High Pointe Convection Oven Tripping CGFI Breaker
Steph and Dud B replied to 2008RN's topic in Mechanical & Technical Tips
Ok, so those settings may have been incorrect, but that's not causing a breaker trip. There's still something else going on. Can you run a heavy extension cord (12 gauge) from an outlet in your garage directly to the plug/cord on your microwave? (Don't use a cheap cord, it could melt.) If the microwave works that way, there's a problem in your trailer, either a wiring fault or a bad breaker in the Xantrex. If the microwave trips your garage breaker, there's a problem with the microwave and it should be replaced. - Today
KCR joined the community
I moved the Oli out of the RV port and next to the house. Used a non-GFCI breaker in the garage that only feeds the air compressor. I ran the test again. This time I went about 5min 30 seconds when the power went off. I check the non-GFCI in the Garage and it did NOT trip, I checked the built in GFCI breaker in the Xantrex and it did trip. Still took about 5 minutes to be able reset the GFCI. Every time I press the button in it would click and pop the button back out. The EMS still reading 12A. I check the Xantrex setup, the LBCO was 10.5, and LBCO Shutdown delay timer.was 300. I missed these values when updated from AGM to (2) Epoch 300AH batteries (totaling 600AH). I used the custom [USE] setting for the Epoch and set Absorption and Float to Epoch specs. So I will need to update the LBCO and LBCO shutdown delay to suggested setting. (LBCO 12.0 or 12.1, then delay of 10. -
It is the Circuit breaker builtin to the Xantrex accessing it through the 6" inspection port below the pantry. - Yesterday
Happier Camper with LEGO modular interior furnishings
Galileo replied to John E Davies's topic in General Discussion
According to their web site, they do still make a “Traveller” model. Funny thing - if you enter “Happier Camper” into the Google search page - first hit that comes up is “www.OliverTravelTrailers.com”. Apparently, someone at OTT marketing has some web savvy! 😂 -
I know this will be hard for many to understand and/or believe. But if you are camping in our northern Wisconsin State Forest/State Parks you will note that most of the campsite leave a fair amount of gear outside at the campsite at night and when elsewhere without fear of someone taking something. It is just that way in this part of the world; really it is the rural upper Midwest. I have been camping for over six decades and have never lost an item.
Todd B replied to John E Davies's topic in General Discussion
We looked at these for a while as well. I like them, but for us, they were too utilitarian. -
Mountainman198 replied to John E Davies's topic in General Discussion
They used to make a larger model called the traveler. I came real close to buying one seven yrs ago from a dealer in Denver (same dealer that used to sell Olivers). Price on this particular new HC traveler was less than $30k but there were several issues with fit and finish that I was not comfortable with (e.g. big gaps around door when closed, modular cubes were warped). Nice little trailer and I hope the quality issues have been resolved. -
We really like state parks. I guess we have been lucky, nothing has been pilfered. We leave the cap wide open and setup when we leave it to look around. We do lock the trailer. I have found most parks have city water at the site. We did a 4,000 mile trip up to NY and back down the coast to VA and back to Arkansas in 2024 and I think a SP in Indiana is the only one with no site water. We did 7,000 last year out west to Montana and down the coast to CA. Every SP had water. Maybe it is a northern thing.
srthomsen replied to John E Davies's topic in General Discussion
While in Seligman Arizona for a Rt 66 event we saw one of these (blue & white) in the parade of vehicles headed to Kingman. -
Galileo started following Wisconsin State Parks and Happier Camper with LEGO modular interior furnishings
I just saw one for the first time yesterday at Glacial Lake SP - had to look it up. Apparently, they don’t get much bigger than this one. Web site says they ARE double-wall fiberglass - but weigh way less. I haven’t talked to the owners yet, but curious how they like it. -
As a friend of mine would say “camping is a 4-star hotel without room service”.
Some of us still backpack.
We stayed at a couple of private campgrounds and “RV Parks” in WI. Some were actually pretty nice and not terribly crowded - like the parking lots with hookups - that many RV Parks are. Yes, they cost more - but you typically have more amenities - nicer showers, laundry, maybe even cable. Though we like and gravitate towards State Parks - we’re finding that security is frequently lacking. Very truncated staff hours - especially mid-week. Often no access control at all. We’ve seen some pretty shady characters come and go as we’ve traveled across the country. Just a casual reminder to keep anything loose and remotely valuable locked up.
The one we’re at in Minnesota (Glacial Lakes SP) doesn’t have water at sites either. The downside of the Northern states I guess. We’ve been to a couple of Western and Northwestern states that have water, but either don’t turn them on until (what I would call) pretty late in the season - or - use the “freeze proof” hydrants. ‘Course, they’re only freeze proof if they’re turned off and allowed to drain. I froze my hose a couple of times. (I mean that literally by the way…) and ruined my good regulator and pressure gauge by leaving them hooked up when the temps dropped to 18F one night.
I thought “camping” was that thing people did with tents, sleeping bags, and cooking over an open fire? I guess to some, even that would be a bit wussy.
