Hard to be sure, but it looks like the overhead speakers are gone. We like the old sound system for music and videos. I'm glad the swing out windows are here, but they usually have integrated shades/screens in other RVs. Those bulgy shades look sketchy.
Haloview BT7 Touch Rear Camera installation on 2022 LEII
Steve Morris replied to dhaig's topic in Ollie Modifications
Don, how persistent is the connection between the camera and the display? Are you seeing dropouts and/or lag? After seeing Mike Urbancic (@Boilermake Chemist) using a Haloview MC7108 at this year's rally, I ordered one, too, along with this adaptor plate with furring to Haloview connectors. https://a.co/d/iMfzTgw The setup worked beautifully in the driveway! But a couple of weeks later when we took our trip to Adirondack Park was the first time I used it on the road. As soon as I got up over 30 or so MPH, I started getting a lot of dropouts. And when there was a signal, a lot of the time there was significant delay. I'd see cars beside me that were just coming into view on the backup camera screen. We moved the receiver all over the dash, against the sunroof, Deb holding it next to the window, all while adjusting the antenna to get best signal. Nothing helped. We were on a 10 day trip, and my return window was 4 days away, so I'm stuck with it. Worse, the Fusion camera and monitor were at home in the garage. I don't really use the camera for backing up, instead preferring it for lane changes and keeping an eye on traffic approaching from behind. I've got it on Facebook Marketplace now, describing how it would be good for something shorter like a truck camper or back of a truck cap. But no interest so far. Haloview Customerservice was useless, answering there first email with generic tips, and never answering the next three or four I sent... So, I'm curious to see how yours works with two antenna on the monitor. The only thing I can think of to cause my unit (and many others after reading more reviews) to lose signal at speed is due to 4K bandwidth of the new camera compared to whatever low resolution is on the original Furrion. But it can't just be interference from engine noise, because I manually kept the truck in first gear to test it at low speeds but high RPM, and no loss of signal or delay. I'm perplexed. -
The old Pullman Sleeper Cars had nicer looking blinds. They were nice and tight, not like a pillow🙃
It was delivered 2-tone by Oliver. I can't find the original announcements. They were off Oliver website.
I saw that on Facebook and commented. Definitely not a fan of the new blinds! They look cheap compared to the current version, and that spot where it rests on the window handle looks like a wear/puncture point, as well as just plain ugly. The TV looks smaller, and the cable entry for the TV swapped sides. Chrome belly band seems to break up the interior better to my eyes. Overall, *I* think it is a step backwards in quality appearance.
It must have been painted or wrapped post sale.
Hull #1000 was built for couple from Tennessee that was 2-tone white/Gray. I heard it was sold. Memory was it was a white top and gray bottom, but I don't remember. It was a 2022. Not sure whether this is #1000 or someone else's. Who knows the story of Hull #1000
Very good use of this unused space! @ScubaRx put a disc brake controller up there moving the LP tanks back a bit. One day I’m sure I’ll mount something up there, TBD! 🤣 I’m sure you know this, but recycle this fuel into your gasser TV every time you return home. You can’t count on our regulated fuel today to last much more than 30 days without an additive. I fight this battle constantly with all the many (near 20) gas engines we have on the property!
- 1 reply
- 1
David that's very cool and clever! Sounds like you know the maker! Do you think you could get the slicer file from him, or have him put it on Thingiverse? Is it made from PLA filament? BTW, I never mentioned it, but the rubber weather cap that comes with the Rj45 socket can be used under Furrion cap. Mine has disappeared though! Thanks, Geoff
Goal: to Minimize the Need to Move the Beds while Camping
Final step on rewiring the basement electric. I had left room for the DC-2-DC charger and having everything conveniently rewired to the rear dinette seat made everything close and easy! 😂 I have another thread on the charger installation => https://olivertraveltrailers.com/forums/topic/10757-the-victron-orion-xs-1212-50a-dc-dc-charger-complete-installation-and-testing/#comment-115374 -
Going back to Geoff's original post on this thread, I did this (except for relay) and it works great but have been concerned about water penetration at the exterior socket when Starlink cable is plugged in. I have swapped mine out for a water-resistant component custom designed and made by Tom at Platypus3DDesigns in Mesa, AZ. Although the original socket worked great, it was not water-resistant so I asked Tom to create one that would replace the Furrion Mini TV/Satellite Inlet. Here is the link to his component. https://www.etsy.com/listing/4349330543/starlink-mini-dc-cable-pass-through It has 18 gauge wires attached and a magnet that holds the cap in. In addition, he adds another magnet on the side that can hold the cap when not inserted. I asked for a modification so I could add a lanyard. Tom drilled and threaded #8x32 holes for that. All screws and machine bolts were attached with blue Loctite. I was able to use the original Furrion gasket. I had to drill out the hole in the fiberglass a bit larger and I wrapped some butyl sealant around the barrel upon installation. Here is a link to the lanyards. https://www.amazon.com/dp/B0B4RXTKBH?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1 To finish it off, I used a very small amount of dielectric grease on the cap seal and rubber fins on the Starlink cable end. Works great. David P.
