  2. Robert, I see you're local to Alabama. Going to the Rally with pickleball gear? Ours are always in the TV. Last summer on our Minnesota trip we played in 6 states! I see there are two public court locations right at the lake! 😎 (Pickleheads app) We're sorry, but please don't bother. Remove the interior panel, loosen 4 bolts, cut wires and then all you need to do is get up rooftop and heave! 🤣
  3. Welcome! It will be worth the wait. What a nice part of TN you live in! Mike
  4. We got lucky and only had a few Smokey days in Gunnison a little smoke in the wet mountain valley we just missed the flash floods and landslides in Ouray, Telluride and near Ridgway,and the Black Canyon……..missed the Aspen fire and the Gold Mountain fire it was a fantastic trip our only bad luck was on the way home in Oklahoma's panhandle it hit 109 degrees and the demonic squirrel cage developed a significant rattle………and was out of service Night temps dropped down and a box fan allowed us to sleep didnt have a chance yet to take the lid off the Penguin
  5. Today
  6. That’s great information. Thanks for sharing. I will check out the Steele product. I would be curious about the Pelland as well. Let us know how that works out. Thanks again!
  7. I've been negligent in posting to my YouTube channel... More to come from last year's Big Bend trip...
  8. Congratulations and welcome! Your pickup date is so close. What an exciting time!
  9. Steele Rubber Products sells window molding weather strip (part # 70-4500-257), and it worked perfectly on my 2022 Oliver Elite II. I learned about it from another forum member who recommended it in a different thread. Another option is: Pelland Enterprises - (part # H109-376). I ordered both products to compare, but have yet to receive the Pelland product.
  10. Does anybody have a supplier for the weatherstripping that goes around the windows in a 2024? That stuff is nearly impossible to get clean and I would just like to replace it all. It comes from Lippert, but Oliver hasn’t been able to get them to provide any replacement rolls of the stuff. Appreciate your thoughts. Bob
  11. clear skies and no smoke, amazing. AQI here this morning is 136 and getting worse.
  12. We are Steve and Elaine. Soon to be the proud owners of Happy Hour - our hull # is 1730. We pick up our Ollie on 20 August (can't wait). We saw our first and only Ollie in the wild (so to speak) when our family members Mitch and Debbie brought their Oliver "Dickens" home several years ago. (We are just finally able to get our own and start traveling) We live in Maryville, TN and look forward to meeting everyone out on the road. Cheers!
  13. after 3.5 months on the road and the Colorado mountain hiking trails we are heading home…. pulling out of Alvarado campground USFS near Westcliffe, Colorado San Isabel National Forest Sangre De Cristo Wilderness we hiked mountain trails all over Colorado and hit the pickleball court in Gunnison our longest hike was 10.5 miles, 2600 ft elevation gain
  14. Google Maps has basic travel planning that is free. Please find an example link below https://www.google.com/maps/dir/McKinleyville,+CA+95519/Medford,+Oregon/Lake+Shasta+Caverns+National+Natural+Landmark,+20359+Shasta+Caverns+Rd,+Lakehead,+CA+96051/@41.427653,-124.1908508,7.61z/data=!4m20!4m19!1m5!1m1!1s0x54d15c594e280e27:0x585da6f91a139f5f!2m2!1d-124.0312661!2d40.9373196!1m5!1m1!1s0x54cf7c5b37361f6d:0x7db736c5541136e!2m2!1d-122.8767396!2d42.3230112!1m5!1m1!1s0x54d27d843f61b711:0x35bb1e6f54db32a1!2m2!1d-122.3039955!2d40.8042955!3e0?entry=ttu&g_ep=EgoyMDI2MDgwNC4wIKXMDSoASAFQAw%3D%3D
  15. I don't know, but i sure would be annoyed with a Rivian tailgating me the whole trip.😂
  16. Yesterday
  17. In the past, I have used RVparky for my trip planning. I have 5 trips saved on the site and it will not allow me to add another trip unless I pay to upgrade to the PRO version. Are there any other trip planning sites to use that are FREE to use (not with a 7 day trial)? Thanks
  18. We like Panther Creek too.
  19. The back of the shower box is exposed in my 2018. The hose at the shower head was leaking. I replaced the entire shower hose and it was easily assessable to unscrew the old hose and screw on the new one.
