  1. Today
  2. Regardless of usage, there is a MAX wattage spec for electrical appliances sold in the USA. Pretty sure it's code, see label picture, "CONFORMS TO UL STD.1026" so that electricians know how to size wiring and fuses/breakers. Also, part of RV solar planning is to add up the wattage of each appliance and to estimate how many hours per day of usage, and so forth. We use the induction cooktop that @Ollie-Haus made us aware of in an older post. My wife likes it so much that after she was using at home too often, I purchased a 2nd one for the Oliver only (I like our Oliver always ready to go, fully equipped). It's rated at 1800W which is listed on the Amazon title and on the product label underneath. Wattage spec should also be listed in product literature and user manuals. https://www.amazon.com/dp/B07KSNTSVR/?th=1 I do not get this statement either, "the stove itself." How can an appliance possibly know what it's wired to, or know whether you're on inverter or shore power? We run our induction cooktop often at the full #10 setting, for example to boil water for pasta. I promise you, I could run two of these 1800W induction cooktops at the #10 setting wired to our Victron Multiplus II, no problem. The Victron is rated at 3KVA, but I've had it pushing near 4KW (by accident) and it will do so for quite some time, alarm sounding, allowing me time to turn something off. 😎
  3. As I said, from page 2
  4. Caulk used Adhesive remover used Plastic razor blades from O’Reilly Razor blade holder also from O’Reilly Bill
  5. Interesting. That corresponds pretty well with our WeighSafe hitch, which usually reports a tongue weight around 550# with a full loadout, including full fresh water and empty grey/black tanks. Our closet floor is mostly tools.
  6. Yesterday
  7. Making the popcorn now...
  8. I called Parts earlier this week and got the $350 number (just for the front logo) and they only had one color that did not match my sides. Ngl, I'll head back to the vinyl shop tomorrow -- probably tow over there -- and ask them what it would cost to repro the entire OEM set. I will then compare the number to an actual wrap. I cannot imagine the latter being competitive but if its within 20% I might just do a wrap. Would certainly be unique as an EII. For cars, wraps are usually a wash at-best for resale but we shall see. It's kinda crazy that this has run this long. You can literally run a hand-held scanner over the surface, import that into any decent photo editor, and then convert to vector graphics with just a bit of work.
  9. O2R - Thank you so much for giving us the conclusion of your Service story. I am so happy that things worked out for you. I am often perplexed by the stories I hear in which what happens seems to be at the entire opposite end of the scale. I'm simply not sure what's the cause of this seemingly drastic difference between quick through responses that , "Oliver went above and beyond on this one" and the owners that report complete dissatisfaction with virtually anything done by anyone working at Oliver. Perhaps your story and how you handled the situation can serve as a "road map" for others to travel. Bill
  10. My Bosch induction at home doesn’t. The burners have a boost setting but you can’t use them simultaneously. This is normal for induction ranges. It’s normal for most electrical appliances too and houses. Try running all your house lines at absolute full bore and see how fast you start tripping breakers. IIRC the national code specifies 80% continuous and non simultaneous use. Which is why total breaker ratings can add up to more than the panel can technically handle (200A typically). But you guys are still thinking in gas terms, electrical doesn’t work that way. But it doesn’t matter, induction is faster and more efficient than gas so you don’t need full simultaneous use. To answer your question specifically I don’t know as I’d have to have the circuit or block diagram of the cooktop to answer, or maybe they talk about it in the manual. Moot point as it’s pretty obvious. Another take, this is just the same as why I can’t use AC, wave and cooktop simultaneously. Making electrical support full simultaneous use is too expensive and not necessary.
  11. Below is the reply that I received an hour ago from Jason: "That's a tough one for me specifically as I have no idea about any of this or where to even find those graphics. Have you tried reaching out to technical support or service?" Bill p.s. I expect that it will take a bit of time before hearing back from Matt Duncan - as mentioned above - he only checks in with Oliver related subjects on an occasional basis.