While preparing for an upcoming trip, where I’ll probably need to run a generator for AC, I decided to utilize some unused space in the dog house to store my RotoPax 2 gallon gas can. I used to carry it in the tongue tray with the generator, but now I’ll always carry it for emergency fuel. I made a rectangular box that's sized so there is just enough friction to hold the gas can snugly in place without needing a strap, and narrow enough to fit between the propane tanks and the front of the doghouse. The tank can’t come out anyway because of the doghouse cover. I measured the can after leaving it in the sun for a while to account for any expansion. The fuel can holder is made from 1/2” void free plywood (baltic birch), and it’s put together with glue and screws. It was rattle can painted with primer and plenty of white gloss, then attached to the frame with self drilling 1/4” screws, like the ones holding the propane tank tray. It can be locked through the handle if desired. The RotoPax gas cans were originally made for off-roaders, and they are pricey at around $85 each. But they are practically indestructible, and they come in different colors for diesel or water. I’ve had mine for around 7 years and it’s never leaked a drop. There are knock-offs available on AZ for about half the price, but I can't vouch for their quality. From the plywood scraps, I also made a little box for the luggage scale that I use for weighing the propane tanks. It was made in the same way with magnets to hold the hinged lid closed. It was mounted in the doghouse in front of the propane tanks. Hope someone finds this useful. Cheers! Geoff
- 1 reply
- 6
Just saw this pic of the 2026 Oliver “retro” interior with roller style window shades. 😳 Appears that the interior window latch may rub on the shade. Also note the white belly band instead of chrome.
Million Dollar Highway in a half ton truck with LE2?
johnwen replied to routlaw's topic in Towing an Oliver
Yes, on the Ollie. -
routlaw replied to routlaw's topic in Towing an Oliver
Point well taken, and great info. I do run quite a bit lighter than you but still. Presumably the flat was on the Ollie and not your Silverado surely? Scary stuff. Likewise I keep a TPMS on ours too, monitors heat and pressure. -
Ah the beauty of a big diesel engine when it comes to engine braking. All that compression truly becomes helpful on these steep descents. A definite disadvantage for gas engines especially the 6 cylinders, turbo boost or not. A couple of years ago I learned this lesson all too well while going over Teton Pass dropping down to Jackson. By the time I was halfway down my then 2013 Ecoboost and Ollie brakes were all smoking. Even 2nd gear was not much use on a 10% grade that runs for about 10 miles. Not something I would ever like to repeat. We were not the only ones that day smoking brakes either. A fifth wheel just in front of us being pulled by a 3/4 ton truck was also in trouble and had to make an emergency pull over. Thus my caution on the Million Dollar Highway. -
Saw a grey/white E2 heading West on I80 in Nebraska today (grey top/white bottom). Best-looking E2 I have ever seen. If this was you, how did you achieve the solid grey on the top clamshell (wrap, paint, gel coat)?
dhaig replied to dhaig's topic in Ollie Modifications
@Snackchaser, thanks for the kind words. I have admired you many technical posts. I recall seeing your posting on turning on the rear camera. I had several projects in my queue at the time, but will revisit. Don -
This is what I keep hearing from some YouTube videos. Might be a better route on my return trip vs on the way south. -
Snackchaser replied to dhaig's topic in Ollie Modifications
Nice work Don, very creative and well documented! Being such a handy guy, you might also like my post "Turning on the rear camera automatically." It sure beats always having to remember to flip the camera switch on and off every time. Cheers! Geoff -
Late-Model RAM Owners - how do you like your “tech”?
Snackchaser replied to Galileo's topic in Towing an Oliver
Just an FYI. If the digital rear view fails, it still acts like a normal mirror. It has to, because the camera doesn't work well in the dark.
