If anyone can get to the show and Austin please post pictures and details.
Yes you can fit a piano in an Oliver!
jd1923 replied to DanielBoondock's topic in Ollie Modifications
Find the right size/depth brackets for your piano case which will take a bit of searching. Use 3M VHB 4950 tape ONLY to mount to the fiberglass. 😎 -
For sure. Ours reads the same 13.2V now and we’re at 48% SOC. We’ve been parked unplugged for the week, running the fridge on DC. And that much voltage drop? Battery health or wiring? Get rid of that Optifuse breaker, replace it with an ANL fuse, clean/tighten all terminals.
Your stated battery voltage of 13.2 is on the low side, which suggests that the battery charge is low. You also mentioned that the inverter cutout on low voltage at 12.1, try setting it to 12.0. Also look to see if there is a low voltage cutout delay setting. This accounts for larger current spikes and it should be around 15 seconds. If the battery was full, and voltage is still that low, then defiantly look for a high resistance connection, such as the 300 amp dc breaker. It's easier to check the breaker by taking a voltage reading across the input and output terminals, first with microwave on, then with it off. The microwave's current load should result in less than 0.5 volts difference. When hooked to shore power and charging the battery, or running a convection oven, the load is higher and voltage drop would be higher too. Good luck and let us know what you find. Geoff
Geronimo John started following Xantrex Inverter
Step One: I agree with Tom and Doreen's post. Step Two: If you put a volt meter on each side of the breaker and use a common ground for the - lead, you can measure the voltage drop thru the breaker. If it is nominal, then the next step I recommend is using your brake temperature IR gun to scan all the 4/0 terminal temperature. They all should be about the same. If you find one hotter, then make the system safe and clean that terminal. Then retest a second time. Clean the next hottest one and retest. Repeat until you see all of them about the same temp. Good luck. GJ
Made in USA leaf springs
Many of us know that feeling. We purchased ours from Hawaii having never seen one in person. But what we, as you, did was to really study the tone and helpfulness of the members here on this forum and the "SOB's" (Some Other Brands) as well. At the time, and still to this day, I think that the owners sell more trailers than OTT does themselves. No other brand came close in this regard. After our purchase I had an opportunity to go to the factory tour and instantly fell in love with our decision. As a technical we all know that machines need maintenance and TLC. Also that some times tweeks to the foundational design of a machine is necessary. WIth OTT, we have seen a few upgrades, a few changes, and very few OOPS. And the number of OOPs is very smal. However over times things change. The two biggest changes I have observed in the past ten years from an owner's perspective likely are the percentage of owners taking their OTT's boondocking further into the wild and running heavier than earlier years. The impacts are higher "G" forces and typically +/- 6,000 pound weights on the suspension 100% of the time. Both of these changes are not OTT fault. There is clear evidence of premature spring failures from OTT owners having road side spring failures, and dozens more finding that their springs flatening out way too early in what should be a normal spring's useful life. So a design change is needed. I believe from history that OTT would not ignore such failures without concern and would be monitoring our experiences. I also would wager one of Art's famous home brews that they are looking at an upgrade standard spring to the 2400 # Dexter four-leaf springs and an option for a "Boondocker's Heavy Duty" suspension package featuring the Alcon type of 5 leaf. Those options both make good common sense. Good news is that OTT takes a lot of care and time, as they should, before making such changes. In that regard it would smart to keep track of the owners who have changed their springs and to monitor them in the normal duty and heavy duty class. In doing so to get specific data as to the pros and cons of their spring choice for their use. If I was running their quality control team that is exactly what I would be doing. One needs data to to make data driven decisions. GJ -
From one pic I saw, it looks like it might be running a 48V Houghton AC/Heat pump.
rideandfly started following X23
Another Oliver owner sent me this link earlier today: https://www.facebook.com/reel/996171699418948 Edit: The above link on Oliver's Facebook page: https://www.facebook.com/olivertraveltrailers/reels/
Yes on FB, but no interior pics or specs. I guess we need someone who lives in the Austin area to go to the show and check it out and report back what they saw, lol.
Yes I've had that problem. In my particular case the circuit breaker ( under the street side bed - Optifuse 300A 48V ) on the input side to the Xantrex inverter was bad, the contacts were pitted. This caused a voltage drop when subjected to a heavy load such as when the microwave was used. Depending upon what year your trailer is you may have different components, some trailers have a marine switch instead of a circuit breaker. In my case I replaced the circuit breaker with a marine switch. To be safe give Oliver service a call to see what they have to say.