  20. We often stop at Panther Creek. Nice campground. If anyone is looking for Harvest Hosts or campgrounds along I-81, we have some favorites.
  21. This fall we will be attending the rally in AL, but coming from Niagara Falls. So, kind of similar? We are choosing a pretty "super-highway-friendly" route this time: Niagara->Watkins Glen-> New River Gorge-> Panther Creek SP-> Lake Guntersville. With multi-night stops along the way. Enjoy your trip.
  22. "Quite easy?" You're a good mechanic! It is easier to purchase and install the entire preassembled unit. https://itcshopnow.com/products/exterior-shower Our shower failed in the same way, the same plastic part shown above where the shower hose connects. It must be from pulling on the shower hose. Drilling and replacing the rivets is the easy part. Do it, don't worry. They are aluminum rivets so each head drilled off in 5 seconds. If you go this route, you can loosen and reconnect each plumbing fitting sitting on a crate outdoors vs. kneeling on the cabin floor and reaching inside the cramped basement. After the old shower assembly is removed, drill the rivets through. Then screw a sheet metal screw in and turn the rivet butt, push in, give it a tap if needed, and grab it from the backside. Connect the water lines by holding pliers on the copper ring of the PEX so it doesn't twist. Make these good hand tight or gentle with a pliers. Then when the entire assembly is still hanging exterior to the Oliver as pictured, turn on the water pump, blead the hot and cold lines and test for leaks. Then push in place and rivet the four corners. I had rivets in my shop that were 3/16" and about 3/4" long. OEM might be 7/32" or 6mm but mine held it nicely in place. UPS arrived with the part today and in an hour or so, job done and we have a brand new outdoor shower with leftover parts saved, like a new shower head replaced just last year. 😎
  23. Welcome to the group and great picture! Mike
  24. Last week
  25. I recommend you ask Google AI. I believe the Victron Orion XS 12/12-50A DC/DC charger can be programmed to reduce output (and therefore strain on the alternator) at idle, if necessary. That feature may allow you to install one connected to your 200A alternator.
  26. I-95 north of roughly Richmond, VA can be horrible, especially Washington DC through Boston. We try to avoid it like the plague. I'd take I-81 north then head east on I-90, but be aware of the tolls. (Also, FYI, in NY and CT, only passenger cars are allowed on Parkways like the Taconic State and Merritt.) We live in CT and try to stay off I-95, even in our car. I-95 north of Boston isn't too bad. There's an old joke about a tourist asking a Mainer for directions that ends with, "well you can't get thar from heah..."
  27. First Post, awesome thread. We were on Lopez Island, WA over the weekend.
  28. Love I-81, through the Shenandoah Valley, along the Blue Ridge, etc. You did not mention this Interstate but could be on your route. When we lived in northern VA and traveled often to see parents in Florida, we often traveled I-81 south to I-77. The conventional thinking was I-95 is direct but one of the worst, most dangerous interstates in the country, IMHO. I also try to map as many non-Interstates routes, as much as possible. For example, we drive from Prescott AZ to anywhere in Texas and I only get on I-17 for 10 miles in AZ, because there's no way around it. The next 1000 miles all on US and state highways. Most everybody else takes I-10 or I-40, boring. Tow less per day, see the country on the secondary roads, stop anywhere in the Oliver overnight! 😎
  29. Looking at this trip later in August using the following interstates. Traveling north on I-10 to I-65 to I-85 to I-40 to I-85 to I-95. Has anyone have any thoughts (positive or negative) on using these interstates? Thanks
