'd open a ticket, and ask for installation instruction manual, specifically. Possibly just shims. The clips served a purpose,  at some point.
Best of luck to you.
Those look like shim clips to make the window tight against the sill.  I could get a better idea by looking at the hole and the window.
ARILINIAKSKYLAMIMNMONMOHOKPASDTNTXVAmed.
On 1/29/2024 at 6:33 PM, Jason Foster said:
The shims are talked about here (time stamp 6:30):
this is helpful I guess the pieces must all be for spacing.  If we can’t figure it out I’ll open a ticket.  And yes it’s 2018 TB model.  Thanks everyone!