  12. Yes, though every Oliver is packed differently! We always have a full FWT. The bottom of our closet is also wall-to-wall drinking water, wine, soft drinks. Very full pantry and Fridge. Back cabinets full of clothes, Attic rather Full, try to keep the rear basement light. Not sure if you have D52 axles and Alcans, but that’s a bit of weight too that is exactly centered! The 580 Lb tongue weight was one measurement taken on the same scale. You can add 600 lbs to the trailer and if centered add little to tongue weight. Tongue weight is light on the Oliver. Reason for WDH on half-ton trucks. Should be 10-15% of trailer weight.
  13. Not really though. I'm looking for the large front one. And maybe I just do all of them while I'm refreshing front. It's funny ... when I put my spec in I asked Sales about having no graphics -- this was back in '19 -- and never got a response. At delivery date I had black and silver. Had I been plain ole egg I had planned to take it to a local wrap place. I was going to go FDE and maybe tiger stripe. I guess I was just ahead of my time. :D ****...maybe I should do that now. ;)
  14. UPDATE: As you can see from my first post, we experienced the issue captured in the video late on Saturday the 30th. After reading the information provided above, and doing a little more research, I called and opened a ticket using the forum link to the ticketing system, called Oliver customer support and left a voicemail, and lastly I sent the video in an email to support@olivertraveltrailers.com with a copy to one of the leadership team. Sunday AM: I received an email from Oliver asking for the model and serial number of the Truma, which I promptly sent. Monday AM (8:30ish) : I called customer support at Oliver and I barely got out my name when the tech said, "oh yes, you were the first topic at our team meeting this morning. You should expect a call from someone on the leadership team to help resolve this." An hour or so later, sure enough, I received a call, and the ball was rolling. A full explanation of the plan to get us back up and running with hot water was laid out. (Note: My Aquago was not in the range of serial numbers that were part of the recall, but the plan we were executing assumed that it was. More on that later.) I was in Pennsylvania the day the issue occurred. I was in Buffalo NY headed to Rochester, when I received the first call on Monday. Oliver gave me several options for where I could have the burner swapped out, and we chose an RV facility in Rochester since we planned to be there for 3 days. Oliver next day aired the part, worked with the RV store to schedule the repair, and the work was completed Wednesday, and we were on our way - WITH hot water. 🙂 For the record, my AquaGo is under warranty. Whether or not the issue is the same one addressed with the recall, I don't know. I will let Oliver and Truma work that out, but it appears to be a different issue. Bottom line, Oliver went above and beyond on this one. There was one individual who was in the driver's seat at Oliver, and she will have a thank-you card and a small gift on the way as soon as we get to a stop where we can make that happen. We are grateful for the response and count ourselves lucky to be part of the Oliver family. Bob P.S. It probably helped to provide a video of a fireball on the side of the trailer. 🙂 Nevertheless, good job, Oliver.
  15. Ha! Ha! You beat me to it again. Well this should be interesting. Mike Sokol is doing his own testing, and doing a number of different tests. He just got 2 old Battleborn's to test them.
  16. I sent a message to Meridian Products regarding the difference between ASI 335 and ASI 335WS. This was the response that I received: (And I apologize for the change in the font size) “
The 335 and the 335 Window Seal are the same base technology, the difference is the window seal label. In addition the Window is listed with AMMA for Window Installation.” I suspect that the “AMMA” that they refer to is actually “AAMA” , the American Architectural Manufacturers Association. Bill
  17. @jd1923 It is interesting that our tongue weights are the same but your total trailer weight is 600 lbs more than mine. Bill
  18. Your answer is on page 2 of this thread.
  19. Both Jason and Matt have been sent PM's in this regard. Bill
  20. How many watts is the cooktop rated? The rating should assume full ON.
  21. If only half of degreed EEs had your practical knowledge
 Excellent work Geoff! Appreciate your design philosophy too! 😎
  22. Yah. I figured as much. Figured it doesn't hurt to offer. Back to #1, if folks are interested I can approach my local guy about working out a vector graphics from pictures. There's design time involved with that. However, if he knew that there were a number of people queued up on that then maybe he would waive or just roll it into price of orders etc. Y'all can let me know. Thx.