It’s on Facebook, too. Apex X23.
I’ve seen notifications on LinkedIn and X this morning for a new Oliver model, the X23. It’s described as an off-road trailer with blacked out trim and a 48V power system. Nothing on the Oliver home page. Anyone else seen anything? Mike
Anyone with Lithium Battery package have trouble with running Microwave? It shuts off for low battery voltage shutoff! It will be at 13.2 and immediately drop to 12.1 and shutoff! Has anyone else changed the low battery voltage shutoff parameter in their, inverter? If so, what was a good level for setting? Thanks!
Been a member for four or five years 🙂 took me that long to make my choice. Oliver was the first choice but then Bigfoot seduced me with that cool BIG FOOT front storage. Got a tour, meh, and noticed the seams and conventional RV hardware everywhere, so came back into the fold. Pretty brave, or stupid too as it was sight unseen, they’re rare out on the West Coast -
DanielBoondock replied to DanielBoondock's topic in Ollie Modifications
There are electronic drum kits as I’m sure you know, takes set up but would work, and won’t bother the wildlife My son got a Donner travel guitar for our inaugural trip which is pretty much ideal, nice and small. It’s basically electric with no spruce soundboard and uses pickups, but you can get a nylon string version and the internal DSP sounds great. He loves it and thinks the action is good Z brackets is a good idea I’ll check out, looking for easy DIY -
Per the above posts, even that group is seeing failures. Time for OTT to wake up to the reality that the owners want a change to a stronger spring. For JD's sake I'll not go further on that! LOL GJ -
The #1 Ollie Tool I purchased was the Lock-N-Lube lock on grease gun fixture. It is amazing and certainly helps. I had a new ole style grease gun and just added the below to it. Love it. With it I did not need to go right angle. I liked the 45 degree ones better. Especially with the below. When I need to replace my grease gun, I'll pay the bucks for the Lock-N-Lube version for sure JPR -
Love your install! You should add Z-brackets on both ends to replace the blocks and then your full-size seat cushions are good as-is! Keep us posted. I take an acoustic guitar on our longer trips and that alone is not so easy. Have a high-end travel case which helps. It lays on the bed when towing. When we sleep it’s standing up at the entrance, or on the back seat of the truck, weather depending. In the bed is a strong folding chair to play anywhere comfortably! 😎 -
Mike and Carol replied to DanielBoondock's topic in Ollie Modifications
My banjo fits nicely under the bed overhang on every trip… Mike - Yesterday
The power grease gun sits nearby on the ground, has a long hose with the lock-n-lube on end. Just attach, hit the power button for a few seconds. Used a manual gun for 40 years, always fighting it!
Steph and Dud B replied to DanielBoondock's topic in Ollie Modifications
You've inspired me. The drum set's going in! Just gotta get this bass drum through the door... 😁 -
if you’re a serious musician you’ll know my dilemma; ya can’t leave it at home. This is a Doepfer stage piano I used before I got my grand. Weighs a ton and is bulletproof with reasonably weighted keys and has a decent action. I’ve been sweating whether this could work but thankfully it will! Being able to fit a keyboard was a selection criteria. I think neither Escape nor Bigfoot would comfortably accommodate it and Oliver was a maybe or “I hope” Yes it looks silly but OH WELL, your instrument is the girlfriend you can’t ignore Those are Anderson blocks and actually work perfectly. Having it there is pretty fine, that side is awkward anyhow because of the sloping wall, this provides an arm rest so if you don’t have a big butt it works. And best of all the table fits on top so no fooling around setting up. I just need custom cushions and most importantly a good chair that stows. The seat has to be good or it’s too hard to play Anyhow interested in ideas if ya got ‘em
axle and spring replacement at Alcan Spring
Ospreybob replied to Ospreybob's topic in Mechanical & Technical Tips
Thanks! I do have a shop here that has been doing the bearings so I’ll talk to them first. -
Yes a four inch drop on a two inch hitch and an adapter to go from 2” to 3”. I sometimes think the trailer looks slightly nose high but a level on the a frame indicates it is dead level.
I use the 90° Lock n lube grease gun with that attachment. It makes those awkward fittings much easier to lube. John