I would not jump to that conclusion. Think of this as a next step in testing. If it doesn't work, meaning your oven blows a 20A non-GFCI circuit breaker, then your oven is drawing too much power and should be replaced. If it works and your readout still shows it's using about 11A +/- then it's the GCFI. Once it has been determined that it's working in the above test, then look into the Xantrex. It's likely the low-power cutoff, but check out these posts. Too bad in the first one the OP never wrote back to communicate cause (this happens too often). In Bill's post a hard reboot solved his issue, or it could be something else. My fix for a 2KW Xantrex was to replace it with a 3KVA Victron MP2! 🤣 https://olivertraveltrailers.com/forums/topic/11320-xantrex-inverter/ https://olivertraveltrailers.com/forums/topic/9255-xantrex-inverter-issues-try-a-hard-reboot/ -
Potawatmie Park under construction this season. Other Door County State Park Peninsula is very popular. FireFly in northern Vilas Co is highly recommended. A real nice park on a small quiet lake. The area has many many inland lakes and thousands of acres of public lands. https://www.google.com/url?sa=t&source=web&rct=j&opi=89978449&url=https://northwoodswisconsin.com/northern-wisconsin-recreation/northern-wisconsin-camping/firefly-lake-campground/&ved=2ahUKEwiEw6jv_PeVAxUpoCsGHQQRLdIQFnoECGIQAQ&sqi=2&usg=AOvVaw25dOd2yyBQgR0ACbU_0RQL
I will give it a shot by hooking the Oli into non GFCI breaker. That will prove if the GFCI breaker to the RV port has problems/ causing problems. FYI: the previous owner never boondocked and always did full hookups. If it works on a Non-GFCI then that would mean that I would not be able to run the oven off of the Xantrex boondocking since the other GFCI outlet is built into the Xantrex. -
Gliddenwoods started following Wisconsin State Parks
Not at State run WI Natural Resource Government public campgrounds. However many very nice campgrounds. We call it camping...
So I went to a deep dark place with my Truma in the past because I always had condensate dripping down the curbside of my trailer and none down the street side, or from either condensate lines under the trailer. The condensate lines cross so that meant I was not getting any drainage from the curb side condensate tray. There is a second outlet on each side of the condensate tray that is supposed to allow water to drain down the side of the trailer if the condensate line is occluded. To make a long story short, the condensate line that drains to the street side was occluded somewhere in between the inner and outer hull, and I could not access this area. I remedied the problem by getting a y fitting and splicing the tubing coming from the street side into the tubing coming from the curbside. I never had any drainage inside the trailer. I should also mention that when my trailer is absolutely level, the ac lists to the curbside. Giving my experience, I would first remove the inner shroud and see if you can identify where the leak is originating. If you confirm it is condensate, I would then get one of these, https://a.co/d/0hkNDgD0, and pass the brush from the condensate drain tube as far as possible and see if it is visible from inside the trailer, since the inside shroud is removed. I would then do the same on the other side. If you determine one side is occluded, I used this fitting to splice the occluded side to the non occluded side, https://a.co/d/0d6K2v06. Maybe you will find a kink or other occlusion that can be fixed with out splicing. I had the outer cover off several times during this process, but found that the access and visibility is poor and I would not start there. I hope this helps, please feel free to reach out if I can help further.
I'm thinking you mean the GCFI 20A outlet you are plugged into had tripped. Your EMS readout displayed 12A which is the total input amperage from shore power, which would include the Xantrex charger if it was in fact charging at the time. Sounds like a temperamental GFCI to me and it's not the first time I've read this story on our Forum! Glad our home was built in 1980 when only bathrooms had GFCI outIets. If it was my garage or exterior outlet that I used for shore power, I would replace it with a standard 20A outlet, regardless of code. Or add a new 30A breaker to your service panel, run wire and a 30A dedicated outlet for shore power. This is what I did where we park our Oliver. Not running on the 2KW Xantrex? Check and lower your shut-off voltage setting which is often the case with Xantrex inverters (not Victron). Your oven pulling only 11A (12A - 1A) should run on any 15A household circuit, let alone 20A. And 11A on 120VAC is equivalent to 110A on 12VDC which translates to 1320W, which again should run on a 2000W inverter with a lot or room to spare! Could the oven be defective? Not likely, since it started up and pulled a measurement read by the EMS. You could think it's the oven since it blew on two power sources. But the microwave works. The oven must create a power spike the GCFI protection doesn't like. The only way to be sure is to connect to a shore power source that is not GFCI! The 30A shore power outlet at any campground are not GFCI outlets. Next time I need a GCFI outlet is the next time I take a shower with a live blow dryer in hand! 🤣 - Last week
Haoleboyk changed their profile photo
Is it the circuit breaker in the breaker box under the dinette tripping or the GFCI in the outlet under the dinette tripping? They are different devices. -
Keep your tongue raised slightly. We have the Dometic AC and had this happen. The trailer was dead level. I raised the tongue and the issue went away immediately. I also checked the two condensate after our trip and they were open.
@strhomsen, Good catch, your right, although the year of my trailer is in my signature area, it is not emphasized greatly. Yes changes have been made to the trailer manufacturing over the years and this fix specifically pertains to very early models. However, when initially discussing this problem with the factory, they said the valves in the new LE1s also had limited clearance to access that bolt. If that is the case in anyone's trailer, this mod, or something akin to it may help in the future.