  23. Nathan - I will mention this to Matt Duncan and to Jason Walmsley (who handles most if not all things tech related for Oliver and used to work directly for Matt). However, I can tell you that Matt is very well versed in computer tech. He and I did discuss this very possibility when we initially sat down in his old office and were looking for the specific computers and memory stick backups. An additional "problem" at this point will be to identify which computers and which memory sticks might have been involved with these graphics. I'll let you know what Matt and/or Jason have to say on the subject. Bill p.s. Yes, I am a moderator. All of the Moderators of the Forum are NOT employees of Oliver Travel Trailers, and are not compensated in any way by Oliver for the work we do here on the Forum (i.e. we are volunteers). Yes, since most of the moderators have been around Oliver (for more years than we might like to admit), we tend to know a bit of history and the former and current employees that were/are involved with both the travel trailers and other parts of the overall Oliver businesses. Perhaps this is good news and bad news. Good news is that we tend to know "stuff". Bad news is that we also know that Oliver is a family owned business that does not have very much (if any) "fat". That is - they have a very lean staff with most of the staff holding down multiple jobs. Therefore, I'm guessing that it may take a fair amount of time to even get a start on the project you'd like to do.
  24. 1. If there are people out there still interested in resolving this, please tag this comment with some sort of emoji as a confirmation. More on that later. And not necessarily related to #2 below. 2.@topgun2, I don't know how the forums work around here but I assume if you are a mod you are either an Ollie employee or at least know them somewhat ... In a previous life I did digital forensics work. That means recovering deleted/over-written files. It's not always possible but sometimes ... Can you let them know I might be able to help? I can walk them through the process of duplicating the drive on that machine in such a way that a copy could be sent to me either electronically or physically to see if I can recover anything. thx
  25. I heard that😁 But I'm no EE
 just an uneducated and curious mind. The first priority in all my modifications — and frankly the cleverest aspect — was minimizing impact on the Oliver's stock functions and appearance. Most modifications can be removed without trace: no fiberglass damage, original functions intact. Everything is fully documented in a binder with detailed drawings any competent technician could follow. This should be a standard practice for every DIYer — and frankly, it's not something Oliver itself can boast based on all the speculation we see in this forum. Cheers!
  26. Thanks Bill, I'm sure many of us are interested! 😎 No CAT Scales in our county (50 miles to the nearest Interstate), so I take advantage of the simple scale at our Prescott Solid Waste Division (the city dump). I did not get separate TV axle weights. I go one day with TV plus TT and weigh the truck wheels on the scale, then all, then Oliver only. The next day I go back, Oliver detached and I add 220 LBS for Chris and her front seat stuff and our 65 LB Springer! I also used a Sherline tongue scale and measured the same 580 LBS. Your TV is a bit heavier than ours. The Duramax and Allison are certainly heavier than our 5.9 Cummins and Dodge 47RE trans, but the real difference comes from the weight of your truck bed cap that we do not have. You can see how our weights have increased in a couple years, getting closer on TV GVWR. We always have 35+ gallons fresh water in the truck bed and have accumulated more tools and camping gear, even spare hubs for TT and TV! The increased weight comes some from more gear but mainly the many mods and additions I've made in the last 2 years. D52 Axles and Alcan Springs is a good portion of the net increase. I'm getting closer on TV GVWR and not concerned re Oliver GVWR since we now have a 10K suspension on Hull #113! Love your old-school spreadsheet! I cannot write a simple to-do list without my favorite app Excel! đŸ€Ł
  27. This is kind of a petty question, but Im going to ask it anyways. We started to have the touch light flickering situation that others have had. I ordered some replacement lights to replace the 4 inch touch light from Amazon. I ordered some 12V 4" Obeaming 3000k lights from amazon. The lights fit just fine but were very yellow and dimmer than the lights that are in the trailer now. So we sent them back and I ordered the 5000K and they were very white , too white, and they ruined the ambiance that the original lights produced. So we decided to order another box of the 4000k lights, unfortunately to the eye they are just as white as the 5000k. So my question is has any one found a replacement light that is closer to the originals. I would imagine Oliver must have a replacement light that will match the other lights in color, but I haven't reached out to them yet. Thanks Bill
