  2. Lexington Barbecue - at least by reputation. 100 Smokehouse Lane Lexington, NC 27295
  3. Today
  4. Welcome to the tribe. What is the best BBQ there in Lexington?
  5. Dan, we disagree half the time and you always come back with something good.
  6. We got one of these right after our pick up trip in 2016 because someone leaned against the fridge and turned it off. A few years later, I called Charlie and told him I was giving a presentation about modifications at our Oliver rally and he sent me some that I could hand out at Lake Guntersville. That was before COVID, so probably 2019. Glad to see they are still available. Mike
  7. Why should there be? My flatbed trailer which we use to haul dirt bikes has one (no house batteries on board). Have you touched one on your Oliver? Something starts your 9K LB sled of batteries! 🤣 You’re going to have to realize 99% of us have “starter batteries.” When you go off in EV-land, like what the F is a Frunk? 🤣 Please translate to those of us who turn the key to start a combustion engine, gas or diesel. We have “starter batteries” and we all have “house batteries.” Pics if your EV fuses, hence my confusion. Thank you. And we have many posts here on disconnecting the AUX wire on the 7-blade connector. This winter, please come to Quartzsite! I’d love to meet you! Spend some time with us, including Steve @ScubaRx. He’s The OTT elder, the guru of everything OTT. Me, I’ve rebuilt everything I’ve ever put my hands on, after 3 years with Hull #113, there’s honestly no better Oliver out there, IMHO of course! 😎
  8. Yesterday
  9. @dewdev and @jd1923 littlehousecustoms.com sells the button guard below, which we found totally eliminated the accidental RM2454 button push. Mossey FRIDGE BUTTON GUARD Who hasn’t bumped the fridge control, switched to DC and run their battery down? This new version is made for us by Charlie Young. It's clear, fits the fridge well and doesn't require removal to operate the buttons. It attaches with clear VHB tape to the control panel. The red color in the photo is the release film on the guard and peels off prior to installation revealing the clear VHB tape. Button Guard $14.95 Add to Cart
  10. That’s just the fuse box for my truck in in the frunk. Basically the high power ones including a 30A for the trailer 12V Don’t know what they had before, just assumed this was standard but sounds like not. In the ‘26’s (mine) my understanding is the 12V truck power is only used to charge the Brightway controller unit. It’s a closed circuit, so there’s three power systems in the truck, this, the 12V and 120V. One of the electrical mounting panels has lettering for a DC to DC controller, so presumably the ‘27’s will offer an upgrade for that to charge the house batteries off the truck (don’t want/care about myself) So there’s no battery in your breakaway unit? Interesting … oh! OK, I think this was done in preparation for the DC-DC upgrade. You can’t have the house battery feed back to the brake controller, so they put in the independently powered unit above, and then they can tap off with a DC to DC converter too. Good thing; safer, in the rare case that the house batteries are offline or dead. Bad thing potentially; I need to make sure that battery is taken care of. And already I’ve got a short. So for ‘26’s and on, a potential failure is if your trailer isn’t towed for a couple months, these batteries might die. I get the impression that Oliver might not have thought of this. No starter battery in an EV, it’s a very small 12V SLA to power the computers and act as a buffer from the internal inverter. But that’s not important, if I understand you yes the ‘26’s have isolated circuits, but sounds like yours the breakaway is powered off the house batteries.
  11. @jd1923 I too love watching "My RV Works". I also still have the Dometic RM2454. My fridge will not stay on left 5. The light usually goes out after a while or immediately depending on ambient temps (so it seems). Not sure it's the eyebrow or board. I've been wanting to delve into it more, but I'm a bit afraid I will break something worse. I'm such a scaredy cat. I don't mind breaking it with someone with me or if it doesn't work at all. LOL. I'm so complex.
  12. I'm not getting this. Do Oliver TTs have something new in late model units? And I don't recognize the fuses in the picture above. Not familiar with Brightway either. On our Oliver I'm pretty sure the breakaway switch uses power from the house batteries applied to the brakes when the pin is pulled. I often pull that pin manually to test for amperage at the trailer brakes. I have a breakaway battery on a flatbed trailer we own. It needs one since it doesn't have house batteries. Is this not disconnected by design? (so that truck starter batteries and house batteries are isolated.)
  13. Welcome @Chuck and Beth. I took nearly 10 years to decide on a camping vehicle/format. Can't say I rushed into things. Enjoy it and continue to learn how things work on your Ollie here in the forums.
  14. Update on the breakaway unit. The 12V is dead and won’t take a charge, supposition is the 12V is internally shorted. Under warranty Brightway is sending out a new unit as they can’t break out the battery separately. Which brings up a DIY project … I have a Honda 7000is generator which has a similar small 12V SLA. Got it long ago before the EV came along which now powers the house in an outage. Early on I found that the starter battery dies after a couple months of not being used, pretty much like any lead acid. With a battery minder on it doing the conditioning its fine. What about the breakaway battery? If these trailers sit for a couple months off seasons I’d expect those to become very unhappy. When’s the last time you checked your breakaway battery, is it still viable? I think what I’ll do is make up a 7 pin socket to 12V port and make sure it’s plugged in at least once a month to top off. Ideally later with a more permanent solution.
  15. Yeah that's a boundary condition. If you were a painter that would be the picture frame you're working in, so you don't think of it much (or at least us lab rats don't, the marketing guys do 😅) Like, a 100 ft canvas is off the table, but the market will support a 4' portrait, so figure out how to make a picture within that frame. Which is why govt jobs go off the rails so easily if they're not fixed price contracts 🙃 tl/dr The Oliver is pretty fascinating from a project standpoint. Never ceases to amaze me how the way you set up a project determines where it ends up. The Oliver brothers put 'The Big Idea' as it's called as "Highest quality". So nothing was spared. I marvel at the complex shape they have for this body. They actually molded in a 'glass skirt to hide the frame! But wait, it does more, it also acts as a water basin if any leaks occur. I've gotten a few big one setting up a filter unit. No shorts, the water just collected and drain, no damage at all. Hold on, what else? Those provide inner body channels to run piping and hoses. Finally it so happens to also provide wire run channel under the trailer, for propane and two exterior cameras I installed! Utterly protected and a snap to install. That's some genius design in one feature, just because they're not afraid of doing fiberglass and went the extra distance on the body shape. I'm a weirdo, I'll sit outside my trailer and just admire the fiberglass all day 😂🥰
  16. We have the same model RM2454, and we've done the same thing! Chris says I hit the switch with my butt when making a drink. 🤣 I use the shelf above the fridge as a bar top. I've gotten up in the middle of the night and it's dark up that way with no lights on! If all the lights are off, then it got turned off accidently. Our fridge has been holding today on AC power, after it needed LP to cool it down at first. I also realized it was nowhere near level. Checked the LevelMate this morning and the front was almost 6" low! That's the way it is in my driveway, hitched with the truck parked in the garage. I raised the front about 3" this morning but can't get it higher because it has to stay hitched. Richard, I'm glad you are working on getting yours to perform again! I was looking at replacement fridges and they're either too small or too big and too much money. Thanks for the heads up on Dinosaur boards. Yeah, if the Xantrex is keeping Marianna up at night, just shut it down. I sleep above our Victron and if it's charging when I want to go to sleep, I'll turn it off. Lucky I can switch it off by the phone app. At some point I'll figure out how the AC/DC circuits work on our model and how to test them myself. This guy may be worth following.
  17. Last week
  18. JD1923: I should clarify my issue. We have a Dometic 3 way RM2454 refigerator. Out charger/inverter is a Xantrex Freedom XC 3000 Pro Inverter. So the situation was: After the 3rd day of camping, we left the campground to go to the fair and was gone 4 hours. Upon getting back to the trailer, the refigerator was off completely. I tried turning the unit on and it would not start up on AC. I then switched it on DC and the Xantrex started up (likely to charge the batteries) and did ot turn off. Since it is under my wife's bed, I know the noise would be too much for her. I then switched it to propane and it ran fine. The next day after I thought about it for awhile, I pushed the auto switch in and out for a few times, as it would not activate the first time and only run on propane. After working the Auto switch a couple of time it finally worked and switched to AC. So the moral of the story is.: 1. I think that one of us had accidently hit the on/off switch before leaving the trailer. The auto swtich had not been pushed for a couple of years, so the contacts may have been dirty. 2. I have always found the button operation to be difficult to get it to ingage, maybe due to dirty contacts. That would explain difficulity in getting the refig started again and switching to AC. 3. After discussing the siuation with a knowledgable friend, he suggested buying a new eyebrow board from Dinosaur Electronics who make a better board the Dometic, which I have ordered. I also ordered a new Dometic board (which includes the face plate) since the cost was less than $5.00. I will now have 2 back up boards when needed. Other explalination would be appreciated.
  19. Pulled our Oliver into the driveway yesterday, since we're leaving for SW Colorado tomorrow. Like Dewdev, I started our Dometic 3-way fridge on DC. It did not seem to work. On the Epoch and Victron apps you could see it was only pulling -4A total and our system pulls -2.5A with almost nothing ON! I think I had the Maxxfan on too, so the fridge switched on DC was not actually pulling any DC power from the batteries! Switched it to AC and the readings changed to -16A which is a good number showing the fridge is drawing amperage so should be running. Two hours later the freezer had cooled down to 26F, the fridge at 62F, ambient cabin temp was 79F. This was going nowhere fast! Later last night, I switched the cooling to LP and started the Beech Lane fan at 50%. I sat at the dinette for 5 minutes to hear the LP ignite. It took two tries because on the first try I had forgotten to first light a cooktop burner to bleed the LP lines. After the bleed, I could hear it go through the click pattern twice to ignite and then I could hear it burning, a soft smooth sound. This should be working now. Got up this morning to read the freezer at 8F and the fridge at 36F (Ruuvi sensors and app). We always keep the fridge cooling setting at #4 out of 5. So our fridge is hardly a 3-way anymore! I will try running on A/C (Victron inverter always ON) while we are towing. Maybe now that it's cool it can sustain running on electric. Last trip we were at 7600 ft elevation north of Flagstaff and the fridge had issues staying lit overnight at altitude. This trip we will always be above 7K+ ft. After all I've done to our Oliver, I'd hate to think fridge upgrade now, but it looks like it's coming soon. At least we have the 45L CFX5 fridge in the truck if all else fails. We're packing light on food with good local markets on the route!
  20. Welcome to the group and congrats on the new Ollie! Look forward to meeting you out there somewhere! Mike
  21. I think you forgot the golden rule of design," we gotta make money" which follows all of your design examples. Mossey
  22. Hi all, First off, thanks to all of the Oliver forum members who post comments and Q&As. The info we’ve gained from periodically checking the forum activity was incredibly helpful in our decision to buy an Oliver, and in figuring out which model and options would work best for us. Although it took more than a year of research, we finally made the leap this past June! We will be picking up our 2027 Oliver Legacy Elite II (Twin Bed floorplan) on September 8th — Hull #1735. We were tent campers for about 40 years and spent the last 8 years camping throughout the Carolinas and Virginia in a 15-foot Taxa Cricket. We are really looking forward to the next chapter of traveling and exploring the country in our Ollie. If anyone is around Hohenwald during our pickup week, say hello! Chuck and Beth Lexington, NC
  23. As @Steve Morris provided plus one extra 4’ pole section in my application.
  24. @Omward Bound Appreciate your post. Very nice looking ceramic application. We're in Lincoln County NC, will give Blake a call when we're ready for ceramic coating. Thanks, Bill
  25. I hear ya, but unfortunately I’m corrupted by spending the last 32 years continually discussing what ‘good design’ is 😅 There’s many different types, ‘design for test, design for mfg, design for repair, design for usability … ‘ What you really mean is it has poor accessibility design. Agreed, or at least it’s not optimal. However it has excellent manufacturing, repair, and simplicity design. Also my post above points out it has excellent usability - once you get in the cabinets its easy to use, don’t need the documentation (diagram) most of the time. And it has the best aesthetic design. The layout is beautiful, and it doesn’t intrude into the cabin with ugly gubbins. So just back of the envelope, it wins in five categories and loses in one (accessibility). Hey, if you can get that kind of hit rate than yes it’s a good design! Design for repair, and design for repair documentation. You’re complaining about the latter. Basically nobody worries about that, it’s what repair manuals (or support lines) are for. I mean seriously, those fuses aren’t hard to find, I did it in my first trip when the composting fan went out. That fuse is in the same spot, I was glad it was so accessible. Turned out it just needed reseating. Anyhow I’ll stick up for Oliver here. One of the things I appreciate about this trailer is how well designed it is. Because they’re not changing the basic design every year! They have one body and frame - that’s been perfected within the form factor, and they just keep refining the interior components and layout. It’s always massive compromise and I love working on this thing, they’ve balanced it all so well after all these years. I absolutely love how neat and tidy it is, with automotive channel wrap on all the wires. Work of art … Ah sorry, been too long at the farm 😅
  26. We bought our used a few months ago. Went to Pennsylvania to pick it up. Love it. We have been staying on Oregon coast a bunch. We reside in Grants Pass Oregon IMG_0858.mov
  27. Appreciate the info and thanks for being back to me.
